Welcome to the North American Subaru Impreza Owners Club Monday September 27, 2021
Old 09-13-2021, 11:59 PM   #1
papasmurf180
Member#: 322150
2003 WRX
Default TICKING noise after HG and TB change
Hello all, i am at my wits end trying to figure out this ticking noise!
2006 Impreza outback sport 2.5
Took the Impreza to shop for a new head gasket and timing belt kit along with all new intake, exhaust, vc gaskets etc. since receiving the car back it has a ticking noise that I can't track down. I have already took the car back twice and they can't figure it out. Since then i have taken matters on myself and reset valve clearances to no avail. Intake .20 and exhaust .25.
I am curious if it is something internal or maybe timing belt tensioner? any help would be greatly appreciated. I know head was taken to machine shop and was told had little warped so needed to machine things down. Frustrating but hopefully you guys can help me out.
papasmurf180 is offline   Reply With Quote
Old 09-14-2021, 01:01 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Those valve clearances are WAAAYY too loose. I believe factory spec is .008" intake and .010" exhaust.
yarrgh is offline   Reply With Quote
Old 09-14-2021, 05:19 PM   #3
Waddlz
Member#: 395275
2012 STi
Yeah that is way too loose.
read the FSM, but I believe Yarrgh is correct that intake is .008 and exhaust is .010
Waddlz is offline   Reply With Quote
Old 09-14-2021, 05:50 PM   #4
benflynn
Member#: 515308
Maybe the happiest answer to why is my Subaru making noise. I bet its a dog like that
benflynn is offline   Reply With Quote
Old 09-14-2021, 08:15 PM   #5
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Valve clearance
Intake:
0.200.04 mm (0.00790.0016 in)
Exhaust:
0.250.04 mm (0.00980.0016 in)
If that doesn't help it may be they unloaded the i-AVLS rocker mechanism and did not get them pre-loaded again or dropped the pucks out of the arms. I have seen that make that sort of racket.
Old 09-15-2021, 11:18 PM   #6
papasmurf180
Member#: 322150
2003 WRX
Originally Posted by Elbert Bass View Post
Valve clearance
Intake:
Exhaust:
Valves are set to those clearances. I might have figured out exhaust leak, EGR recirculating pipe crossed threaded into intake manifold. will be replacing the manifold this week. ticking is still present but unsure if that maybe the leak is causing it as well???
