Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 02-12-2011, 11:29 PM   #26
Teh Police
Member#: 246204
My Subaru Forester
is White.
Im not saying your wife's knowledge of the size of the radiator means much. With such a small radiator and less cooling ability this car wouldn't make the best daily driver. Honestly, Id take the AC condenser out and put a bigger than average radiator in its place and slim fans between the fmic and the radiator. That seems like more of an appropriate setup for what you have going on.
Teh Police is offline   Reply With Quote
Old 02-12-2011, 11:51 PM   #27
SiFlyBy
Member#: 250910
She barely drives it, but there is the rare occasion. She will not, however, until I am completely satisfied that the cooling system is going to handle stop-and-go driving. Its hard to see with the bumper on, but there are 2 slimfans in between the FMIC and the condenser..I'm not crazy.
And I WILL NOT get rid of the A/C. Why? Because it shouldn't need to be done. I feel it is very sloppy to remove functional equipment in order to make modifications such as P/S and A/C. Done for weight resons, I understand, but not on a street car.
SiFlyBy is offline   Reply With Quote
Old 02-13-2011, 12:14 AM   #28
Teh Police
Member#: 246204
My Subaru Forester
is White.
No offense, Im not trying to argue with you, but you are significantly downsizing the most important part of the car. The radiator cools the motor. You are going with a bigger set up, but cutting your radiator in half? This wont be too great for daily driving and/or stop go traffic. The only reason I say that is because of what you just posted about thinking it sloppy to remove functional equipment.
You could have very easily had a stock mount or rotated mount big turbo set up but you chose front mounted. You have to realize turbos (especially big ones), arent designed to fit up there. When you go with that setup you have to choose between losing AC or radiator cooling efficiency. If your block overheats, hello new motor. Just saying.
Old 02-13-2011, 12:36 AM   #29
SiFlyBy
Member#: 250910
The fluid capacity of the new radiator is about the same as the stock one. It is half the width, but over twice the thickness.
Old 02-13-2011, 12:49 AM   #30
Teh Police
Member#: 246204
My Subaru Forester
is White.
oh okay, I would go bigger than stock capacity if at all possible.
Old 02-13-2011, 01:54 AM   #31
SiFlyBy
Member#: 250910
Its not possible....unless what I have can't keep up.
In that case, I think I will go with a water/air intercooler and that will make a lot of room up front for a proper radiator along with the IC radiator. I just don't have the cash for it right now.
I just found this tonight: http://www.frozenboost.com/index.php...f79bb2b6c94fdb
water/air is not as costly as I thought it would be and would very well decrease turbo lag by a signifigant amount.
Old 02-13-2011, 02:08 AM   #32
Teh Police
Member#: 246204
My Subaru Forester
is White.
If you go that route, you can turn your front mount into a heat exchanger by capping the ends off and putting a fitting for your water lines at each end. Then all your have to buy is the actual intercooler, water pump and lines and fittings. Let me know if you need help piecing a system together in the future.
Old 02-14-2011, 12:48 AM   #33
jakedademon
Member#: 157764
2002 '02 SZ55 hyb
2002 v9 EJ207 VF22 wagon
Turbo is going to produce a massive amount of heat. And it is 6 inches(?) from the rad? kudos for doing a custom setup, but a turbo at 300F-500F so close to the radiator who's cooling surface area is cut in half seems like a risky setup. Good luck with it.
jakedademon is offline   Reply With Quote
Old 02-15-2011, 06:15 PM   #34
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
Love this build, there needs to be more DIY guys in the subaru world.
perrin247 is offline   Reply With Quote
Old 02-16-2011, 05:28 AM   #35
oguitar
Member#: 206720
2002 WRX Wagon
It is also very close to the timing belt. I was wondering how heat might effect the strangth of the belt over time. A turbo blanket is being utilized so this might have been addressed already.
Good work on the build so far.
oguitar is offline   Reply With Quote
Old 02-16-2011, 10:01 AM   #36
SiFlyBy
Member#: 250910
The radiator is for a civic body, so 1.6L-2.2L engines. Mine is 2.0L. Look at any turbo civic and you will see turbo proximity very similar to what I have...hell alot of people run the DP right next to the radiator and wrap nothing. Every piece of exhaust pipe in the engine bay is wrapped except for the WG dump which is far from anything and only gets hot on occasion.
Old 02-26-2011, 10:50 PM   #37
SiFlyBy
Member#: 250910
Update:
Accessport is history and I am running very good on a Romraider SD rom. I have to say that tuning on RR was a little disappointing vs. AP as you have to flash/log/modify/flash/log/modify, etc.. instead of realtime tuning and adjustment, but the benefits of the SD rom far outwiegh litle thing like that. I have to say that looking at the HY35 and this BW S258 side-by-side, I was a little worried that it would spool slow as ****, but I am very pleased. This thing spools faster and hits much harder than the HY did. I'm sure that the manifold/length and cams help. I'm only running WG pressure now(15 psi) and its still puts down a raping that brings a large smile to my face. I'm gonna have to wait till it warms up here a little before I go any farther. The highs for the nex week are single digits, but after that I'll tune it up to ~24 psi and see how that feels.
Old 02-27-2011, 10:44 PM   #38
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Congrats on getting this together. I don't think you'll have a problem with the radiator, but if you do run into heating issoes just get a custom shroud for it (should be available off the shelf since it's an OEM Honda size) and put an electric fan on the engine bay side of it.
