Welcome to the North American Subaru Impreza Owners Club Thursday June 24, 2021
Old 03-26-2021, 04:47 PM   #51
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
Originally Posted by silversurfer05 View Post
Great gains. 50+ hp/tq everywhere after full boost. Prob another 20-30 with the housing upgrade too
Realistically the housing upgrade might not even be needed for 700whp, kept boost target at the same 31psi... Past 6600rpm you can tell there's a gradual drop, which is to keep fuel pressure consistent.
But lets keep in mind that the number is corrected, and on a relatively high reading dynojet. The DW Brushless pump is rated for 750crank hp, so that's probably around where I am at.
PotatoFlakeSTi is offline   Reply With Quote
Old 03-28-2021, 10:22 AM   #52
silvercookie
Member#: 180033
2005 WRX
Didnt realize i follow you on IG. Just saw your post this morning. Upload the video.
silvercookie is offline   Reply With Quote
Old 04-06-2021, 01:31 PM   #53
pigboat_2
Member#: 247823
2006 Fxt
RBP
Let's meet up at Cryotune for a dyno run sometime.
pigboat_2 is offline   Reply With Quote
Old 04-06-2021, 01:38 PM   #54
K3rm1tth3fr0g
Member#: 508105
2002 Black WRX Wagon
VF39 + 4.44 5MT
Damn! 670WHP on a stage 2.5 Block
K3rm1tth3fr0g is offline   Reply With Quote
Old 04-06-2021, 02:30 PM   #55
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
We talked about this
I should be getting to Bandimere some time soon (probably not on decent tires though) so we can look at MPH as an indicator of 'true' power.
Old 04-06-2021, 03:21 PM   #56
pigboat_2
Member#: 247823
2006 Fxt
RBP
Yeah, but I actually would love to see a direct comparison. I had half a mind to dyno at Cryotune and Mofab in the same day. It would be cool to do it with another car or two.
I could be talked into Bandimere. I don't practice launches much though.
Old 04-06-2021, 06:00 PM   #57
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
I'll let you know if Cryo is ever in the cards for me.
At the dragstip MPH should be a pretty good power indicator regardless of your 1/4mile time, so the launch isn't super important.
That said - I've found that high launch rpm and just dumping the clutch to make SURE it breaks a bit of traction to be ideal... Less chance of catastrophic driveline shock if the tires are spinning.
Old 05-06-2021, 11:33 AM   #58
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
Got her to Bandimere but was having a nasty issue with a fuel cut in 1st on every run.
Best I managed was a 11.48 @ 129MPH with a 2.27 60ft - Density Altitude was about 13000ft that day
My previous 60fts were in the 1.6-1.8 range, hope to have it sorted next week.
Edit: Today on the street w/ cold tires, using a Dragy GPS, I managed an 1.98 60ft and a 1/8th mile 0.2 quicker and 2 mph faster that I did on the 1/4 mile run.
Not sure how that would translate to 1/4mile, but there's easy potential for 10's @ 130mph.
Old 05-27-2021, 03:33 PM   #59
Lee_WRX01
Member#: 324566
2002 DCCD Bugeye STI
You should be going .83 or 1.01 on a 2.0L for sure.
Thanks for the info, ended up buying the 0.83...yet to fit it. What size hot side and cold side pipes you running?
My plan is 2 inch from turbo to cooler and 2.5 inch from cooler to throttle. Im running a 4 inch front mount treadstone.Also running a ported 2.5 NA intake.
Lee_WRX01 is offline   Reply With Quote
Old 05-28-2021, 05:13 PM   #60
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Yeah 129-130 will crack 10's without doing anything special driver wise. What's you launch routine? I find that for my car it likes a slight slip to engage then a dump the last 2/3's of the peddle throw from the 6,000-6,500rpm range depending on traction.
Scuby04STi is offline   Reply With Quote
Old 06-01-2021, 12:03 PM   #61
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
Well, the thing I've found to work with this new clutch/turbo setup is launching at ~6250, unfortunately I can't really "peddle"(pedal?) this ceramic twin disc, it's either on or off....
So for the 'best' street launch, which bettered the track launch, I set the Driving mode to S (~20psi) launch and feather the gas trying to retain traction, slap it into S# (~32psi) as the car is moving, which seems to be preventing hitting the rev limit so hard that it was fuel cutting.
It seems launching it in S#, no matter how much I try to "peddle" it, it's like hitting a brick wall.
I should be able to get back to the drag strip in about 2-3 weeks, and give that procedure a go with better grip.
Old 06-01-2021, 12:04 PM   #62
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
I'm running an ETS FMIC with MoFab piping on the hotside.
Old 06-01-2021, 01:20 PM   #63
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
I "think" we have the same Comp Clutch twin disk, when I said slip to engage I mean once it actually starts to engage the clutch then I just dump the rest of the way so the clutch never actually is being asked to slip, just helps with not upsetting the car in how you get to the point of engagement.
Once that all happens I let the tires spin through 1st then hit second quickly, it has gotten me extremely consistent 1.48-1.52 60' times (no slicks stock air pressure).
Be nice to see what it will do with a whole 1/4 all put together with a solid launch.
Old 06-01-2021, 09:25 PM   #64
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
I'm actually running an XClutch now. I'll give a few different ways a try when I get to the track next! I appreciate the advice.
Old 06-02-2021, 12:17 AM   #65
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
Oooooo Iíve been looking at those, how does the pedal feel and what is engagement like? I heard they hold some serious torque
silversurfer05 is offline   Reply With Quote
Old 06-02-2021, 02:38 PM   #66
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
Oooooo I've been looking at those, how does the pedal feel and what is engagement like? I heard they hold some serious torque
Pedal feel is near OEM, engagement is pretty brutal and you basically have to rev it near 2500 or it'll catch so hard she stalls.
Discs are also very noisy when disengaged, but that doesn't really bother me.
Old 06-09-2021, 01:16 PM   #67
Lee_WRX01
Member#: 324566
Any idea what size piping that is on hot side and cold side?
Old 06-10-2021, 04:17 PM   #68
silversurfer05
Member#: 366241
Dgm
I appreciate the honest input. Engagement is really that rough?(zero slip)
Old 06-10-2021, 04:23 PM   #69
Waddlz
Member#: 395275
2012 STi
I really like the comp MPC I have, Organic twin disc. It engages extremely low is my only complaint, but the pedal feel is like stock and its quiet. I dont hear anything from it
I haven't taken it to Bandi to test it, but its much easier to drive than my Exedy Stage 1 HD clutch.
Waddlz is offline   Reply With Quote
Old 06-11-2021, 04:25 PM   #70
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
It's gotten a little better after driving it more - but trying to slip the clutch at all lets you to feel every 'puck' trying to aggressively engage.
Old 06-11-2021, 04:35 PM   #71
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
Yeah my Comp Multi Disc felt like stock too.
