Welcome to the North American Subaru Impreza Owners Club Monday September 27, 2021
Old 06-09-2021, 11:14 PM   #1
UltimatumPerformanc
Member#: 524766
Default Best ej25 block that is compatible with ej22e heads?
Building a Franken and was wondering which is going to be the most durable bottom end for a moderately boosted build. Not looking for insane power just enough to enjoy the car and have a fun daily. My other question is if going with my current non-interference heads will my setup still be non-interference?
UltimatumPerformanc is offline   Reply With Quote
Old 06-22-2021, 05:33 PM   #2
SoCoNoHa
Member#: 478524
1995 EZ30 Coupe
Green
You're going the wrong way for boost. 22 heads on a 25 block gets you high compression with poor flowing heads. Decent low end for off-roading and such but bad for boost.
I can personally attest that a 22e bottom end with 25d heads will LOVE some boost if you can tune for it. I ran 18psi from a td04 for a while in my coupe, it was a blast.
That said, if you're dead set, sti (257) is the best you'll get from Subaru, after that you're gonna spend serious coin on an aftermarket block with forged internals, closed deck, etc.
SoCoNoHa is offline   Reply With Quote
Old 06-22-2021, 05:51 PM   #3
K3rm1tth3fr0g
Member#: 508105
2002 Black WRX Wagon
VF39 + 4.44 5MT
2.5 Type RA is best shortblock from Subaru you can buy new today.
You can obviously build a forged motor, but at that point you might as well use good flowing heads....
Research is your best friend.
K3rm1tth3fr0g is online now   Reply With Quote
Old 06-23-2021, 04:59 PM   #4
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Originally Posted by K3rm1tth3fr0g View Post
Type RA is best shortblock from Subaru...
1993 WRX Type-RA closed deck w/ oil squirters EJ20G (the block used in all WRC/NBR24 engines) or the 2019 STI Type-RA open deck EJ257?
(<--- EJ20G owner...)
car_freak85 is offline   Reply With Quote
Old 06-24-2021, 08:01 PM   #5
SoCoNoHa
Member#: 478524
1995 EZ30 Coupe
Green
I'm partial to the ej22t block myself. Closed deck, oil squirters, and an extra 200cc. Slap some real heads on and enjoy.
