Welcome to the North American Subaru Impreza Owners Club Monday November 18, 2019
Old 04-28-2014, 02:09 PM   #76
thill
Member#: 377200
18 Miata Club
Jet Black Mica
It would be interesting to see the front and rear bar specs for the STI. I would not be surprised if their rear bar is larger.
I know the Motortrend guys complained about moderate understeer with the 2015 WRX at the track, but said it was not an issue on canyon roads.
thill is offline   Reply With Quote
Old 04-28-2014, 02:10 PM   #77
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
I don't think it is but I'm not sure
Celery GT-5 is offline   Reply With Quote
Old 04-28-2014, 02:46 PM   #78
Gro Harlem
Member#: 165782
2015 WRX Limitd Stg2
'02 Stg4 & JSW TDI Stg2
UPDATE:
I edited post #2 to display requests/questions posted here that have yet to be answered. I'll remove them & add them to the knowledge base when we confirm them. 15 questions so far:
http://forums.nasioc.com/forums/show...01&postcount=2
Gro Harlem is offline   Reply With Quote
Old 04-28-2014, 03:01 PM   #79
Celery GT-5
Member#: 98210
Originally Posted by Gro Harlem View Post
UPDATE:
SPECS: 2015 SUBARU WRX STI
ENGINE 2.5L EJ25 BOXER, turbocharged/intercooled with SI-DRIVE Engine Performance Management system
POWER 305hp at 6,000rpm; 290lb-ft torque at 4,000rpm; 14.7psi max boost
DRIVETRAIN 6-speed manual with Symmetrical AWD and Driver Control Center Differential (DCCD); mechanical/electronic limited-slip center diff; helical limited-slip front diff; TORSEN limited-slip rear diff
SUSPENSION front inverted struts with 24mm stabilizer bar; rear double-wishbone with 20mm stabilizer
BRAKES Brembo Performance Brake System with 13 ventilated disc/4-piston calipers and 12.4 ventilated rear disc/2-piston calipers
WHEELS/TIRES 188.5 cast alloy (standard); 188.5 BBS forged alloy (Launch Edition and Limited models)
FUEL 17/23/19 (city/highway/combined mpg)
not sure if that's accurate or not
Old 04-28-2014, 03:03 PM   #80
JPelletier
Member#: 385166
2015 WRX Sport-Tech
World Rally Blue Pearl
UPDATE:
You can add: Trunk measurements, see http://forums.nasioc.com/forums/show....php?t=2624333
JPelletier is offline   Reply With Quote
Old 04-28-2014, 09:15 PM   #81
ECP
Member#: 280021
Awesome info! I added it to the knowledge base. I'll be disconnecting my resistor immediately when I get my car...WHICH IS AT 4PM TODAY can't wait!!!
Congrats and good luck! Taking me a bit to get accustomed to it coming from my '11 hatch. But I like all the amenities going from a base to Limited. Something tells me that I should have splurged for the STi though but time will tell
ECP is offline   Reply With Quote
Old 04-28-2014, 09:36 PM   #82
Representexas
Member#: 115350
2018 STI Type RA
I don't know if anyone has posted yet but can we add if the liscence plate delete and relocation kits will fit?
I want to order a relocation kit and the perrin delete plate that covers the factory holes before my plates get here.
Thanks!
Representexas is offline   Reply With Quote
Old 04-28-2014, 11:52 PM   #83
boost-o-matic
Member#: 248364
2010 Huevos grandes
WRX Dom 1.5XTR E85 silver
I gots a question...
Is the 2015 WRX 6spd STi derived or all new? Wondering if it has the same power handling characterstics of the STi tranny. If not the same, maybe it's more stout than the 5spd from last year?
boost-o-matic is offline   Reply With Quote
Old 04-28-2014, 11:53 PM   #84
Celery GT-5
Member#: 98210
people seem to think its the 10-12 LGT 6mt with carbon syncros on 1st and 2nd but I have no idea
Old 04-29-2014, 12:01 AM   #85
ThePupppet
Member#: 87384
2015 WRX
CWP
Factory Speaker depth limits for front & rear.
I already took the rear speakers out, working on installing a sub. I will try to get the answer to this tomorrow night.
Also interesting, it seems the fuel lines run from a grommet up by the brake booster through the firewall and along to door sill on the floor back to under the rear seat. That and the rear seat is really easy to take out.
ThePupppet is offline   Reply With Quote
Old 04-29-2014, 01:41 PM   #86
Diznario
Member#: 9179
2015 WRX Limited
Ice Silver
Word of warning about the fog lights - Subaru is not using a traditional H16 bulb although they are labeled as such. They look like an H11 bulb to me.
