Welcome to the North American Subaru Impreza Owners Club Monday June 25, 2018
Old 01-12-2018, 01:42 AM   #1
Turbo_CurboNY
Member#: 480469
Default Buying car soon, HELP!
Hi, Im fairly new to Subarus in general and Im planning on purchasing one this upcoming week, its a 2002 wrx, and what are some things I should ask about the car? (Noob question I know, Im sorry) I just donít know what kind of questions to ask! Thanks!
Turbo_CurboNY is offline   Reply With Quote
Old 01-12-2018, 07:26 AM   #2
Jack
Add Lightness
Member#: 13699
not my president
(From General)
The first thing to do is to arrange for a pre-purchase inspection with a Subaru specialist mechanic. Skip this and we'll just roll our eyes when your next post talks about a knocking in the engine or overheating after 20 minutes driving home.
Look for Unabomber's manifesto as he has a very good write up on car buying. Remember that this is an ancient car that needs to have records of the timing belt replaced and at this point, every hose and vacuum line in the car. Unless it's currently owned by an OCD maniac, you'll need to replace all fluids (coolant, brake fluid, clutch fluid, trans fluid, rear diff fluid, power steering, which is NOT power steering fluid) and although you can check and not replace, expect all filters and spark plugs to be due. The easy stuff like brakes can be checked, but while you're checking, do the slides still slide? Ancient Subarus (like all antiques) tend to stick, which makes the brakes not work right. Do the caliper pistons move? This is all stuff that a PPI will check. It should take several hours and cost a few hundred dollars. Rust? Rear shock towers, lower control arms, sub frame mounting points are all known problems in these cars. Control arms are easy but rusted shock towers can mean "scrap the car".
Old 01-12-2018, 08:25 AM   #3
Ishbu0062
Member#: 375051
2016 WRX STi
^^ THIS
Ishbu0062 is offline   Reply With Quote
Old 01-12-2018, 11:36 AM   #4
Turbo_CurboNY
Member#: 480469
Thank you! Will do! The guy selling it has been a Subaru mechanic for 4 years, but Iíll probably still get it checked out before hand! Thanks again!
Old 01-17-2018, 08:26 AM   #5
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Honestly, this means nothing.
- How good of a mechanic was / is he?
- What is the reputation of the Dealership he works at?
You want someone unbiased to go over the car. Rightfully so, current owner is biased about his car. This doesn't mean he is trying to deceive you at all, but how would you know?
Does he have a complete list of Service Items and Parts on this car to give you, ie; maintenance records?
Old 01-12-2018, 07:53 AM   #6
rtv900
Member#: 428511
2016 STI
It's 16 years old, so you can just verify it's not a nightmare vehicle and that you aren't paying more than $1500.
rtv900 is online now   Reply With Quote
Old 01-17-2018, 12:45 AM   #7
Mr.Darcy
Member#: 480731
2000 GC8
I brought my 2000 WRX on a whim without an inspection. Depending on the price of the car, sometimes you just have to bite the bullet as old cars will have problems and you just want to avoid a nightmare.
Mr.Darcy is offline   Reply With Quote
Old 01-19-2018, 04:10 PM   #8
lpxltt
Member#: 395574
2007 OBS
I take it you were not living in the US at the time?
lpxltt is offline   Reply With Quote
Old 01-19-2018, 03:07 PM   #9
StocktonBomb
Member#: 451544
2017 STi
Get compression and leak down tests done before buying.
StocktonBomb is offline   Reply With Quote
