Welcome to the North American Subaru Impreza Owners Club Wednesday November 20, 2019
Old 09-09-2014, 11:55 PM   #951
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
xluben is offline   Reply With Quote
Old 09-10-2014, 01:01 PM   #952
2011rex18
Member#: 321728
2011 WRX Limited
Default xluben's 2002 WRX | NF Performance | 2.5L | 6MT | 500+WHP | 10sec 1/4 Mile
Looks like you were pulling on the gtr towards the end there nice runs man!
2011rex18 is offline   Reply With Quote
Old 09-10-2014, 01:28 PM   #953
mxblaster292
Member#: 357709
2010 wrx
red
Yea man looks like it pulls hard on the top end.
mxblaster292 is offline   Reply With Quote
Old 09-10-2014, 02:26 PM   #954
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yep, pulled 2 or 3 car lengths by the end of the 1/4.
Old 09-10-2014, 02:41 PM   #955
SDoBB
Member#: 335853
2013 WRX 5 Door
CBS
That car is hot like its on fire...
SDoBB is offline   Reply With Quote
Old 09-10-2014, 05:34 PM   #956
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Old 09-10-2014, 06:11 PM   #957
Smurftastic
Member#: 243697
17.4 PSI ECUtuned 02
BLOD Cofounder|TopScoob31
Planning to get slicks?
Smurftastic is offline   Reply With Quote
Old 09-12-2014, 04:34 PM   #958
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Maybe. I think I need axles first though....
PS. Someone hijacked my thread title!
Old 09-12-2014, 05:20 PM   #959
jnorth85
Member#: 76785
2000 700Whp The RSTI
SRP
I am so lost! hahahaah this thread title is killing my brain!
jnorth85 is offline   Reply With Quote
Old 09-12-2014, 05:24 PM   #960
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Lol. I asked for mine to be changed to this title and they did it for Ben's thread instead for some reason.
WRXt4cy is offline   Reply With Quote
Old 09-12-2014, 05:27 PM   #961
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Updated the first post!
Either of you guys make it to the strip yet?
Old 09-12-2014, 06:06 PM   #962
jnorth85
Member#: 76785
SRP
the 27th we will both be there
Old 09-12-2014, 06:11 PM   #963
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I have the 8374 tuned up to 25 psi. It's feeling very strong but starting to run out of fuel from the walbro 400 and FIC 2150's. I think I'll reach 27 to 28 psi maybe. Gonna get a big fuel lab pump and surge setup soon as I can but this trip to the drag strip will be on whatever it can make for now.
Old 09-12-2014, 06:36 PM   #964
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Should be making waaaay more power than me. What do you think it'll run?
Old 09-12-2014, 06:39 PM   #965
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
sounds like shootout!
SenorDucK is offline   Reply With Quote
Old 09-12-2014, 06:44 PM   #966
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I'll be on federal street tires and I'll need to hit 5th but I'd like to see mid 10s with an appropriate trap speed for my weight. I went 11.5 @ 119 on the Dom 3.5 at 24 psi through the GS TMIC.
Old 09-12-2014, 06:45 PM   #967
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Same tires as me and I also shifted 5th.
Old 09-12-2014, 06:49 PM   #968
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What did the Dom 3.5 Dyno and what does your new one dyno?
If you rev it out you can probably do 4th. The turbo should be able to do it.
Old 09-12-2014, 07:19 PM   #969
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
512 / 460 at 24 psi on the TMIC. Didn't dyno at full boost with the FMIC. Virtual dyno suggested 570 / 490 @ 30 psi tapering to 26.
I'm tuning some other cars on the dyno tomorrow including an 8374 LGT and a 7670 stroked EJ20 w/ jdm heads WRX. Might throw mine on and see where it's at but my setup is basically like the LGT so it's numbers should tell me a lot about what this turbo makes at xx boost. This turbo doesn't fall off at all out to 8000 with the 1.05 TS housing and EWG setup. 8000 in 4th gear seems to get me just a bit over 130 I think.
Old 09-12-2014, 08:12 PM   #970
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
512whp trapped 119mph so 570whp should do at least super 120's. Should be good for 10's.
Are you tapering boost on purpose? My baby size turbo holds 30psi flat to 8k. It actually rises about 1psi as it goes up.
PS. Title is fixed!
Old 09-12-2014, 09:06 PM   #971
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
PS. Title is fixed!
That boost was on the built motor with Dom 3.5. It had too much back pressure up top with the IWG. EWG probably would have helped but I didn't want to try that on that turbo and the 8374 came up for sale for the right price. The 8374 has shown no signs of tapering and doesn't need wastegate duty ramped to hold flat boost to 8k.
Old 09-12-2014, 09:15 PM   #972
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Oh I get it. It was 512 Dyno and 570 Virtual. I thought 570 was the new setup. What does that do on Virtual Dyno? Mine will barely do 500 on Virtual Dyno
Old 09-12-2014, 10:35 PM   #973
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
24 psi on the 8374 shows 580 so about the same and it feels like it's at about the same power at peak torque but it holds flatter to redline.
Old 09-12-2014, 10:39 PM   #974
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What are you going to run it at at the track?
Old 09-12-2014, 10:58 PM   #975
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I'm gonna keep going on boost until I'm out of fuel and run at that. Judging by where I'm at now I'm thinking 27 to 28 psi. I need to move my pressure sensor for oil to the fpr or get a second one on a switch so I can see what fuel pressure is doing. I need to see how much it's dropping. I'll run boost by gear and turn down 1st and 2nd to get traction if needed.
