Welcome to the North American Subaru Impreza Owners Club Sunday November 17, 2019
Old 01-14-2018, 03:55 AM   #1301
amiexploited
Member#: 251061
18 Trek 6mt,
garage queen 15 WRX 6mt
Originally Posted by amiexploited View Post
Thanks for the input fellas! The sun is out today so I'll start taking off panels.
Well.....it was my loose airbox. The 10mm bushing bolt on the top was loose. Wow.
amiexploited is offline   Reply With Quote
Old 01-28-2018, 04:24 PM   #1302
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Alright, I need some help. I cannot figure out WTF is making this goddamn squeaking noise.
In the video I'm sitting on a slight hill facing down, just letting off the brake while in neutral, going down a bit and then hitting the brakes to stop.
I've taken the center console up and held the wires and stuff underneath there, but the noise is still present. I've had a passenger in the front seat and back seat. Held the front seats so it can't move, moved the passenger seat all the way up and back and middle and the seat back the same... noise is still there. I think it's possible that it's coming from underneath the car somewhere near the center tunnel.
I did take the car into the dealer and they said that some passenger seat wiring/plugs were loose and they fixed those. Noise is still present - though that may have fixed some other rattling noises, idk - this is the big problem.
Any ideas?
Pantyraider is offline   Reply With Quote
Old 01-28-2018, 11:05 PM   #1303
Cab0oze
Member#: 443914
2015 WRX
That sounds crazy annoying. Unless someone else has already experienced this, better get down to the basics. To rule the underside of the car out, have someone do the same thing while you're outside with the car off.
Since it is so easily repeatable it should be easy enough to have a passenger stick their ear around/touch stuff until they find where it is coming from. Where do you think it's coming from?
Open your glove box, make sure it is nothing in there. Does it do it when you go over bumps? When did it start? (i.e. following some other garage visit?)
Anyway just a thought - if you're convinced it's the pax seat, that seat is pretty simple to remove... yank it out for a day. If you still have the noise, you've at least ruled it out, and it gives your passenger in the rear seat a lot more room to move around to find the source.
Cab0oze is online now   Reply With Quote
Old 02-01-2018, 01:31 PM   #1304
Midnite8
Member#: 430858
2016 WRX Premium
World Rally Blue
Anyone have a custom sound system/SUB like me with a 2017+ rear view mirror(with autodimm, compass, homelink) experience rattling? I have a 2016 and my rear view mirror rattles really bad on crappy roads and when I obviously crank up my volume. Seeing if the new mirrors have a slightly different design that doesn't rattle as much. I took my mirror apart and added CLD tiles in it to hopefully add mass to it but seems like the issue is where the lip around the plastic meets the actual mirror that rattles.
Midnite8 is offline   Reply With Quote
Old 02-03-2018, 04:09 PM   #1305
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Squeaky STI - 2017 Limited - YouTube
Any ideas?
This ended up being shifter stabilizer bushing (35036AA010 - CUSHION RUBBER-GEAR SHIFT) that needed to be replaced.
So far I haven't heard the noise again. Hopefully it stays that way.
Bottom middle
Old 02-05-2018, 01:20 AM   #1306
Subie_pnw
Member#: 437681
2008 Forester XT
Originally Posted by Devilchrist View Post
Seems liek there's a Lot of repeated questions of rattles.
So I'll just list what I got from various threads.
SOLVED
1. Steering column rattle - This seems like it's the Cruize control button.
Solution - Take stalk apart, remove button, spring and ball, stretch spring. reinsert. no more rattle
2. Rear window rattle - This seems to be the seat bracket
Solution - Take the reat seat back out. The center latch on the seat rattles against the hook bolt. Put some dynamat or some durable thick rubber on top of the bolt head. *note* i put dynamat, it worked for a few months.. but it wore through.. and started ratteling again.. next will be piece of thick leather.
3. passenger Door rattle - this seems to be wiring rattleing against the inner door panel or the cover. Use some sticky foam and wrap wires..
4. wagon spare tire rattle thanks "sjl1614" for solution
solution - Where the spare tire "cover" sits down and rests of the plastic trim, right under there, the trim sits on metal tabs. Which is the souce of the rattle. use some foam tape on the metal tabs and the noise is gone - sjl1614
5. Drivers side door handle thanks "Flat4 STI"
solution - Drivers side door handle,where you pull the door closed would rattle. 3m double sided tape on the bottom of it where the screw pokes through.
6. Steering column top plastic rattle thanks "Flat4 STI"
Solution - 3M double sided tape,Once you take off the top piece of plastic, nearest the steering wheel theres a piece of plastic that sticks up,I used two layers to touch the column plastic pieceAlso about the middle of the steering plastic piece i put another piece of 3M there also.Kinda hard to descibe.
7. Rear deck area rattle where third brake light is "Flat4 STI"
Solution - center seat belt plastic cover in trunk was loose,the piece that covers the retract part,Silicone around top edge to hold it in place.
