Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 03-05-2019, 12:09 PM   #1
What could go wrong
Member#: 448908
Default Left/right squeak diagnosis
I have been dealing with a drivers side squeak for a while, and I could never diagnose it because it would only happen while the car was moving. It would occur if I turned the steering wheel right wile the car was moving. I would get out and shake the car around and I could never reproduce it, so that eliminates the springs/dampeners. The other day I managed to reproduce it.
If I grab the top of the fender on the drivers side and shake the car laterally left and right, I get a squeak somewhere in the suspension... I haven't been able to track it down yet, any ideas on what it might be? I nut and bolt checked the sway bar and the bolts were tight, but maybe the bushing is bad or something? Thanks in advance for any help!
What could go wrong is offline   Reply With Quote
Old 03-10-2019, 02:19 PM   #2
What could go wrong
Member#: 448908
Any ideas?
Old 03-18-2019, 07:55 PM   #3
What could go wrong
Member#: 448908
Still haven't diagnosed it, problem occurs while steering right while the car is moving.
Old 03-18-2019, 08:05 PM   #4
El Jefe de Jefes
Member#: 497588
2020 el presidente
Red
Sway bars, bushings, lat links, strut mounts, spring seat, body panel flexing/rubbing, etc...
El Jefe de Jefes is offline   Reply With Quote
Old 03-18-2019, 08:39 PM   #5
What could go wrong
Member#: 448908
I figured, just hoping to narrow it down a bit more than that
I was hoping this was a known issue, but I guess not, thanks anyway!
Old 03-18-2019, 09:08 PM   #6
El Jefe de Jefes
Member#: 497588
2020 el presidente
Red
sorry man, too many variables. Get out a can of wd40 and spray part by part till you narrow down.
Old 03-25-2019, 06:45 AM   #7
Officrnaughty
Member#: 499526
2016 WRX limited
Dark Metallic Gray
curious are you on stock suspension or coilovers?
Officrnaughty is offline   Reply With Quote
Old 04-04-2019, 05:50 PM   #8
What could go wrong
Member#: 448908
Stock suspension... just trying to figure out what to check first for left right play, it's just weird
Old 04-06-2019, 12:07 PM   #9
WoodyBrain
Member#: 499171
2005 STi
With it only making noise while turning the wheel, I would start with looking at the upper strut mount. It has a bearing in a rubber bushing that allows the strut to rotate when the wheel is turned.
WoodyBrain is offline   Reply With Quote
