Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2018
Old 01-05-2004, 07:24 PM   #26
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
If its the same mod (and as I said, I'm not sure if it is or not) the cut is right below the microweld on the injector itself (at least it is on the ones I have). I can't see your pic Cronic, so I'm not sure what you are showing (just see the red "x" )
I can post a pic of what I have, if somebody can post a pic of one just cut (I'll show you mine if you show me yours ). Should be pretty easy to see if they are identical, at least externally. I know the ones I get are flow matched as well, so maybe some more work is going into the ones I've been getting.
Kingpin or anybody else thats done this - do you have flow numbers for 4 injectors that you could show? Just to see how matched they are after doing this?
DarthChicken is offline   Reply With Quote
Old 01-05-2004, 07:28 PM   #27
IgotWRXed
Member#: 14868
2002 wrx
wow, this is great. i was just about to purchase some pinks for my VF34 app. now im just going to mod my stockers
IgotWRXed is offline   Reply With Quote
Old 01-05-2004, 07:29 PM   #28
IgotWRXed
Member#: 14868
2002 wrx
it would be awesome if you could show a modified injector. possibly next to an unmodded one?
Old 01-05-2004, 07:30 PM   #29
03WRXMA
Member#: 35081
2012 WRX
Im pretty sure its the line closer to the end of the injector.
-Dave
03WRXMA is offline   Reply With Quote
Old 01-05-2004, 07:30 PM   #30
cronic
Member#: 9749
Pic shows up fine for me man..
cronic is offline   Reply With Quote
Old 01-05-2004, 07:31 PM   #31
03WRXMA
Member#: 35081
2012 WRX
Does your shop tell you what "flow matching" includes?
Old 01-05-2004, 07:38 PM   #32
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
I'm pretty sure it would be the "or here" line in the pic. It would make sense for the cap to come off once you grind away the weld.
Zackbo is offline   Reply With Quote
Old 01-05-2004, 07:40 PM   #33
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Cronic, I'm behind a firewall here at work, thats probably my problem (I tried just linking to it in a blank window and got a security error). Probably my problem.
As for "matching", what I get is a form saying "flowed to 73lbs" and some measurements (Injector #1 - 737cc, Inj #2 - 739cc, etc...). So, they are individually flowed.
The question though is... what is done? Is it just cutting the caps, or is it more? Thats the $1M question!
Old 01-05-2004, 07:44 PM   #34
SleeperWRX
Member#: 8179
am i wrong in thinking this will decrease the atomization of the fuel...it will be more of a spray than a mist? I'm not just talking about the amount of fuel being flowed, but the way it is being sprayed.
SleeperWRX is offline   Reply With Quote
Old 01-05-2004, 07:55 PM   #35
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Originally posted by Kingpin
Cronic. We have maps for these injectors for the US and JDM STI ECU's including the AF481 and AG970. Send the ECU back if you want me to update it!
Could you reflash my JDM ECU I believe its a AG790 for the 740cc and a T3/T04E setup w/ FMIC? This is with supporting mods of course.
Need4Boost is offline   Reply With Quote
Old 01-05-2004, 07:56 PM   #36
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Old 01-05-2004, 08:07 PM   #37
cronic
Member#: 9749
Hey man Soon2BGreat and myself will be setting up another Tri-State dyno day in the early to mid spring in which KingPin will be tuning ECUTEK, UTEC, and other ecu's.. If they have some sort of basse map for you to hold you over until the dyno day that would be awesome..
Dave-
Old 01-05-2004, 08:13 PM   #38
sideways slut
Member#: 21085
2.5 rs-t
i wonder if this mod will work on a stock rs injector where it also sprays out the sides, at least for the my00-01. that whole secton will need to be cut off aprox1/2". ive never really known what the importance of the side flow is seeings how my RC's dont have it. also aprox. how much is it to get injectors flow tested, i have an extra set sitting right in front of me and ill be willing to cut them right now and send them away tomorrow to see what theyll flow(obviously less then the wrx's but you would think that they should be able to spray around 500cc).
jay
sideways slut is offline   Reply With Quote
Old 01-05-2004, 08:27 PM   #39
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
You cut the cap off. If you hold an injector in your hand you will see the cap is welded on. Either grind the welds down or just cut the end of the cap off. I have had great luck with these and they seem to be very close in flow. So close that testing is no longer needed in my opinion. Like I said, If you are worried then send yours into Venom or RC for testing. Its a waste of money but if it makes you feel better then go for it.
