06-14-2017, 10:38 PM | #1 |
Member#: 464679
SWIC
Vehicle:2012 WRX STi Ice Silver Metallic |
AEM or Innovate Wideband
Just purchased the Invidia downpipe with 2 O2 bungs, now I need a wideband sensor set up! I'm looking at the AEM UEGO and the Innovate MTX-L Plus. Which do you recommend?
Also, I'm going to need advice or a guide on how to wire it. I haven't installed one before so I don't know how to route it and how to get it into the cabin. I would like to set it up to work with my Accessport as well. Please help!
06-14-2017, 11:04 PM | #2 |
Member#: 40453
South East
I went through 2 innovative widebands. Complete junk. Controllers failed on both of them. Constantly needed to be calibrated.
06-14-2017, 11:06 PM | #3 |
Member#: 464679
SWIC
06-14-2017, 11:45 PM | #4 |
Member#: 138994
Vehicle:2006 WRX, 6MT, 5x114 |
AEM. Especially since they are now using the Bosch 4.9 sensor.
06-14-2017, 11:46 PM | #5 |
Member#: 464679
SWIC
06-15-2017, 08:32 AM | #6 | |
Member#: 138994
https://forums.nasioc.com/forums/sho....php?t=2778063 https://cobbtuning.atlassian.net/wik...Sensor+Logging Last edited by JarHarms; 06-15-2017 at 08:40 AM. Reason: added links |
06-15-2017, 10:37 AM | #7 |
Member#: 427424
Vehicle:2014 wrx hatch black |
I have both the AEM uego and the Innovate MTX-L in different cars. I like the MTX-L more. It has a faster response than the AEM. I don't datalog with the aem since it is in a carbureted vehicle but the mtx-l syncs right up with romraider logger. I haven't had any issues with either unit and they both seem to be accurate. Been running the innovate for 6 months, aem for several years.
06-15-2017, 11:02 AM | #8 | ||
Member#: 464679
SWIC
06-15-2017, 11:20 AM | #9 |
Member#: 236952
Vehicle:2010 WRX (SSM) Stg 2+ 310/370, 6sp R180 |
06-15-2017, 11:27 AM | #10 |
Member#: 236952
personally i run the Spartan2 OEM from 14point7. good response, and i didn't mind wiring it up myself. a hell of a lot cheaper than the big name offerings.
my biggest gripe with AEM and Innovate units are that they have unnecessary round gauge displays. you only need a small LED segment display (or no display at all if you just wire it into the AP). on my setup i have the 0-5V signal split, one wire to the rear O2 plug to be datalogged by the AP, and the other running into a microcontroller that's converting to a digital signal and sending to a small LED display for real time. |
06-15-2017, 11:31 AM | #11 | |
Member#: 464679
SWIC
06-15-2017, 11:33 AM | #12 |
Member#: 427424
I think he's saying to log with accessport you need to connect the aem output to the rear sensor wires(since rear o2 is not used for tuning, only front). Sounds like you can't log external sensors with accessport but I don't have one so I don't know. Tactrix cable with Romraider you can log all the car's sensors plus external sensors and don't have to hook wires together under the car or scale voltages.
The only problem I had with the innovate was initially getting it to sync with romraider. Most of the time it would not work but randomly would but it was not the fault of the innovate unit. The DB-9 to usb adapter cable I purchased was crap. Bought a more expensive one with the FTDI FT232R chipset and it works every time without issue. |
06-15-2017, 11:39 AM | #13 | |
Member#: 464679
SWIC
06-15-2017, 11:40 AM | #14 | |
Member#: 236952
The AP can log any 0-5V signal you give it. It really doesn't matter what it is. If you have some random 0-5v sensor that the AP doesn't know what to do with (like say EGT or something) you can still input the signal and log the voltage directly, then do your own calibration curve conversion in post analysis of the datalog. I'm currently logging fuel pressure and Wideband O2 by feeding the signals into the ECU directly and configuring the inputs in the AP software. You can feed 3 different 0-5v sensors into the AP on the following inputs: Rear O2 Right TGV Left TGV |
06-15-2017, 11:53 AM | #15 | |
Member#: 464679
SWIC
06-15-2017, 11:57 AM | #16 |
Member#: 236952
06-15-2017, 11:58 AM | #17 | |
Member#: 236952
You can use 1 TGV input even if you don't delete them. That's what I'm doing now. You just duplicate one TGV to drive both, then use the spare one for whatever signal you want to input. |
06-15-2017, 12:27 PM | #18 |
Member#: 464679
SWIC
06-15-2017, 01:09 PM | #19 |
Member#: 236952
Yup. It takes the analog 0-5v signal converts it to AFR value, then writes the value over the digital serial port to the display.
06-15-2017, 02:26 PM | #20 |
Member#: 464679
SWIC
Just found the UEGO on Amazon for $153 with free prime shipping. Probably going to go that route
06-15-2017, 02:32 PM | #21 |
Big Ron
Super Moderator Member#: 18062
Have you considered spending $153 on hookers and blow as you DO NOT need a wideband on your car at all? My 250,000 mile trouble free Subaru has not seen the need for one since April 2003.
06-15-2017, 02:40 PM | #22 |
Member#: 464679
SWIC
I have a feeling 153 may not get me very much blow and probably an undesirable hooker. Hahaha
