Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 06-12-2017, 09:32 AM   #651
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Originally Posted by CalvinT View Post
You need to be sure they can handle engine oil pressure.
I'm pretty sure transmission fluid is run through at a lower pressure, maybe on return to the transmission sump.
True, another thing to consider.
Keep in mind, the cooling system will be pushing in on the "oil cooler" with about 16PSI.
As I stated before, depending on where you plumb it in, I would be concerned with the potential lack of flow through it.
Old 06-23-2017, 03:25 PM   #652
chansdaman
Member#: 457390
Default Good Experience with EBay Radiator
Just bought and installed a radiator from OPL (available on EBay, Amazon, and their own site) for $160. All aluminum, three row, good fitment, but had to trim the upper hose a little to clear the fan and the pulley. Model number is HPR078. Needed some bolts as well for the fans. All in all very pleased. 180F coolant temp while cruising. 10 year warranty is a bonus. My car is a bugeye with a hybrid swap.
chansdaman is offline   Reply With Quote
Old 06-23-2017, 03:38 PM   #653
chansdaman
Member#: 457390
Here is what it looks like.
Old 08-08-2017, 02:10 PM   #654
Freddy_WRX
Member#: 472520
Default Coolant Temp Sensor Bad
I think my coolant temp sensor might be bad, the accessport won a normal day of driving will read anywhere from 220 to 240, but my gauge cluster needle will stay at the bottom for a while once I start driving then out of nowhere it will jump up to above the red or sit at 3/4 and not move.
Freddy_WRX is offline   Reply With Quote
Old 08-08-2017, 03:44 PM   #655
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Most ECT's have 2 circuits, one drives the gauge, one drives the ECU for fueling. Part can fail but look good on the other.
Cheap/easy is to replace the sensor.
Old 08-19-2017, 11:06 PM   #656
RussianTiny
Member#: 387467
2018 WRX Limited
WRB Stage 2 FlexFuel
So what's the popular coolant enhancer for the FA? I've used water wetter in the past with good results on a 50/50 mix. I know the enhancers work differently on DI engines.
RussianTiny is offline   Reply With Quote
Old 08-26-2017, 05:35 PM   #657
CLL_OBP
Member#: 310435
'12 Sport Limited
ST HM 0W20 191,425 mi
Default 2012 Impreza Coolant Replacement & Capacity FB20
I replaced the coolant late last night and wasn't expecting so much out of the radiator. The factory service manual shows the CVT models have an 8.2 quart capacity. I bought two gallon jugs of Valvoline Zerex 50/50 thinking I was going to do two drain and fills. If the capacity is what it is, one drain and fill replaced over 90% of the old coolant. The second picture is after disconnecting the lower hose. The short line above the 7 quart mark shows how much more was drained.
Old 09-03-2017, 10:31 AM   #658
MikeC5
Member#: 104702
95 Legacy
Green
So I replaced head gaskets and am looking for coolant for my 2002 Legacy and my local Subaru dealer no longer carries the Subaru coolant for the older models. I've done a ton of internet searches and have found 2 or 3 other brands recommended (Peak Global, Zerex Asian, Beck Arnley) but none of them are locally available and I hate the idea of having to pay for shipping on something like this. I did find Zerex Asian locally but only in the 50/50 mix (which will cost about 80% more to do a complete re-fill since you have to buy 2 bottles!).
My (old) Subaru Long Life coolant bottle spells out the ingredients; Ethylene Glycol, Diethylen Glycol, Soduim Benzoate and Potassium Hydroxide (and water, even though it is a concentrate). I see many other brands out there with the first two main ingredients and have to wonder if any of those will suffice. I have a new bottle of Subaru Coolant conditioner that I may or may not use along with 6 Star MLS head gaskets. I'm beginning to think any coolant that is compatible with aluminum engines will work and it was only because of the widespread HG problems with these engines that make it such a hot topic. Anyone using a commonly available brand with no ill effects?
MikeC5 is offline   Reply With Quote
Old 09-04-2017, 01:26 AM   #659
CalvinT
Member#: 329025
2002 WRX Wagon
It's OK to mix the old and new coolants.