I have a program that should be damn close for your AG970 ECU with Garrett turbo and these injectors. I can also remove the limiters and cal for different octane. Email me if you need more information.
Good luck guys. I know you will like these and its a great value! Free! Just make sure you have something that can tune these guys. 740's are damn big injectors. Turbos like 20G, 1820, Garretts, SR's and AVO's can use this much fuel. Most of the VF's dont need nearly this much fuel but you can still use them as long as you have something to tune with.
Kingpin is offline   Reply With Quote
Old 01-05-2004, 08:51 PM   #40
M32WRXin3seconds
Member#: 36797
ummm...i just installed PE 650's why? for sale!
M32WRXin3seconds is offline   Reply With Quote
Old 01-05-2004, 10:01 PM   #41
IgotWRXed
Member#: 14868
2002 wrx
hmm if i get something like cobbs upcoming stage 3 reflash for the VF34 turbo or an ECUTEK reflash through vishnu or vivid or someone, would i be able to still use these? with the money saved i could purchase a nice manifold
Old 01-05-2004, 10:18 PM   #42
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
I'd be interested to see if this works with the stock RS (00') injectors as well.
t.rod is offline   Reply With Quote
Old 01-05-2004, 10:22 PM   #43
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
I don't see why not. I have these in my car... Kingpin tuned this, and PDXTuning will be tuning them in my car later this week.
Old 01-05-2004, 10:22 PM   #44
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Very interesting information. Thanks for sharing, as always
So, theoretically... one could just enlarge the holes uniformly and (ideally) get them flow tested by RC if one didn't want a whopping 740cc. Probably a bit sketchy to do. I'm thinking of the people looking for ~240WHP, etc.
jblaine is offline   Reply With Quote
Old 01-05-2004, 10:23 PM   #45
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Not likely. Get a custom EcuTek tune and sure.
Old 01-05-2004, 10:42 PM   #46
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
We got hosed Josh, we got hosed
I'm going to wait for other people to try this out though before i take out the PE's. It would be cool to have this mod work though, and all along everyone thought DSMs were king of the free mods hahaha.
PaulRex is offline   Reply With Quote
Old 01-05-2004, 11:19 PM   #47
sideways slut
Member#: 21085
2.5 rs-t
i would like to see what the wrx injectors look like with this mod done. i cut apart a my00rs injector and it ended up in pieces
it looks like the gas flow through this little tube
i even cut just after the secton with the holes but it must be all one piece. i then tried to grind another one down to see if it would work better but it turned out crappy to. i wonder if i should try drilling out the center and see how that turns out
Old 01-06-2004, 01:30 AM   #48
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
I sure hope this is what Perrin is doing to the stock side feed injectors on the USDM STI.
http://forums.nasioc.com/forums/show...hreadid=473196
I'm one happy camper if it is.
Wombat North is offline   Reply With Quote
Old 01-06-2004, 02:28 AM   #49
M32WRXin3seconds
Member#: 36797
paul...i think im going to stick to the PE's until this is proven, than sell them used on ebay for over 300 someone would definately buy them...
Old 01-06-2004, 02:48 AM   #50
Big Turkey
Member#: 32118
He did say that it's already been done on 7 cars. Which technically means it's proven. I still have my stock injectors and I will do the mod when I get the chance and send them out to be flow tested and post the results for everyone who's interested in seeing them.
Big Turkey is offline   Reply With Quote
VF39 turbo, STI Top Mount,740cc Injectors, MORE! FREE SHPPING mjackle Engine/Power/Exhaust 13 10-09-2008 01:35 AM
WTB: Nismo 740cc Injectors for 05 STi Legba Private 'Wanted' Classifieds 2 02-19-2008 09:01 PM
FS: JECS 740cc injectors for STI legacy2003 Engine/Power/Exhaust 4 07-03-2007 12:38 PM
MZMperf. drop-in 740cc injectors for STi zacek Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 07-16-2004 03:29 PM
WTT: My Modded 740cc Injectors for APS CAI Schleppy Private 'For Sale' Classifieds 0 05-12-2004 12:17 PM
