Welcome to the North American Subaru Impreza Owners Club Friday November 22, 2019
Old 03-14-2013, 02:39 PM   #1
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Default 1/2" Air Line Regulator / Filter compatible with 1/4" Compressor outlet? Pics inside
Bought an air compressor wrongly listed as 1/2" outlet, in reality it is 1/4".
Thinking I was getting a 1/2" outlet compressor I bought a 1/2" air line regulator/filter. Will I have any issues?, ie, pressure drop due to large 1/2" internal in regulator/filter? Plan is to get a fitting reducer from 1/2" to 1/4".
1/4" Outlet Compressor
1/2" Filter/Regulator
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 03-14-2013, 04:26 PM   #2
PARANOID56
Member#: 22035
2014 Brocoma DCab
71 FJ40, 13 DRZ400SM
nope, you will be fine. just put a pipe reducer fitting on it and call it a day. i am surprised that there isnt a tank fitting you could come off of so you could use your 1/2" from that.
but on my 80ga 2stage setup the main line is 1/4" and i have a feed off the tank thats 1/2"
both seem to work great for everything i do at home, from air tools to plasma cutter.
PARANOID56 is offline   Reply With Quote
Old 03-14-2013, 08:15 PM   #3
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
I could replace the tank plug and replace with a 1/2" plug/nipple but I would also have to replace the switch box as it is 1/4".
Thanks for chiming in.
Old 03-14-2013, 11:43 PM   #4
PARANOID56
Member#: 22035
2014 Brocoma DCab
is there no plug on the side? if the only spot is where its allready hooked up. leave it at 1/4 and get a pipe adapter to fit your reg. then keep it at 1/2 the rest of the way.
Old 03-16-2013, 12:53 PM   #5
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Thank you, no side plug this is a 26gallon tank. ended up getting 1/2x1/4 adapters and hi-flow fittings (hi-flow offer 4x larger ID than conventional and are same as ID as the 1/4 compressor nipple).
Old 03-17-2013, 11:31 AM   #6
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Northern or Harbor Freight do not carry the hi-flow fittings (T type), found'em @Lowe's.
Old 03-18-2013, 01:04 PM   #7
PARANOID56
Member#: 22035
2014 Brocoma DCab
yea, and i would say stay away from the fittings at harbor freight. every one i have tried started to leak or leaked brand new
Old 03-18-2013, 10:44 PM   #8
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
too late pal, I bought the ****ty central pneumatic, pretty much everyone leaks, tried re-taping, retightening to no avail.
Which brand would you recommend that is decently priced? Milton's?
Old 03-19-2013, 03:10 PM   #9
PARANOID56
Member#: 22035
2014 Brocoma DCab
i dont. i have had semi good luck with ones from home depot. but i have a bunch of old ass ones i took out of a building i was demoing and kept a bunch. 30+ years old and no leaks
Old 03-19-2013, 11:43 PM   #10
flstffxe
Member#: 155358
2008 Forester
Steel Silver
SCHRADER TWIST-LOCK
By far my favorite coupler. Our entire shop is plumbed with these. No leaks, no unintended disconnects and high flow.
If you use these at home, you don't ever have to worry about some one using your air tools and not bringing them back. A adapter is nice to have made up and on hand when you do want to loan them out or use them else where.
Just be prepared to spend some cash if you need a bunch at first.
flstffxe is offline   Reply With Quote