Subaru switched to the new (blue) coolant in 2008 starting with the WRX STi models. During the 2008 production run other models came with either the old (green), the new (blue) or a mixture of the two.
The May 2008 End Wrench issue discussed it. If you mix the two, you need to follow the replacement schedule for the old coolant.
CalvinT is offline   Reply With Quote
Old 02-12-2018, 02:26 AM   #660
nik790
Member#: 481982
Does anybody know what concentration of coolant to distilled water the plant/factory uses to fill the cars before shipping them out? Curious if they just fill them up 50/50 or anticipate people topping up with water, or depends on the region they send it out to.
nik790 is offline   Reply With Quote
Old 02-12-2018, 10:15 AM   #661
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
AFAIK, all are filled at 50/50, the OEM does not assume anything.
Old 02-12-2018, 05:37 PM   #662
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
It's probably 50%/50%, but you'd be safe anywhere from 40%/60% distilled water/antifreeze up to 60/40.
car_freak85 is offline   Reply With Quote
Old 01-15-2019, 07:51 PM   #663
slashnul
Member#: 496475
2007 Forester XT
In my 07 Forester XT MT, if I drive aggressively, park, wait a few minutes, then restart the car, the engine runs rough for about 30 seconds. I suspect its temperature related. I have a BlueDriver OBD2 reader coming in the mail. Once I get it, what should I be monitoring? Oil temp and coolant temp, and anything else? TY
slashnul is offline   Reply With Quote
Old 04-10-2019, 10:47 PM   #664
ohrearry
Member#: 400530
07 STI
Default Cooling System FAQ: Read if you want coolant information!
I recently did a coolant flush and fill as well as a themostat change on my 07 STi. Capacity in the manual says 7.6L~ which is more than 2 jugs of super blue coolant (3.78L each jug from dealer). I only got through 1 whole jug and 3/4 of the second jug of it until it stop accepting anymore coolant. I also added the subaru coolant conditioner. I am able to add little amounts after I let it cycle, but not much. I used a no spill funnel that burps the car as you're filling it with coolant.
My question is: should I be worried if its having trouble accepting the final jug of coolant?
Or continue to add little by little until its finally empty?
ohrearry is offline   Reply With Quote
Old 04-11-2019, 02:17 PM   #665
car_freak85
Member#: 13530
EJ205
Did you measure how much coolant came out versus how much you put back in?
Old 04-11-2019, 02:32 PM   #666
ohrearry
Member#: 400530
07 STI
I did not. I did notice my overflow reservoir is above the full mark by a little bit. Prior to refilling, it was about even with the full line on the reservoir.
When I did the flush I completely emptied the car of distilled water.
Old 10-06-2019, 12:47 PM   #667
Lug_Nuts_23
Member#: 506272
2002 WRX Sedan
Great FAQ. However, a few of the radiator brands listed at the top of the thread don't seem to exist anymore or at any rate their websites don't exist anymore.
ARC can't find any pages: http://www.arcinter.co.jp/
Blitz refuses to load: http://www.blitz-na.com
Gimmick also seems to be down: http://www.gimmickmotorsports.com
(Though I have found some Gimmick parts on other websites)
Does anyone have any new decent quality brands to add to the top of the thread for easy finding?
Lug_Nuts_23 is offline   Reply With Quote
Old 10-07-2019, 01:20 AM   #668
CalvinT
Member#: 329025
2002 WRX Wagon
I'd only use two brands, Subaru and Beck-Arnley.
https://www.beckarnley.com/parts/flu...life-blue.html
https://www.beckarnley.com/parts/flu...ncentrate.html
The Beck-Arnley website is useless for finding a dealer, but Google has several links including O'Relllys but you'll have to special order.
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 734 10-26-2019 02:18 AM
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! Unabomber Service & Maintenance 1076 10-06-2019 09:35 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 391 08-16-2019 11:49 PM
Tool FAQ: Read if you want information on Subaru specific tools and sundries Unabomber Service & Maintenance 41 08-16-2014 05:59 PM