8. high pitch rattle behind ear thanks "gh32"
Solution - Very faint metal-on-metal high-pitched noise that took me a while to identify. Turns out it was the zipper on the passenger seat on the top of the pass-through (roughly behind where your neck is). Easily fixed with a piece of tape.
9. glove box key hole
Solution - try using some thick silicone grease? if the problem is within the lock, if its outside then, remove the unit and add 3M windows seal
10. glove box rattle thanks "hank3"
Solution - I had the glove box rattle and what I did was wrap some black electrical tape around the U-shaped bracket the door latch attaches to. That fixed the rattle
UNSOLVED
1. Seatbelt top cover rattle - I put this on unsolved because to me removing outright is not a solution.
2. Driver side A Pillar, Vent cover - put puressure on the vent cover piece by the A-Pillar and rattle stops. -
Things I tried
- siliconing the white clips..
- taping the vent cover piece to the bottom piece..
- strips of fuzzy side of velcro (helped a bit but still there)
- removing the entire vent cover
*edit you can emulate this sound by pushing down on the vent piece. repeat until you have the right speed and pressure.. the only way i see to solve this it to jam some thick cloth to maintain the pressure, or take the dash apart... i have not done this yet...
3. Steering column rattle - left wheel goes over bumps - when only the left front wheel goes over the bumps the whole steering column shutters... I dont' think there's going to be a solution to this..
4. Rearview mirror - if you have warrenty left then it's all good but what if you don't? any one have a fix for this?
anyone else like to add?
I've got one not listed... 2014 Crosstrek, there is a rattle (well, in mine at least..) right smack dab in the middle of the dash. I got mad at it once and slapped right under the hazards button and it stopped for about 15 seconds. Now I drown it out with music.
Subie_pnw is offline   Reply With Quote
Old 02-16-2018, 09:12 AM   #1307
bobbypty
Member#: 325834
2011 Impreza 1.5R
Sky Blue Metallic
Default Impreza sedan 2008-2011
Hi guys.
If anyone here has a creaking coming from the rear seats I found that the culprit was the striker/latch mechanism so I wrapped duct tape (maybe felt tape will also work) a couple times so it makes the seat thight when it locks into place and boom! no more noise.
bobbypty is offline   Reply With Quote
Old 02-19-2018, 04:03 PM   #1308
SlickWRX
Member#: 17312
2015 WRX STI Limited
Dark Grey Metallic
I had the 2015+ passenger door rattle issue. Opened up the door card and put in a piece of foam adhesive going around the speaker and it solved the issue for a while. Now it's come back. Not sure if its the same place or a new one. I was watching a video on YouTube where someone took out a plastic pad from the door that didn't appear to have a specific purpose. It had some adhesive foam on it as though Subaru knew it was the source of a rattle and put that on it.
So the interesting thing is I wanted to know what this is specifically for. The best I've been able to find is its some kind of water guard. Although in my findings I also found out that there are two different versions of the part depending on whether or not you have the premium audio. I wonder if the root cause of the sound issue is due to this part being mismatched with the type of audio in your car. I'm going to check it out when I get home from work but I wonder. Hopefully the part number is stamped on the part somewhere.
PAD - SUBARU (61208VA010) - Premium Sound
PAD - SUBARU (61208FJ000) - Without Premium Sound
SlickWRX is offline   Reply With Quote
Old 02-19-2018, 09:56 PM   #1309
HCowell
Member#: 482167
2012 Impreza WRX
World Rally Blue
Default Amazing!
Thanks for all the great tips!
HCowell is offline   Reply With Quote
Old 02-24-2018, 09:00 PM   #1310
SlickWRX
Member#: 17312
Dark Grey Metallic
Sorry guys. Been busy. VR headset came in and I was consumed with it. I took apart that passenger door. Testing is positive at this moment. I spent like 20 mins listening to my music. No rattles like before. I removed all of the interior door panel plastic sheets and foam.
I also removed the part I questioned. Guess what? It was the wrong part. I have a Limited with the HK sound system. This part is for the non premium sound system.
Maybe some of you guys with these 2015+ door rattles can check this part too.
Old 03-05-2018, 12:08 PM   #1311
amiexploited
Member#: 251061
18 Trek 6mt,
Decided to take my 15 wrx on my new commute route. Bumpy roads revealed rattles along the headliner near the visors. I taped up the wires above the map light. Still there. I saw a post about the visor rattles. Any one know of a fix?
2015 wrx limited
Thanks!
Old 03-05-2018, 12:29 PM   #1312
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Anyone have a fix for a squeaking dead pedal?
Old 03-08-2018, 10:42 AM   #1313
whowhat
Member#: 483095
So many rattles, so little time!
whowhat is offline   Reply With Quote
Old 03-24-2018, 08:17 PM   #1314
SlickWRX
Member#: 17312
Dark Grey Metallic
So in the interest of following up on the passenger door sounds with the HK premium system on the 2015 STI, I ordered the part that is supposed to correspond to the premium sound.
