Welcome to the North American Subaru Impreza Owners Club Monday August 19, 2019
Old 04-22-2003, 09:51 AM   #26
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Originally posted by stimpy
Cable speedo was mentioned because the older imprezas used a mechanical speedometer. The cable goes to the speedo and the gauge cluster sends the speed signal to the ECU. The newer imprezas use an electrical speedometer and the speed signal splits from the tranny and goes to the ECU and the gauge cluster. This will only be a concern if you swap in a newer transmission or if you use a newer factory ECU.
-Jon
Why would you have a problem if using a newer ECU? Are you talking about just the splicing and soldering of the harness?
Thanks, Micah
Old 04-22-2003, 09:51 AM   #27
Homemade WRX
Member#: 33782
96 in the garage
-Jon
Thanks, Micah
Old 04-22-2003, 10:00 AM   #28
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Click the submit button about 3 times fewer.
You could have a problem using a newer ecu and an older tranny because the signal must be tapped off the gauge cluster. While both ECU's expect a 0-5v signal, I am not sure if the pulses are the same between sensors.
-Jon
has anyone done a DIY PPG install?? ATMO5PHERE Transmission (AT/MT) & Driveline 4 12-28-2007 11:42 AM
Has anyone done a 98 N/A EJ22 into a 93-95 EJ18 swap? Kostamojen Subaru Conversions 3 06-04-2004 11:40 PM
Has anyone done a swap of the STi sedan suspension to a wagon? Richard Sierra Brakes, Steering & Suspension 36 04-16-2004 01:16 AM
Has anyone done a Defi boost gauge/timer install on the STi? OldSkewS4 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-17-2003 02:25 PM
Has anyone done a ej20t transplant before? ac_gohan Bay Area Impreza Club Forum -- BAIC 0 05-22-2001 02:01 PM
