Tire & Wheel Forum sponsored by The Tire Rack |
08-04-2013, 03:29 PM | #2176 |
scammer
Member#: 343232
TXIC
Vehicle:2012 WRX 5DR DGM |
I just got brembos and need to run 5mm spacers in front. Is it ok to have spacers only in the fronts or do I need to put 2 in the rear as well.
08-05-2013, 06:08 PM | #2177 |
Member#: 329268
Vehicle:2006 WRX Wagon WRB |
Never mind, I found the right thread and moved the post over there...
08-09-2013, 10:38 AM | #2178 |
Member#: 94299
Vehicle:2000 2.5 RS Sedan SRP |
Guys I have a 2000 2.5rs.
Was gonna get a set of steel wheels & tires from discount tire but the offset on their universal steel wheels is +41. The car is my daily. Reaching 100K miles. Is it safe to assume that this offset is not bearing friendly. In addition, the steel wheel is lug centric, not my favorite choice. Tire rack has a steel wheel with +50 with the correct bore which is much better but due to shipping the set will be $100 more. Opinions. |
08-13-2013, 08:50 PM | #2179 |
Member#: 155658
TXIC
Vehicle:2010 WRX Sedan WRB |
I have a 2010 wrx sedan with stock wheels and 225/45-17 tires. Just did Sprint Sport springs. I'm looking to get Enkei RPF1s in either 17x7.5 or 17x8. The front fenders have about half the lip trimmed by the previous owner. Any idea if the 8in wide wheels will rub? Looks like I've got a bit of room to work with but would rather be sure ahead of time. As far as I know the offset is 48mm for the 7.5 and 45mm for the 8 in.
08-16-2013, 08:00 AM | #2180 |
Member#: 155658
TXIC
Nobody has any experience with this wheel size? Also I will roll my fenders if need be. I'd really like the 8in wide wheels.
08-16-2013, 06:33 PM | #2181 |
Member#: 365651
It might be posted in here somewhere, but what if I want to fit wider than 8''? Correct me if I'm wrong but the stock wheels are 17x8 offset of 53? Whats the recommended offset for a wheel thats 9 or 10 '' wide?
08-17-2013, 11:05 AM | #2182 | |
Member#: 234357
Vehicle:2009 WRX Sportwagen zum einbauen! |
08-17-2013, 11:06 AM | #2183 |
Member#: 234357
Stock wheels come in a variety of sizes. Need to know what you drive to answer any questions at all.
08-17-2013, 11:42 AM | #2184 |
Member#: 155658
TXIC
Thanks man. There's a awesome group buy right now but they're 17x9 with 38mm offset. Think that might be pushin it lol
08-17-2013, 12:41 PM | #2185 |
Member#: 365651
It's a 2013 wrx sedan, I'm looking to fit new rims but I want to go wider than the stock one, I'm assuming this will help performance, although some people have been telling me that wider tires will make the steering sloppy and is isnt worth the extra grip. This is my first all wheel drive so I'm somewhat in the dark compared to the cars/trucks I've worked on. The car will be lowered next summer, which is around the same time I plan on getting new wheels.
08-19-2013, 12:55 AM | #2186 |
Member#: 234357
For the 'widebody' WRX's ('11 - '13) A pretty common fitment is 18x9.5 +38mm Running like 255's or 265 tires. That is fairly agressive though and I don't know what fender work (if any) it takes to run a setup like that.
And yes, stock wheel size on those is 17x8 (+53 or +55, can't ever remember) |
08-19-2013, 02:48 AM | #2187 |
Member#: 361948
International
Vehicle:2009 Impreza GT Sorta like.. Gunmetal |
will the stock wheels for the widebody wrx's (11'-13') fit on the 08 and 09 sedans?
08-20-2013, 12:19 AM | #2188 |
Member#: 234357
08-21-2013, 03:01 PM | #2189 |
Member#: 204690
RMIC
Vehicle:1992 Turbo Wagon dead red |
My head hurts from trying to figure this out.