I bought a set of H16 LEDs for my shiny new 2015 WRX and when I went to install them I found out they're completely wrong. To make things more fun they're a total pain to access since you have to come in through the fender well.
I did a quick bit of searching, and it looks like Subaru has done this "H16" trickery before so it's not entirely new, just wish I knew ahead of time. Hopefully I can help someone else avoid the same trouble.
I now have a set of H9 LEDs on order, in hopes that those fit using the old H9 / H11 conversion trick. I'll report back if it works.
Diznario is offline   Reply With Quote
Old 04-29-2014, 02:17 PM   #87
quantum13
Member#: 389143
2015 WRX Limited
correct. this thread has a little more info on that and some pics - http://forums.nasioc.com/forums/show....php?t=2623864
quantum13 is offline   Reply With Quote
Old 04-29-2014, 09:43 PM   #88
BrownDog40
Member#: 357235
Has anyone purchased the Subaru WRX / STI Rear Quarter Under Spoiler? Looks like it would help prevent rocks from flying up from the back tires. Aftermarket flaps would be cheaper, and of course, looks are subjective ...
BrownDog40 is offline   Reply With Quote
Old 04-29-2014, 10:25 PM   #89
amr5387
Member#: 384088
2015 WRX
World rally blue
Hey everyone! I have a quick question, and I figured this would be the best place to find an answer. First off, I just purchased my 2015 WRX Base Model last night, and I can't stop driving it!
Today, I went to fool around with the multi-function and multi-information displays. I was able to scroll through the multi-function options just fine, but I couldn't seem to figure out how to use the multi-information display on the dash next to the speedometer. How do you get the digital speedometer and other options to display? I tried using the arrow buttons on the steering wheel, but nothing seemed to change.
Thanks!
amr5387 is offline   Reply With Quote
Old 04-29-2014, 10:30 PM   #90
thill
Member#: 377200
18 Miata Club
Jet Black Mica
Thanks!
Did you check the owners manual?
Old 04-29-2014, 10:40 PM   #91
Rigged
Member#: 259196
2015 WRX STI
WRBP
Hey everyone! I have a quick question, and I figured this would be the best place to find an answer. First off, I just purchased my 2015 WRX Base Model last night, and I can't stop driving it! Today, I went to fool around with the multi-function and multi-information displays. I was able to scroll through the multi-function options just fine, but I couldn't seem to figure out how to use the multi-information display on the dash next to the speedometer. How do you get the digital speedometer and other options to display? I tried using the arrow buttons on the steering wheel, but nothing seemed to change. Thanks!
There are three pull style levers on the bottom left behind the steering wheel that change the display. You have to pull the lever not push it.
Rigged is offline   Reply With Quote
Old 04-29-2014, 10:45 PM   #92
amr5387
Member#: 384088
2015 WRX
World rally blue
I did. The way it was worded made it seem like the options could be selected simply by pressing the up and down arrows on the steering wheel next to the volume controls for the radio. Nothing happened when I tried this in my car.
Old 04-29-2014, 10:50 PM   #93
amr5387
Member#: 384088
2015 WRX
World rally blue
Thanks! I didn't even see those levers. I got it to work now!
Old 04-29-2014, 11:03 PM   #94
PKILLA81
Member#: 388247
2015 WRX Premium
PIAA H16 bulbs fit. I installed them with no issues
PKILLA81 is offline   Reply With Quote
Old 04-30-2014, 02:23 AM   #95
Celery GT-5
Member#: 98210
Old 04-30-2014, 07:44 AM   #96
bluesmobile440
Member#: 247485
2006 WRX TR
I believe it is based off the Forester 6 sp
bluesmobile440 is offline   Reply With Quote
Old 04-30-2014, 12:00 PM   #97
sc00by4life
Member#: 97135
It's the legacy 6 speed..forester XT hasn't had a manual option since 2008.
Old 04-30-2014, 12:11 PM   #98
Celery GT-5
Member#: 98210
base forester, not xt
Old 04-30-2014, 12:15 PM   #99
Celery GT-5
Member#: 98210
this is the lgt tranny
maybe someone can take some comparison shots
Old 04-30-2014, 12:30 PM   #100
epv
Member#: 381966
2015 WRX
Originally Posted by SoapBox View Post
Go into a parking lot, lock the wheel in one direction and floor it.
You're not going to get understeer until you break traction, by definition. You have to be in a real hurry for that be be occurring on the street.
Obviously. I could push my '09 Rabbit into understeer easily on the street, 195s and FWD will do that. My point is that unless you're autoxing or something you don't need to give up any ride quality in the '15 WRX since the handling is so strong already.
epv is offline   Reply With Quote
