Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 08-01-2012, 01:20 PM   #1
chewbakarox
Member#: 25478
2003 WRX Sport Wagon
Default 03 WRX Cranks But Won't Start!
I have an '03 WRX with about 95,000 miles. Basic Stage 2 mods include UP, DP, intake, catback and Protune. It has been running perfectly for years when all of the sudden it wouldn't start this morning.
It cranks nicely so I don't think it's the battery or starter. But there is no other sound other than the starter (i.e., the engine doesn't even idle/stumble or anything). It just cranks and cranks and nothing happens. Driving home yesterday, I sensed something was off - the engine almost stalled once after letting off the accelerator but I didn't think much of it.
Again, I haven't modified anything in years so it's not a case of a faulty new part or incorrect installation. Can someone help me troubleshoot this and tell me what the most likely culprit is? How do I diagnose if this is a fuel issue, ignition issue, or otherwise? TIA.
chewbakarox is offline   Reply With Quote
Old 08-01-2012, 02:43 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Pull the fuel line from the fuel filter under the hood.
Hold the line in a bucket and have someone try to start the car.
If no fuel, then it's your fuel pump.
If fuel, reconnect fuel line and try again after the filter.
If no fuel, then it's your fuel filter.
Repeat again after the fuel pressure regulator.
If all is good (fuel), then yiou are getting fuel to the fuel rails so not the fuel system. It is possible you have a clogged fuel rail, so you may have to disconnect the fuel rail and try one more time.
Check your electrical connections to all your igniters. I highly doubt all your igniters went bad at once.
Samurai Jack is offline   Reply With Quote
Old 08-01-2012, 03:41 PM   #3
chewbakarox
Member#: 25478
Thank you much for the tip. Sounds like the fuel system is the most likely culprit. I will do some troubleshooting tonight and reply.
Old 08-01-2012, 10:41 PM   #4
chewbakarox
Member#: 25478
OK - I did a bit of troubleshooting. There is no fuel coming into the fuel filter. I also can no longer hear the fuel pump priming when I turn the key to the "on" position. So at least that narrows it down (I think?).
So now that the problem is focused on the fuel pump, do I assume I just need to replace the pump? Or could it be an electrical issue tied to the pump (like a relay or something)? TIA, the advice here is a lifesaver.
Old 08-02-2012, 12:14 AM   #5
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Easiest way to tell is test the various parts of the circuit with a multimeter
J.Gibbs is offline   Reply With Quote
Old 08-02-2012, 12:56 AM   #6
MarioAndretti
Member#: 199394
02 Impreza OBS
red
The first place to start is check all your fuses both in the dash and under the hood.I would hate to see you replace a fuel pump and have it still not work.
MarioAndretti is offline   Reply With Quote
Old 08-02-2012, 01:30 AM   #7
chewbakarox
Member#: 25478
I checked fuse #11 in the dash (ignition) but from what I have gathered here in the forum, I don't believe there is a fuse for the fuel pump, only a relay. If I am mistaken, someone please let me know which fuse to check please!!
Old 08-02-2012, 01:34 AM   #8
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
How about the clutch switch? Or does it not crank with a bad switch. Just a thought.
Old 08-02-2012, 01:55 AM   #9
chewbakarox
Member#: 25478
Yeah, it wouldn't even crank if there was a bad clutch switch. But thanks for the heads up!
Old 08-02-2012, 02:20 AM   #10
chewbakarox
Member#: 25478
OK, I am going to check for power at various points of the circuit. I am a noob with a multimeter - can someone explain where to start and what setting to use on the multimeter? I figure I should start at the wiring harness to the FP and work my way towards the FP relay and ECU?
Old 08-02-2012, 04:14 AM   #11
MarioAndretti
Member#: 199394
02 Impreza OBS
red
As a general rule everything electric in on a fused circuit somewhere in the system to prevent a fire or other damage in the event of a short.After a bit of searching I found that the large 30A fuse in the center row of the fuse box under the hood controls the fuel pump relay,main relay,engine control module and the data link connector.I believe it was SBF5.I have 3 such fuses in my 02 OBS(SBF5,6 and 8)and can be checked visually without removing them.
Old 08-02-2012, 12:25 PM   #12
chewbakarox
Member#: 25478
Hi Mario, I also was able to find this info and checked the SBF5 fuse last night. It was fine, so I think I can rule out a blown fuse as the culprit.
Old 08-03-2012, 02:44 AM   #13
chewbakarox
Member#: 25478
OK, did some digging tonight and got some weird results. Checked for power at the fuel pump harness, got nothing. Checked for power at the fuel pump controller harness, got nothing. Moved on to the fuel pump relay.......
I have 12V constant at pin #2. When turning the key 2 clicks to "on", I get about 1 volt at pin #1. So the ECM is sending something to the relay, but it is only 1 volt.....WTF? Does anyone know what this means? Please help!!
