Welcome to the North American Subaru Impreza Owners Club Thursday August 5, 2021
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 05-07-2021, 10:26 AM   #1
Clmoore3
Member#: 505803
Default Walnut Blasting vs. Chemical cleaning valves - help
my car is a 2017 WRX premium, purchased at 40k miles (42.5k current), no clue if previous owner had them cleaned, assume not - no issues except i get a lot of carbon on my exhaust tips (they are completely black right now) ... not sure if this indicates the valves are gunked up? I have called multiple shops and mechanics, posted in various facebook groups, etc trying to find someone near me (Evansville, Indiana) that does walnut blasting. I have been unsuccessful as no one near me does it that ive been able to find.
1 shop said they don't do walnut blasting but do offer a fuel injection cleaning service where they introduce a chemical into the engine that will clean the carbon build up out. I mentioned my car is DI and doesnt have fuel injectors but they said it would still clean it out. When I recently realized that the carbon build up is a thing that needs addressed, everything ive seen has said walnut blasting.
TLDR; will this chemical cleaning im being offered work just as well as walnut blasting to clean the intake valves?
Clmoore3 is offline   Reply With Quote
Old 05-07-2021, 11:09 AM   #2
numskull50
Member#: 373996
2015 FXT Touring
Quartz Blue Pearl
you can buy CRC intake valve cleaner at any auto parts store. you can also get a media blaster walnut shells and everything at harbor freight plenty of videos on youtube on how to do both.
numskull50 is offline   Reply With Quote
Old 05-07-2021, 11:17 AM   #3
Clmoore3
Member#: 505803
The CRC cleaner isnt going to do that great right? How does that and the results of walnut blasting compare to the chemical cleaning a shop is offering me? ($171 if only has to do 1 application, double if 2). You may not know the comparison per se, but im hoping someone here might.
Yeah ive been looking up DIY videos, guess im a little nervous to mess something up.
Old 05-07-2021, 11:18 AM   #4
MZR2FA20DIT
Member#: 426776
2016 WRX
lapis blue pearl
No it won’t hardly do anything. At 40k I wouldn’t worry about it too much. My first cleaning was at 80k. The soot on the exhaust is normal, seems direct injection cars have more of that or at least in the ones I have owned.
MZR2FA20DIT is offline   Reply With Quote
Old 05-07-2021, 11:23 AM   #5
Clmoore3
Member#: 505803
First DI car + first modified car. I am looking to do some more mods soon + get a tune so I was thinking i should look into cleaning it prior to that.
Old 05-07-2021, 11:24 AM   #6
dpetro1
Member#: 487500
2018 WRX
Depends on what chemical process is being used. Running a cleaner through the gas tank won't do anything. Introducing a chemical cleaner via the intake manifold should help. Subaru actually makes a kit for this and is recommended in their service intervals.
Of course some type of physical removal of the carbon is a sure fire way to clean the valves.
dpetro1 is offline   Reply With Quote
Old 06-11-2021, 02:36 PM   #7
Rety1-1
Member#: 234801
I recently tried cleaning my intake with Seafoam spray I picked up locally and my car (17 WRX stock) has been having really strange issues..
wont boost over 3psi, AFR stays consistently between 13:1 and 15:1, EGT is always about 100 degrees higher than normal, and there's no consistent codes.
I get a P0420 that doesn't actually trigger the CEL and I had a P0137 one day but I cleared it and it never came back.
I'm completely baffled.
I was thinking the seafoam redeposited cleaned carbon onto my spark plugs, and changed them to no avail (I'm at 60k miles so it was time to change them anyway)
Rety1-1 is offline   Reply With Quote
Old 05-07-2021, 11:26 AM   #8
Clmoore3
Member#: 505803
Yeah, i didnt think running something through the gas was gonna do much. I should (and will do so) clarify what the chemical cleaning process involves.. if they actually introduce it through the manifold/take it off to get to the valves, then i would feel a bit better about it.
Old 05-07-2021, 06:07 PM   #9
noobultimatum
Member#: 431550
2016 WRX
ALL THE STAGES
Run a search on the forums. There are a few threads talking about this subject already that will help you understand dirty valves, walnut blasting, wmi...
Bottom line? Nothing will clean your valves completely except for WALNUT BLASTING THEM. Nothing.
WMI will help maintain the back of the valves by having something spray over the backs of them, but since it isnt spraying all the time, you will end up with build up.
DI motors all suffer from build up on the valves. It comes with the territory.
noobultimatum is offline   Reply With Quote
Old 06-11-2021, 03:15 PM   #10
dpetro1
Member#: 487500
2018 WRX
Which seafoam product did you use and how did you introduce it into the engine?
I would check simple things first, like any potential vacuum leaks.
Old 06-11-2021, 04:07 PM   #11
Rety1-1
Member#: 234801
the aerosol spray they have for cleaning gasoline direct injection engines. I don't recall a specific product name other than Seafoam.
The directions say to introduce the spray right at the throttle body but that would've been nightmarish to accomplish properly so I slid the tube into the charge pipe going into the intercooler. I only took off that worm clamp to slide the tube inside the coupling and I tightened it back up when I was all done.
I'll check it when I get home to be 100% certain its on correctly and tight.
Edit: It also idles perfectly, the only issues are when the engine is under load.
Edit #2: I wanted to also apologize for hijacking this thread. I didn't have enough posts to start my own and this is the most closely related thread I could find to try and get some kind of information.
Old 06-14-2021, 02:30 AM   #12
basyager
Member#: 518233
2019 WRX
id just get this kit and DIY it. just make sure the valve is really closed lol
https://subiebros.com/subie-bros-fa2...lnut-blasting/
watch their video. you literaly slap this bad boy onto your heads and blast teh velves
basyager is offline   Reply With Quote
Old 06-15-2021, 03:28 AM   #13
Tinapayboy
Member#: 524927
Walnut all the way!
Tinapayboy is offline   Reply With Quote
Old 07-07-2021, 02:19 PM   #14
legacyboy
Member#: 408121
2012 Legacy GT DIT
JDM
nobody in my country has heard of walnut blasting and we're all driving DI cars.
i think it's optional unless the carbon is causing problems
legacyboy is offline   Reply With Quote
Old 07-07-2021, 02:25 PM   #15
cdska
Member#: 458809
05 blob, 02 bug
all maintenance is optional, some just have more repercussions by not doing than others
cdska is offline   Reply With Quote
