Welcome to the North American Subaru Impreza Owners Club Monday September 27, 2021
Old 09-10-2021, 05:50 PM   #1
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
Default Any machinists in here?
Trying to source a bottoming extended length M14x1.5 tap. It has to be at least 8 inches long. Either my googling sucks or I'm looking in the wrong places. I need this to tap the block I'm working on for IAG 14mm studs.
alexmartynyuk is online now   Reply With Quote
Old 09-11-2021, 12:03 PM   #2
fwillyj
Member#: 165640
---there is a place on the internet in new york "Victornet"
--they'll make any tap you need basically to your specs---and the price is decent---seems like around $25 or so---and only takes a couple of days
---problem is you need to know exactly what you want and you'll need to call them
--I have done maybe two Subarus for oversize studs
--pretty sure I did 1/2-13 lower threads--had to ream out the bolt holes down thru the heads---might have had to spotface the washer area
---looked in my stuff and the only extra long tap I have is a 14x1.75 that is 12.5" overall length
---I have four 1/2-13 taps from 6 to 8" overall length
---one of these 8" was made extra long but I had to machine down the shank diameter
---so I'm pretty sure the Subaru stud jobs I did were 1/2-13 or 14x 1.175mm
---and none of these are bottoming taps
---looking at the head stud suppliers they are really vague about giving you exact dimensions like diameters and the thread and the shank lengths etc
---I have bought from Victornet several times with very pleasant results
fwillyj is offline   Reply With Quote
Old 09-11-2021, 02:01 PM   #3
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
Thanks a ton man! Ill try to reach out to them. Yeah I found other taps that are about 224mm long but they are M14x2. IAG lists their 14mm head studs as M14x1.5 $25 seems too good lol. All other taps seem to cost $200+
Old 09-11-2021, 02:03 PM   #4
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
FwillyJ what was the overall length of your tap for the 1/2 studs you did?
Old 09-11-2021, 02:50 PM   #5
fwillyj
Member#: 165640
--I have no idea about what I used for studs
---here's a story I wrote to myself when I did the 1/2 studs
Subaru B25 style block gets half inch head studs
---I did some depth checks and machined some light witness marks on the tooling shanks to correspond with the top of the block deck.
1---to tap the head bolt holes requires a 6" tap, a long .422" and a 5" long .515" reamer to do the 1/2-13 threads.
2---clamp the case to the mill.
3---install the drill chuck.
4---set rpm to 150 rpm
5---double check depths of hole to see if they correspond to witness mark rings machined onto the shanks of tooling.
6---eyeball center the .422" reamer and dry ream to bottom of hole to near the witness top ring mark machined on reamer shank.
7---install .515" reamer, dry ream to length of flutes plus about .090" to the machined witness ring.
8---remove the reamer and blow out the chips real good using a 6" long 90 degree air nozzle tip before installing the tap.
9---install the 6" long tap, lube with dark threading oil, normal plunge & prepare to stop
---coast to a stop and reverse at first machined witness mark on shank.
Old 09-13-2021, 12:32 PM   #6
rtv900
Member#: 428511
2016 STI
Dude, you just need a tap extender, not a super long tap
The mention of somebody making a custom tap for $25 is mind boggling, no clue how anybody could do that.
just get an extender. It's just a rod with an end for the tap and an end for a tap holder, just like a tap.
Go to MSC.com and type in Tap Extension
Old 09-13-2021, 05:01 PM   #7
junebugfareast
Member#: 167468
2004 STI
White-ish
Now I feel sheepish about having thought I was clever and fabricating one myself. Should have known something like that would be COTS.
junebugfareast is offline   Reply With Quote
Old 09-13-2021, 10:01 PM   #8
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
i have thought about a tap extension but it may be too wide to fit the block. unless there are super low profile ones. I was able to get in touch with a company that can make a custom tap in Germany but its probably gonna take too long.
Old 09-14-2021, 09:31 AM   #9
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
The problem with extenders that I've seen is their too large of an OD to fit into the hole.
Have one that actually works that you recommend?
Old 09-14-2021, 12:12 PM   #10
rtv900
Member#: 428511
2016 STI
Well the "custom tap made in Germany" thing should answer that question.
It's going to cost half as much as the block and you'll get it come spring time.
Plus, if you are doing this by hand I can tell you starting off with a bottoming tap is asking for trouble. A good bottom tap will barely have any lead on it (hence bottoming) so starting it by hand straight will be hard as hell. If you get it started crooked you are screwed.
If it were me I'd use a gun tap to start (it will have a huge lead on it and pilot in straight) and then go back again for the bottoming.
Well I don't have one that works in that application because I haven't done that exact job, but we have tons here and use them all the time. Any time I see them in use the body of the extender doesn't appear to be any bigger than the body of whatever tap it uses.
But I'll admit I don't really know how small a hole he has to go down into.
Old 09-14-2021, 06:15 PM   #11
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
Definitely not going to do it by hand, It will be done by my local machine shop i'm working with.
I'm hoping to avoid having a custom one made because of the wait time and cost. The taps are somewhere out there as there are a lot of machinists installing the 14mm studs. Just a matter of finding them I guess.
Old 09-15-2021, 08:31 AM   #12
rtv900
Member#: 428511
2016 STI
And this machine shop is conveying to you that they don't know what to do with the reach situation of the tap?????
Old 09-15-2021, 11:32 PM   #13
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
Look at MSCdirect.com or McMaster Carr for what's called a pulley tap. They are long taps not sure you'll find one the length you need but give it a shot. Also look up Walton tap extension that what I have in my box at work. You may be right about the OD of the extension. It fitting in the hole. Good luck
Edit: you can also just buy a standard tap have the shop turn down the shank to a small diameter (so the extension wall thickness isn't very thin) and then drill a hole in a piece of steel 1/2" in diameter or so and drill and tap for a set screw or two to hold the tap. I have also brazed taps into extensions. Hope this helps
*6STARS* is offline   Reply With Quote
Old 09-17-2021, 01:25 AM   #14
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
He's doing what he can on his end but has limited time so I'm doing what I can on my end in my own interest so that we can get this project done. He is currently equipped to do 1/2 head studs on EJ blocks and the tap he uses is about 7". I was able to find a couple taps right around 7-8" Will see if he can get his machine set up for one of them and give it a test hit. Will report once he gets to it but it will probably be another month since the tap is only gonna show up late October. I'm trying to avoid making a custom one or braising as I don't know how well it will hold up at high speed in the CNC machine. If anyone else has any other sources that might have a long tap please do share!
Old 09-17-2021, 01:36 AM   #15
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
I have looked through msc and mcmaster but had no luck finding a long M14 x 1.5 tap. Looked at extension taps and pulley taps. Modifying a tap is something i'm considering but trying to avoid it for now, but good idea tho!
Old 09-17-2021, 01:38 AM   #16
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
Not sure if we are allowed to post links but giving this one a try first:
https://www.gavantools.com/collectio...29891403546723
and also have my eyes on this one:
https://www.grainger.com/product/OSG...ion-Tap-54MF03
