Welcome to the North American Subaru Impreza Owners Club Thursday November 14, 2019
Old 11-04-2015, 09:59 PM   #1
X49
Member#: 386600
2015 WRX
Default 2015 WRX Blower Fan Noise
2015 WRX. When my blower fan is on a low speed setting, it makes a consistent fluttering/whining noise. It has always done this. It isn't that loud, but it is loud enough that I can hear it over normal road noise. I would think that at the lowest setting, I shouldn't be able to hear the fan at all. Is this normal? I don't want to bother bringing it to the dealer unless I know its abnormal and will be fixed.
X49 is offline   Reply With Quote
Old 11-05-2015, 11:05 AM   #2
Berkalurk
Member#: 411010
2015 WRX
Maybe try posting this in the 2015 defects thread? Maybe someone will have an answer there. My personal experience with both the 15 and the 16 is that the blower is noisy at low settings so this might be "normal" for the platform but I'm not 100% sure.
Berkalurk is offline   Reply With Quote
Old 11-05-2015, 04:22 PM   #3
Mitchwrxpaps
Member#: 415635
2016 WRX Limited 6MT
Lapis Blue Pearl
Its normal, mine is noisy too. unless yours is obnoxiously noisy
Mitchwrxpaps is offline   Reply With Quote
Old 11-05-2015, 04:55 PM   #4
satriani1
Member#: 432721
2016 WRX Premium 6MT
Mine is quiet. Cant hear it driving while on low. A 'fluttering" noise sounds as if something might be hitting the fan. I'd probably pop it out and have a look since its right there under the glove box but that's me. Bob
satriani1 is offline   Reply With Quote
Old 12-14-2015, 11:40 PM   #5
obiwantoby
Member#: 428773
2018 WRX Limited
WR Blue
Default WRX Fan Noise Solution
Wife's WRX also had this same fluttering/whining noise. It was very noticeable to the both of us, and we could hear it when the fans were on low, just like you could. I took it to the dealership who listened to the fan and told me it was normal. They even pulled out another '16 WRX and it also made the same noise.
After that, I did some research and decided to try out ordering this crosstrek blower motor cover, and...it's a perfect fit. Now the noise is inaudible! Well worth the $30 we spent on the part.
http://subaruonlineparts.com/subaru-...er-p-3064.html
http://parts.subaru.com/p/UNDER-COVE...6066FJ010.html
obiwantoby is offline   Reply With Quote
Old 03-29-2016, 02:27 PM   #6
FirstAidKId
Member#: 442435
Wondering if this part fits 2013 impreza as well.
FirstAidKId is offline   Reply With Quote
Old 06-15-2016, 01:17 AM   #7
hekler
Member#: 388366
2016 SUBARU WRX(cvt)
CBS w/eyesight
This is a good topic. I just ordered a shroud cover from Subispeed before I saw this post....
http://www.subispeed.com/2015-subaru...i#.V2DWaq_2bX4
hekler is offline   Reply With Quote
Old 08-08-2016, 09:01 AM   #8
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
Bump.
Installed the cover yesterday. Took less than 5 mins. Direct fit.
I used 3 of those clips, as the one the cover comes with is a little flimsy.
Fit and finish is excellent. This cover should have been there from the factory.
vapore0n is offline   Reply With Quote
Old 08-08-2016, 09:07 AM   #9
n2oiroc
Member#: 141952
18 golf arrrr!
i have no idea how you guys can hear the blower motor over the exhaust and rattles.
n2oiroc is offline   Reply With Quote
Old 12-12-2016, 08:39 PM   #10
SixSpeeder
Member#: 455581
2016 WRX Limited
I installed the cover earlier today, but I have the OEM interior illumination kit (footwell lights) so I had to remove the light before installing the cover and loop it through an existing hole in the cover, then I remounted the light with some 3m double sided tape cut to size. It's a noticeable improvement, there's no more rattling/whirling sound when running the fan, just the sound of air coming out of the vents like a normal car.
Sorry about the subpar quality installed pic, it was dark by the time I got back from the store with double sided tape:
SixSpeeder is offline   Reply With Quote
Old 12-16-2016, 08:14 PM   #11
NorM15
Member#: 451904
15 WRX
Cw
Very true.
Wrx seams a little louder than the OB. IMO/ I wouldn't worry about it.
NorM15 is offline   Reply With Quote
Old 01-27-2017, 03:29 PM   #12
fishfangs
Member#: 425438
2015 WRX
ISM
Just installed the cover last weekend as the whine was getting annoying. After installation a rattle was introduced from the motor cables hitting the cover. To address that, I used some camper seal foam tape from Lowes on the bottom right corner of the cover as pictured above, between the corner of the insulation and the corner of the cover itself. Works great!
fishfangs is offline   Reply With Quote
Old 02-11-2017, 05:49 PM   #13
dchow
Member#: 453751
Great thread!
dchow is offline   Reply With Quote
Old 11-10-2017, 03:19 PM   #14
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Great thread. I was just wondering if there are ways to cut that noise down. It's not annoying but I would like to not hear it.
jasonwrx86 is offline   Reply With Quote
Old 02-24-2018, 03:28 PM   #15
nine5raptor
Member#: 473534
15 WRX Prem. w/ HK
CWP
2015 WRX. Gonna check this out. My fan is louder on setting one than my muffler deletes and HK stereo set on 17.
nine5raptor is offline   Reply With Quote
Old 09-27-2019, 06:07 PM   #16
Jmgrande
Member#: 456851
Not to dig up an old thread, but my 2017 STI had that annoying whine sound. I bought the fix pack from SubiSpeed, but havenít installed it yet. My car is coming off the 3 year/36k warranty so I brought it in to my local dealer to see what they would say. The tech heard the sound and replaced it under warranty! No more annoying whine sound when the fan is low.
Jmgrande is offline   Reply With Quote
