Welcome to the North American Subaru Impreza Owners Club Monday September 27, 2021
Old 09-14-2021, 04:50 AM   #1
Hog Head
Member#: 199810
72 VW Beetle
Ivory
Default EJ20K piston interchange
I have a JDM EJ20K - V4 engine and while I have the heads off for a re-seal, thinking of new pistons and rods
I already bought Cometic C4261-051 (1.4mm / .054") head gaskets
I see that Weisco has "pre 1998" pistons for my engine. Difference is compression height and volume, so I am guessing that it must be wrist pin location, and perhaps crown design.
Stock static compression with my 49cc heads is 7.8:1
Later EJ20 engines are 8.2:1
Or does this even apply to JDM engines?
Rod length seems the same as the later 2.0 engines at 130.5mm
Perhaps my search skills need improving, but surely I am not the first to run across this piston interchange. Must I buy pre 98 pistons, or will the later pistons give me a bit more compression?
Turbo is a VF-48
My goal is a reliable street engine with a bit more power
Hog Head is offline   Reply With Quote
Old 09-14-2021, 10:09 AM   #2
benflynn
Member#: 515308
Id want 8.2 over 7.8, hell if u have E85 Id want 9.8
benflynn is online now   Reply With Quote
Old 09-14-2021, 10:58 AM   #3
Hog Head
Member#: 199810
72 VW Beetle
Ivory
Originally Posted by benflynn View Post
I'd want 8.2 over 7.8, hell if u have E85 I'd want 9.8
Hence the question about late pistons in an early engine
We have E10, E20, and E85 in Thailand
Old 09-14-2021, 11:11 PM   #4
Hog Head
Member#: 199810
72 VW Beetle
Ivory
I am now not so sure if my compression is 7.8 after doing more reading
I see specs ranging from 7.8 to 9.1???
My JDM engine is shim over bucket, TD04 turbo (I think this is stock), no variable valve timing, no wasted spark in the intake, bare aluminium intake
I "think" it is a EJ20K and defiantly is a JDM engine
Heads are off now so maybe time to measure head and cylinder volume
Old 09-18-2021, 03:22 AM   #5
Hog Head
Member#: 199810
72 VW Beetle
Ivory
Valves are leaking so difficult to get an accurate volume until they are ground, but looks like 46-49cc
Piston dish is -7 cc per my measurement, but I have seen specs at 9cc so maybe my measurement technique and will try again with a plexi plate rather than the brimming bathtub method
Piston stick up is 0.3mm
I may well have the later post Oct 1998 EJ20K engine?
I will get a more accurate reading with good valves and a surfaced head, but the data in hand suggests 8.67 - 8.91:1 static
If the engine is post Oct 98 EJ20, I understand that all EJ20 pistons are compatible using my Cometic .054 head gasket - is this correct?
