Welcome to the North American Subaru Impreza Owners Club Wednesday May 14, 2025
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 03-09-2004, 09:41 PM   #26
Matt
Allergic to turbos
Member#: 181
They're sending out the letters starting at the end of last month until May based on the build date of your car.
The emails were sent through poeple registered with my.subaru.com. Also, it may take a while to get your letter/email, but don't worry. SOA also doesn't advise going to your dealer until you receive the letter, though you Atlanta people can go bother Porter and get your money's worth out of him.
Matt is offline   Reply With Quote
Old 03-09-2004, 10:47 PM   #27
HappyEeyore
Member#: 29400
i got the email ... just not the real mail ...
HappyEeyore is offline   Reply With Quote
Old 11-01-2004, 08:42 AM   #28
kjtar
Member#: 54006
1988 Mercedes-Benz
Cabernet Red Metallic
From a message on http://www.volvospy.com/resources/300/volvost1.php
A word of warning about using Holts Radweld in the cooling system of your car, from personal experience. A couple of months ago our 360 suddenly developed what sounded like a very expensive rumbling noise coming from the bottom end of the engine. Luckily we were not far from home and were able to drive steadily back for a closer inspection. Listening to the engine with a short hosepipe it certainly sounded like a bearing had gone. However, when the belts were disconnected from the cooling fan and alternator the noise stopped. The alternator was OK but when I turned the water pump pulley it made a terrible grinding noise. The bearing in the water pump was very badly worn which could have resulted in the fan shearing off through the radiator! When a water pump is beginning to wear, leaking coolant normally escapes through the drain hole in the bottom of the pump. As Radweld had previously been used in the car this did not happen as the drain hole was sealed. The pump was found to be full of coolant with a badly worn bearing which could have sheared at any time without warning.
So, now where does this leave us? If the seep hole on the water pump is "sealed up" by the "Subaru Cooling System Conditioner" (aka Holts Radweld) then what course of action do Suby owners have? I guess we could go back to Subaru, they could go to Holts (Honeywell) etc.
Tom Reynolds
Sand Springs, OK
kjtar is offline   Reply With Quote
Subaru Cooling System Conditioner - What IS this stuff? jac04 Service & Maintenance 55 02-09-2018 11:31 AM
WWP-99 Service Campaign - Cooling System Conditioner subyfanatic Warranty Issues & SOA Problems 155 01-31-2014 07:52 PM
Subaru Cooling System Conditioner Silver04WRX North West Impreza Club Forum -- NWIC 2 06-03-2005 10:07 PM
Service Program Bulletin WWP-99: Engine Cooling System Conditioner speedway7414 Warranty Issues & SOA Problems 2 04-24-2004 12:35 PM
WWP-99 Service Campaign - FREE Cooling System Conditioner dayton100 North West Impreza Club Forum -- NWIC 6 02-24-2004 10:51 PM