So say I'm going for a very aggressive look on a swapped GC. I'm ordering diamond racing steelies in a 17x10. What offset do I need? |
08-30-2013, 11:12 PM | #2190 | |
Member#: 366943
Vehicle:2012 Impreza 5-door DGM |
17x9 +42 2012 Impreza
my 2012 impreza hatch is running stock 17x7 +48 with stock 205/50R17 tires and I was considering 17x9 +42 with 215/45/17. I didn't see the 9" width listed on the chart so how would this swap affect me? From what I've been reading, the +42 offset would probably not rub BUT the 9" wide wheel I have no idea about especially in the steering clearance? And then the issues of load and bearings makes me wary... A bit of help please! So doing more research I see that with the 17x9 wheel/tire combo,
What's the wheel well clearance on my model Subie??? Bueller Bueller? Last edited by forgedcbuser; 08-31-2013 at 01:03 AM. Reason: new info found |
09-01-2013, 05:23 AM | #2191 |
Member#: 366943
Anyone with advice on this setup?
Will I have any issues with the inner wheel well...especially with sharp turns? |
09-01-2013, 08:51 AM | #2192 |
Member#: 366626
will these fit
Bolt Pattern: 5x100 Offset: 48 Finish: Satin Black w/Machined Lip Stripe Back Spacing: 6.39 Product Weight : 24.00 Load Range: 1580 Hub Bore: 72.6 MFG Part# : MR12278051748 2012 wrx hatch |
09-03-2013, 10:34 AM | #2193 |
Member#: 234357
09-03-2013, 05:38 PM | #2194 |
Member#: 366626
Thank You
09-09-2013, 01:41 PM | #2195 | |
Member#: 292096
Vehicle:2011 WRX Sedan Dark Grey Sexiness! |
09-09-2013, 01:43 PM | #2196 |
Member#: 292096
09-10-2013, 01:30 PM | #2197 |
Member#: 366943
forget the 215's for the 17x9...way too much stretch. thinking about 235/40/17...will that get me to stock impreza height? or should I go 235/45/17?
09-20-2013, 06:13 PM | #2198 |
Member#: 285515
Vehicle:2011 wrx sedan black |
Asked this in a diff thread but then i noticed this would be a better thread to post it in.
Looking into the Ray's 57 Xtreme wheel. was planning to go with 18x9.5 complety clueless about this offset situation. I do want a concave look, something crazy but nto TOOO crazy lol. I have a buddy with rota grids 18x10 +35 off set, but that wheel has a lip. Work makes a similar wheel to the 57xtremes, THe work Emotion Work Emotion CR-KAI. I know alot of people have the wheels on the 08+ wry/sti's Any help with offset specs on those. It is the closet wheel i cant find that looks simials to the CR-KAI's. I'm not looking for a super thing extra tire looks, I'm looking for a meaty, but not to meaty stance if you know what i mean. I do know offset descions are a bit confusing. Would greatly aprreciate the help. I am running 25mm spacers on the rear and 15mm spacers on the front with the stock wrx limited bbs spider spoke wheels. I love the fitment with spacer and my ride height. If have to camber the wheels a tad bit but im not going to crazy with my camber, the wrx is daily driven in the ****ty roads of jersey and nyc. Please give me some tips/help/ and advice i would greatly appreciate it!!! If you have pics of people wiht the CR-KAI's that would be nice. |
09-20-2013, 06:15 PM | #2199 |
Member#: 285515
09-20-2013, 06:19 PM | #2200 | |
Member#: 285515
lol that was funny why look cool when you can do both with just taking the time out and asking the right people. Form and Funtion is must with a subi any subi...otherwise whats the point of having a beast like that |
Can we correct "The Offset Information Thread"? | Portly | Tire & Wheel | 20 | 12-14-2015 06:51 PM |
So I read the Offset thread... | Dracon | Tire & Wheel | 6 | 11-18-2012 04:39 AM |
The Hella Flush Information Thread | Impreza2.5i-Kid | Tire & Wheel | 16 | 08-23-2010 08:33 AM |
The end all 6 speed swap information thread | DS1 | Transmission (AT/MT) & Driveline | 156 | 11-14-2009 08:21 PM |
The Header Information Thread | imposter | Normally Aspirated Powertrain | 315 | 04-25-2003 02:59 PM |
