Welcome to the North American Subaru Impreza Owners Club Tuesday November 12, 2019
Old 06-07-2019, 01:32 AM   #51
Wrekluse
Member#: 502948
Good luck getting the claim, I had an 09 forester XT that was from the stop sale vin range of 2009 and they wouldn't do anything for when it spun #1 rod bearing at 90k. Known engine failures with a stop sale and nothing.
Wrekluse is offline   Reply With Quote
Old 06-14-2019, 11:13 AM   #52
MarkkInNj
Member#: 393094
2014 WRX Hatch
Ice
interested to see where this goes as the final hearing was last week. Motor blew at 13k, stage 1 AP tune, and they covered it under warranty. Also purchased an extended warranty after that, which sucks since now this one is longer anyways.. lol
MarkkInNj is offline   Reply With Quote
Old 06-29-2019, 02:22 PM   #53
vinniev
Member#: 409494
2012 WRX
blue
Originally Posted by vinniev View Post
Update: 5/28
Rod bearing number 2 is toast. Rod bearings 1 and 3 are scored. Turbocharger doesn't spin freely. They will replace short block, but I have to pay for heads to be rebuilt and cleaned and buckets to be replaced. Also doing timing belt kit and clutch and flywheel. So free labor there.
I thought the heads and turbocharger would be covered because of lack of oil from rod bearings, but guess not. Total out of pocket $3,870. Including turbocharger.
Update: 6/29
Picked up the car yesterday. Got the price down to $3,000. Would have been nice if they covered the heads and turbocharger, but really can't complain the car had almost 100,000 miles on it.
So far runs great have to bring it back in 1,200 miles for a check up.
They didn't say anything about braking in the motor or turbo.
vinniev is offline   Reply With Quote
Old 06-30-2019, 03:59 PM   #54
greatwhitehunter77
Member#: 503774
WHat was it for? Turbo failure from cat?
greatwhitehunter77 is offline   Reply With Quote
Old 07-01-2019, 07:41 AM   #55
vinniev
Member#: 409494
2012 WRX
blue
Rod bearing number 2 failed so oil pressure to the rest of the engine was to low.
Old 07-05-2019, 11:20 PM   #56
dolemite
Member#: 503963
Subaru n00b here. Looking @ a WRX since it's one of literally a handful of appealing cars these days.
Does the FA20 suffer from any notable problems? Honestly the ring land thing is scaring me away from getting an STI.
dolemite is offline   Reply With Quote
Old 07-17-2019, 02:21 PM   #57
HDmac
Member#: 442367
2012 WRX
I've got a 2012 hatch for sale in NH with a built short block if you'd be interested in something like that.
HDmac is offline   Reply With Quote
Old 07-17-2019, 02:44 PM   #58
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Early ones were covered for "excessive oil consumption". My Crosstrek with an FB20 had the short block replaced at 94k miles. Honestly, if they had offered me a few hundred dollars to live with adding a couple quarts between oil changes, I'd have gladly taken it. So far, the new short block hasn't used a drop of oil. I expect newer FBs have corrected this issue. I don't know what was done to fix it......as I also don't know what was corrected following the CVT replacement in the same car at 53k miles.
Old 08-16-2019, 11:07 PM   #59
ben_7
Member#: 464522
2018 Subaru WRX STi
Default WRX/STI engine failure class action settlemnet
So does anyone know if the 2018 STi is affected if it has the same short block as the 2017 STi?
ben_7 is offline   Reply With Quote
Old 08-16-2019, 11:39 PM   #60
F1EA
Member#: 448622
2019 STI SportTech
CWP
Affected? This is a class action settlement benefiting owners of models from 2012-2017.
So no; the 2018's are not part of the class settlement.
F1EA is offline   Reply With Quote
Old 08-18-2019, 12:20 AM   #61
ben_7
Member#: 464522
2018 Subaru WRX STi
What I mean is, are the 2018 STi motors also susceptible to engine failure for the same reason as the 2017 STi motors?
Old 08-18-2019, 04:04 PM   #62
F1EA
Member#: 448622
2019 STI SportTech
CWP
Well, the specific class action lawsuit has to do with the connecting rods, and as far as I know there hasn't been any changes to those. I think there's another class action for the ringlands, but I'm not sure.
The 2018 RA and the 2019 STI do have 'upgraded' pistons... which seem to address another issue (ie the ringland failures), but there's been very little feedback on whether they will or will not suffer the same issues. I don't even know if the issue is as prevalent (in 100% stock cars) as it is made out to be.
What I'm saying is...
Are you planning to modify the car? if not, then don't worry because from what Subaru has been doing (even with the CVT transmissions) is that if the problems do persist, they include the newer years as their factory warranties run out. And even if the problems don't persist... they seem to just keep issuing the warranty extensions. Plus Subaru (at least here in Canada) are not bad with warranty. They deny modified cars, but if your claim is reasonable, then they typically help with no issues.
Another option if you do not want to modify the car is to just get an extended warranty directly from Subaru. If your car is still under factory, you can get an extended for reasonably cheap. Some people say they are worthless. Some praise the lawd when their engine pops and they still have warranty.
If you are planning to modify... then just know that you have to be VERY careful no matter which model yr you have. There's lots of examples of people successfully modifying even the older ones; and examples of people wrecking the RA and maybe even 2019.
Most people go with a "reputable tuner" and expect (and assume) they have a PERFECT tune... that's crazy. And others run an OTS but don't follow the map notes to the dot. That's bad.
In my case, if mine fails and doesn't get covered under warranty, I'll put in a built block. So while I'm doing everything in my power to not wreck the car; if it does, I'm ok with the $6k or whatever to deal with it. And I dont even bother constantly reading my AP and so on. I monitor or tke a log every once in a while just to give it a quick check, but mostly keep it stored away. I don't want that stress in my life. That's why I prefer conservative tunes and safe routes rather than trying to extract the most power.
One thing is certain: out of 10 STI or EJ WRX I see for sale, easily about 7/10 are on their 2nd engine. BUT 9/10 have been modified
