Welcome to the North American Subaru Impreza Owners Club Monday November 18, 2019
Old 01-11-2018, 10:31 AM   #1
cegan09
Member#: 302222
2016 WRX
Default Other Maintenance to do along with head gaskets?
my 135k mile 2012 WRX needs head gaskets. I'm trying to think of other smart things to do while I have the engine out. I'm not looking for mods or power adders, the car is stock and will stay that way.
So far I have
- pcv valve
- turbo oil filter/screen
- check clutch
- replacing most of the exhaust hardware
Anything Else I should be doing while the engine is out?
cegan09 is offline   Reply With Quote
Old 01-11-2018, 04:15 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
spark plugs? they're easier to do w/the engine out.
Old 01-11-2018, 05:51 PM   #3
rubmetoasty
Member#: 427123
2008 WRX
i recommend replacing any brittle vacuum lines, mine were rock hard on my 08 @ 115k. Especially the ones on the passenger side of the engine, from the turbo heat.
Even removing most of them caused them to break, also had a leak on a few of them even though they looked ok, when i started pulling i could see they had split along the bottom.
rubmetoasty is offline   Reply With Quote
Old 01-12-2018, 02:02 AM   #4
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
The most obvious is all the timing components and water pump. What exhaust items would you need to replace besides gaskets?
ThinWRX is online now   Reply With Quote
Old 01-12-2018, 05:02 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
You're way better off reusing the original water pump than putting a cheap aftermarket replacement on.
And you should just go ahead and replace the clutch, save yourself a bunch of labor in the not too distant future.
CosmoTheCat is offline   Reply With Quote
Old 01-12-2018, 10:07 AM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Gaskets/seals like rear main, valve covers, cam and crank.
Check valve adjustment.
Check to see if your engine has a history of cracked oil pickup tubes.
Rubber hoses like cooling hoses.
Old 01-13-2018, 08:40 PM   #7
cegan09
Member#: 302222
2016 WRX
Spark plugs I did roughly 10k miles ago, so I'll leave those alone. When I did the timing belt at ~95k I also did the water pump (used subaru OEM), so I think that's ok.
My clutch was done at 30k under warranty (bad throw out bearing), if it's toast after 100k I'll have to hit myself for sucking that bad. But I'll inspect it.
Vacuum lines are a great idea, thank you.
Exhaust hardware i'm referring to is all the bolts/nuts. New England car so that stuff rusts up bad.
I bought a whole gasket kit, everything from valve cover to main seals to valve seals. I'll be replacing everything I can during the process.
Thanks for all the suggestions.
Old 01-14-2018, 06:01 AM   #8
CosmoTheCat
Member#: 3409
98 My FMIC
If it's still got considerable life left after 100k you're ahead of 99% of the rest of the world.
Old 01-21-2018, 09:20 PM   #9
cegan09
Member#: 302222
2016 WRX
So I'm curious, why does most of the subaru community think that a clutch is done at 100k? I got the engine out today and took a look, there's enough material left to go another 50k-80k on the disk. It has some wear, yes, but not enough to consider it end of life. I'm certainly not a saint when it comes to my clutch treatment either. I ordered a new one to install anyway because the money was worth not dropping the transmission later, but looking at it I really don't need to be replacing it now.
in my family we've had several cars go 200k+ on the stock clutch (admittedly not subarus) Hell, the clutch we pulled from my dad's 254k mile saab looked in better condition than my subaru clutch. I'm just curious why 100k is the accepted lifespan of a clutch disk.
Old 01-22-2018, 03:38 AM   #10
CosmoTheCat
Member#: 3409
98 My FMIC
Because we've all seen a bunch of kids need a new clutch at 10k miles.
Old 01-22-2018, 10:37 AM   #11
cegan09
Member#: 302222
2016 WRX
Lol, fair.
Old 01-24-2018, 05:19 AM   #12
CosmoTheCat
Member#: 3409
98 My FMIC
The auto group I used to work for sold an SRT-4 to a kid back when they were new. They put a new clutch in at I believe they said it was 7 miles. Seven. He didn't make it out of town.
Old 01-26-2018, 06:09 PM   #13
AZP Installs
Member#: 40160
Timing Belt Kit (water pump, idler pulleys, belt, tensioner, thermostat)
Clutch if it hasn't been done recently
Plugs
Everyone else has pretty much hit on the major items.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 09-20-2018, 04:07 PM   #14
zebnoyd
Member#: 491671
2009 Impreza Outback
Default Reccomendation
What other things would you do for an automatic car? I have leaking head gaskets in my 2009 Impreza. I have read a couple of threads that suggest pulling the whole engine, are there any other gaskets that tend to leak? oil pan? Have you tried to do the head gaskets with the engine in the car?
Thanks
zebnoyd is offline   Reply With Quote
Old 09-20-2018, 05:01 PM   #15
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Thanks
Other than clutch, obviously, check/do everything else listed if it's due or close to it.
Can you do HG's engine in car?
Yep.
Have I/do I want to?
Nope.
I think worse is a DOHC (like mine), but not a lot of room.
Clean engine and bay, jack it up, likely loosen motor mounts & pitch stop so you can jack engine up and push to one side.
Old 09-20-2018, 05:08 PM   #16
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
You're NA, hand tools, floor jack, engine hoist, I can have the engine out in under 2 hours (unbolt the torque converter early on and leave it in the trans).
Then easy to work on.
Yours is 9 years old. Some items (belts and hoses) have both time and miles limits.
Other things are just time, or just miles.
How many miles on it?
Old 09-27-2018, 04:03 AM   #17
CosmoTheCat
Member#: 3409
98 My FMIC
Unless someone is in a pinch for money, I pull the motor and do a complete reseal when I do them at home. You can do them in-car, but a) you're not doing the rear main, baffle plate, etc and b) you run the risk of denting your ever-so-thin fenders from leaning over them.
Old 10-25-2018, 11:40 PM   #18
aharris42
Member#: 493203
Check for bad or old vacuum hoses, tiny cracks or leaks can cause a huge problem and can be a pain to fix. I'm going through the game of fixing one leak and finding another.
aharris42 is offline   Reply With Quote
Old 11-04-2018, 04:40 PM   #19
Rapsicurio
Member#: 487439
1999 Impreza RS
Oil pan gasket and valve cover gaskets, might as well do them while it's easy. Also, it helps that they're cheap.
Rapsicurio is offline   Reply With Quote
Old 10-11-2019, 10:29 PM   #20
Jroc1360
Member#: 507308
I have an 08” Impreza 2.5i and when pulling the heads I noticed the drivers side head had 2 valves still open even when everything was set to TDC. Passenger side valves were all closed. Is this normal? I could see them open through the intake ports so I rotated the motor 2 full rotation back to TDC again with the same results.
Jroc1360 is offline   Reply With Quote
Old 10-14-2019, 02:19 PM   #21
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
You sure it was TDC? Subaru timing marks line up with the pistons halfway. And the SOHC has the driver side cam under load when setting timing.
Old 10-16-2019, 03:47 AM   #22
CosmoTheCat
Member#: 3409
98 My FMIC
Yeah it's not TDC. You never do anything at TDC with Subarus except leakdown tests.