A-man07 is offline   Reply With Quote
Old 03-04-2011, 10:40 PM   #39
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
i love how u build custom turbo setup with a decently large turbo and all this other stuff.
But then are concerned about having to let the wife drive or carry your kid in the car.
just get a diff car for daily use lol. what its gonna put down.
not hating. just confused lol. its cool to be differant at a certain point.
but if that car just happens to be your daily that the wife drives and your kid rides in. my plans would be differant, thats all.
NW2TONE is offline   Reply With Quote
Old 03-05-2011, 12:39 PM   #40
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Looks like an awesome project.
bhhamblin is offline   Reply With Quote
Old 03-06-2011, 10:10 AM   #41
DarkKnightBaku
Member#: 199536
2018 WRX
nice looks goods!
DarkKnightBaku is offline   Reply With Quote
Old 04-13-2011, 10:15 AM   #42
SiFlyBy
Member#: 250910
I never had a concern of IF the cooling system would be sufficient. It was just a matter of what it would take to make it such. as the weather is getting warmer I have noticed that the engine does get warm driving slow and sitting for awhile running. So, I ditched the POS slimfan that I had and bought a flex-a-lite and moved it to the engine bay right behind the radiator. That sucker moves ALOT of air. I had to mostly redo the compressor inlet plumbing to make it fit. So far, no more overheating, but I still think that I may go with the water-to-air setup.
Old 04-15-2011, 05:27 PM   #43
Ozzy
Member#: 8774
1998 Impreza RS
Im building a similar setup to yours right now. I have a water-to-air in the place of the battery(and half way in the fender)...the radiator Im using is from a Jeep Cherokee with the inline 6...in front of the bumper beam. Kudo to you for keeping the A/C, I wasnt that creative, and space is at a premium with front mounted turbos as you know.
How is your timing cover holding up? This is my #1 worry at this point in my build.
Ozzy is offline   Reply With Quote
Old 04-16-2011, 08:58 AM   #44
SiFlyBy
Member#: 250910
It's looking more and more that I will have to change things...as it happens with these type of projects. What I'm going to do is put a water-to-air essentially where the radiator/charge piping now sit. For the radiator, I have some cores from 6.4L Ford diesels that are 2 3/4" thick and 37'' long. I'm going to cut to about 10" tall and build end tanks for and mount it where my intercooler sits now, in the front bumper.
My timing cover is golden so far. I spent money and bought what I thought was the best turbo blanket. Its from DEI and it seems to work VERY well. The actual turbine housing is over 1" from the condenser and the timing cover. I say spend the money on a good turbo blanket and you'll be good to go.
Oh, and get a build tread or something going...I want to see what you're doing.
Old 04-18-2011, 04:42 AM   #45
Ozzy
Member#: 8774
1998 Impreza RS
I will put a build thread up, but Im actually waiting until I get it almost finished to post it. My project has taken me too long and didnt want to be pushed along faster than I could afford to buy parts(without a credit card). I noticed your turbo blanket in the pictures above, that is the one that I was planning on buying. Im glad to hear that the plastic timing cover is holding up.
Your radiator plan should work well. Those dimensions are about the same size as my Jeep Cherokee radiator and it should be more than enough to cool the intercooler water. The volume of water in that radiator should be substantial. My car is a 98 Impreza rs and it fits the bumper skin opening and the bumper support. Should work well with your car too.
Im planning on using a radiator core from a water cooled 911 in the hood scoop for my intercooler heat exchanger.(I work at a Porsche shop and hoard all the damaged intercoolers and radiators)
I could PM or post a few pictures of my progress if you want.
Old 04-21-2011, 01:31 PM   #46
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
You may want to consider fabbing up a litle heat shield for the sake of the passenger side CV joint coming out of the tranny. It looks like your exhaust is very close to it. I cooked one of mine before the downpipe was wrapped.
The build looks great tho man. Good work!
Y_I_K_E_S is offline   Reply With Quote
Old 05-13-2011, 09:43 AM   #47
SiFlyBy
Member#: 250910
Everything is wrapped in the engine bay and there is sufficient clearance with the cv shaft.
Old 05-13-2011, 10:08 AM   #48
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Would there be any disadvantage to clocking the cold side downwards (aside from ground clearance), or was this way the shortest route to the intercooler?
NitroTrike is offline   Reply With Quote
Old 05-14-2011, 09:28 AM   #49
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
WOW! This looks great! Great DIY!
King of Poop is offline   Reply With Quote
Old 05-16-2011, 11:49 AM   #50
SiFlyBy
Member#: 250910
My IC outlets are at the top, so it was pretty much the shortest route for a FMIC...I am in the process of builing a radiator to put up front where the IC is now and will then go water-to-air and have the IC in the engine compartment where the radiator is now. And that will be the shortest route.
WTB : 02+ Wrx/04STi front drivers side hub Brando5185 AKIC Private Classifieds 1 01-31-2011 11:38 AM
WA: FS: ssac xs power 02-07 wrx/sti front mount intercooler kit gmulid Engine/Power/Exhaust 3 09-27-2007 03:35 PM
WTB: 02+ WRX/STi Front Strut Mounts and 02/03 Rear upper Mounts, Goodridge SS Brake L SoSube Private 'Wanted' Classifieds 3 07-19-2007 10:33 PM
spotted 02 wrx with front mount and carbon fiber hood railguy Mid Atlantic Impreza Club -- MAIC 0 01-14-2005 03:06 PM