PAD - SUBARU (61208VA010) - Premium Sound (https://www.subarugenuineparts.com/o...pad-61208va010)
I removed (61208FJ000) which one YouTuber (
) said *should* fix the issue. If anything it made it worse. I will try out the newly ordered part by itself. If that does not fix it I will go completely overboard on padding and isolating things in the door. BTW, I asked SOA about this and they gave me a really **** answer and told me to go to a local dealer. The same local dealer who didn't presumably install the correct parts in the first place.
BTW that part is $17 and change, so whatever. If it works then great. If not oh well, it's not a lot of money.
Edit: Part came in. Not sure how I got it mixed up but its for the left side, not the right, which is what I would have wanted. The part is exactly the same though. Oh well.
Old 03-25-2018, 07:50 PM   #1315
max0117
Member#: 483831
WD-40
max0117 is offline   Reply With Quote
Old 05-28-2019, 07:46 PM   #1316
mrco555
Member#: 252184
Default 2016 STi dashboard creaking noise
Hey guys,
I have a 2016 STi with about 38k miles. Recently, I have been hearing a creaking noise coming from the dashboard on both the passenger and driver side. It sounds like plastic and metal rubbing together and making a popping/creaking noise near the top of the dashboard near the windshield. It actually reminds me of a worn out bushing.
Could it be the windshield or maybe a loose bolt? I can't seem to find the source. It only happens with abrupt bumps.
Any suggestions?
mrco555 is offline   Reply With Quote
Old 05-28-2019, 09:47 PM   #1317
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Originally Posted by mrco555 View Post
Hey guys,
Any suggestions?
Same here.
I forgot about this thread. I wish I could forget about all the rattles
Old 05-29-2019, 02:47 AM   #1318
Breezzy
Member#: 490331
2006 STi
My door cards are starting to rattle
Breezzy is offline   Reply With Quote
Old 05-29-2019, 03:01 AM   #1319
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
2015 Forester XT, Tribeca
Hey guys,
Any suggestions?
Check the dash speaker grills. That was the cause of my 2017 WRX RATTLE issue. In my Forester XT it was aftermarket pioneer GPS antenna rattling in that same spot.
ImprezaRS dot com is offline   Reply With Quote
Old 05-29-2019, 10:19 AM   #1320
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Interesting... I had one replaced already under warranty because it wouldn't stay seated down all the way, it was sticking up in one corner. Still looks like it's flat now, but I'll check them again and see if reinstalling them fixes that particular noise.
I probably need to take my door cards off and do something there, too. And the rear deck.
Old 05-29-2019, 12:48 PM   #1321
mrco555
Member#: 252184
Thanks! I will try that. If it doesn't work, I will record a video of the noise and go from there.
Old 05-29-2019, 01:02 PM   #1322
Cab0oze
Member#: 443914
2015 WRX
Hey guys,
Any suggestions?
I had rattles around there too. For me it was the A-pillar clips, tweeter grills and plastic trim around the gauge cluster.
Basically Subaru clips suck. Tear off every trim panel (door card, pillar etc) remove the plastic clip, put some electrical tape across the hole where the clip is installed, and then jam the clip back in and re-attach the panel. Will stop the rattling.
For the tweeter grills, just put sticky backed felt (available at hobby stores) on the clips, and around the edges. For the gauge cluster trim, hopefully that's not your problem. Mine only made noise when it was cold. Press on it in various spots (top, sides, bottom, etc) to see if that stops the rattle. if it is, you'll have to take it off (easy) and put felt on every single surface until you find out which one was making the squeak. Took me like 5 attempts, but luckily it's easy to remove - just 2 screws IIRC.
Good luck!
Old 05-29-2019, 08:32 PM   #1323
mrco555
Member#: 252184
I went ahead and recorded a video of the creaking sound. Don't know if this will help.
https://youtu.be/uPucLG8qCgo
Old 05-29-2019, 08:50 PM   #1324
mrco555
Member#: 252184
Good luck!
Thanks! I will add this to my to-do list.
Old 05-31-2019, 10:36 AM   #1325
mrco555
Member#: 252184
Tried the speaker grill fix but it didn't help. The creaking noise sounds like it is where the firewall and dashboard connect. Here is a video of the noise:
SF5 forester thread doublej Member's Car Gallery 20 07-26-2012 02:30 PM
Can We Get a DIY Thread Going? STIckySTIfee General Community 17 04-03-2008 01:00 PM
Can we get another ice thread going? forced4 Texas Impreza Club Forum -- TXIC 0 01-17-2007 12:41 PM
Can we get an OT sing-a-long going? BEGIN! snvin Off-Topic 27 12-01-2005 02:15 PM
