Welcome to the North American Subaru Impreza Owners Club Thursday November 21, 2019
Old 08-29-2019, 10:16 AM   #1
smccloud
Member#: 442552
Default 2008 Impreza 2.5i bubbling in the overflow tank
Around 3 months ago I replaced the head gaskets, timing belt, water pump, thermostat, radiator, etc on my Impreza. All has been good up until now. Last Saturday I was driving into the office for some out of hours work (the joy of IT no one tells you about) and the temp light started flashing red. First time I've ever seen that, pulled off at the nearest has station and when I opened the lid for the overflow tank I could see a bubble every second or so. Once I got done working for the day I pulled off the radiator cap, topped off the radiator and started the car. At that point I saw no bubbles in the radiator. Drove home without incident but when I got home the bubbles were back in the overflow tank. Put a new radiator cap on because it's an inexpensive thing to try. Still happening. Did I mess up putting the head gaskets in or did I not purge the cooling system properly when I refilled it? If it helps, my normal commute is 1.5 miles each way to the train station. When I have to drive in to the office it's around 50 miles each way.
smccloud is offline   Reply With Quote
Old 08-29-2019, 01:34 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
When up to temperature, sounds like there's just enough gap to allow combustion gasses into the coolant. When things cool off, the gap closes, no bubbles. Did you have the heads or block checked for flatness?
yarrgh is offline   Reply With Quote
Old 08-29-2019, 02:09 PM   #3
Blktrax
Member#: 220971
2002 WRX 224K Mi.
If you didnít measure the heads for flatness or have them machined likely the heads were warped from the previous gaskets.
Alternatively if the proper torque and sequence wasnít followed would also lead to head gasket failure.
3rd and somewhat rare possibility depending on the heads condition and if they were overheated, sometimes internal cracks happen in the head itself, and only open up as the metal heats up.
Blktrax is offline   Reply With Quote
Old 09-01-2019, 09:00 PM   #4
smccloud
Member#: 442552
I think I missed a step on one side when I torqued the heads. Sounds like I get to replace the head gaskets again
Not sure where I be can even get there heads machined, I don't think there is a machine shop anywhere me :+
Old 09-02-2019, 11:57 AM   #5
smccloud
Member#: 442552
I had traded my car for my dad's pickup for the weekend because the wife kids and I went camping. He noticed that the lower radiator hose was weeping done, could that be part of the issue too?
Old 09-04-2019, 07:36 AM   #6
smccloud
Member#: 442552
And it was the lower radiator hose being slightly loose
Old 09-04-2019, 01:39 PM   #7
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
good to hear you found the culprit. thx for following up.
Old 09-04-2019, 03:21 PM   #8
smccloud
Member#: 442552
Actually my dad found the culprit. Thankfully he was willing to look at it while we had his truck so we could bring the bikes camping over Labor Day weekend. Helps that he used to be an ASE Certified Master Technician.
Old 09-23-2019, 09:03 PM   #9
smccloud
Member#: 442552
And looks like I was to soon to call it solved. When I start it up now I can smell a little bit of coolant being burnt. Only on startup though. Oil looks good and the coolant isn't dropping to fast. Guess I'm doing head gaskets again in the near future....
These any good? I'm on a tight budget. https://www.rockauto.com/en/catalog/...head+bolt,5308
Old 09-24-2019, 02:33 PM   #10
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
You can reuse the bolts.
Old 09-24-2019, 07:42 PM   #11
smccloud
Member#: 442552
Reuse torque to yield bolts? Doesn't sound like a good idea to me. Plus my kids ride in it, I'd rather go longer without something I want/need than put them at risk of being stranded.
