Welcome to the North American Subaru Impreza Owners Club Friday April 20, 2018
Old 07-31-2013, 03:34 PM   #1
cwb124
Member#: 15571
2006 06 Forester XT
Default Home theater experts...need troubleshooting
My current setup is a Panasonic 50" plasma model th-50px80u. Have a Vizio sound bar. HDMI cables running from sony blu-ray and Comcast DVR to HDMI inputs 1 and 2 on the back of the TV. One optical cable output going to Vizio sound bar.
Just upgraded to Comcast X1. However there was no audio when setting it up with the new cable box. We swapped HDMI cables and inputs and no audio. DVD audio worked fine the whole time.
Just for giggles, we ran a cable from HDMI port 3 on the front panel of the TV to the cable box and audio works fine. WTF could that possibly be? I have a clean install and would rather not have a cable running out of the front of my TV. I'm at a total loss.
cwb124 is offline   Reply With Quote
Old 07-31-2013, 03:36 PM   #2
CatfaceType-R
Member#: 81102
Old 07-31-2013, 03:37 PM   #3
OriginalSin
Member#: 66341
Home theater .....Vizio sound bar
yeah ... no
OriginalSin is offline   Reply With Quote
Old 07-31-2013, 03:39 PM   #4
touch
Member#: 12678
touch is offline   Reply With Quote
Old 07-31-2013, 03:41 PM   #5
lacuna0
Member#: 251529
Do ports 1 and 2 work on the front of the TV? Did you go through the sound menu on the new box to make sure those ports are on?
lacuna0 is offline   Reply With Quote
Old 07-31-2013, 03:42 PM   #6
TrickNipple
moon moon
Member#: 86213
Did you try looking in the Home Theater subforum?
TrickNipple is offline   Reply With Quote
Old 07-31-2013, 03:43 PM   #7
cwb124
Member#: 15571
2006 06 Forester XT
HDMI ports 1 and 2 are on the back of the TV, and they worked with the old box before we replaced it. We also tested them with a DVD during this process and they worked fine. THey just didn't like the new X1 box. I just find it very odd that HDMI 3 on the front worked fine with it.
Old 07-31-2013, 03:44 PM   #8
touch
Member#: 12678
Check the audio settings in the cable box menu. Sometimes you need to restart the box for the settings to take effect.
Old 07-31-2013, 03:46 PM   #9
cwb124
Member#: 15571
2006 06 Forester XT
Restart what? We did check audio settings. There isn't much on the cable box. Stereo or surround are the only options. I went through the audio settings in the TV as well.
Old 07-31-2013, 03:47 PM   #10
OriginalSin
Member#: 66341
you suck worse than we thought
Old 07-31-2013, 03:49 PM   #11
cwb124
Member#: 15571
2006 06 Forester XT
And you're an over-entitled attention whore ****ing douchebag. Shut your ****ing hole already. I hope your rope breaks.
Old 07-31-2013, 03:52 PM   #12
cwb124
Member#: 15571
2006 06 Forester XT
It's a brand new box that was just put in. And yeah we've cycled it as part of the first few steps of fixing this.
I think the problem lies in the TV since 1 of 3 ports works.
Old 07-31-2013, 03:53 PM   #13
OriginalSin
Member#: 66341
if by rope you mean weenur .. then it already did...
in your mom!
QUAH-BAM!!!! you got served
Old 07-31-2013, 03:53 PM   #14
lacuna0
Member#: 251529
Oooohh gotcha. So you didn't change anything on the TV but 1 and 2 don't work with the new cable box and 3 does. I'd still go through setting to make sure your digital audio is set to HDMI and if it has a secondary audio option make sure it's set to no. Sorry that's all I got for you.
Old 07-31-2013, 03:54 PM   #15
Reflex-Arc
Lord of the Gif
Member#: 1703
2013 Fiat 500 Abarth
Bianco
Does the X1 box have that sub menu you can poke around in? (Power off the box, leave the TV on, hit menu on the Comcast remote) I don't recall ever seeing audio options in there, but it may be worth checking.
Reflex-Arc is online now   Reply With Quote
Old 07-31-2013, 03:55 PM   #16
ganzhimself
Member#: 252648
2010 Mini Cooper
Pepper White
Unplug the optical cable from the TV going to the sound bar. Does the audio come through the TV speakers? There may be a setting in the audio menu for using that optical out, I had the 42" version of that TV years ago, though I never used the optical port.
ganzhimself is offline   Reply With Quote
Old 07-31-2013, 03:56 PM   #17
FellowTraveller
Member#: 161570
2007 Impreza
Newport Blue Pearl
how do you spell HDCP ?
FellowTraveller is offline   Reply With Quote
Old 07-31-2013, 03:57 PM   #18
touch
Member#: 12678
Wait, I thought you said the audio worked with the dvd but not the Comcast box (through the same ports).
I know in my cable box there are several audio settings - fixed/variable; optical/analog; etc. I had a similar problem recently and found that the internal changes were not taking effect unless I on/off'ed the box itself. When I finally figured that out I was all
Old 07-31-2013, 03:58 PM   #19
CalcVictim
Member#: 57056
2006 Focus
enchanting primer
Look on the cable box for the sound menu, it could be sending a signal encoded in a way that you TV can't decode, it might say "surround" or something else
also when there was no sound have you switched channels/programs on the cable box...some sound is DD encoded and some is PLII
CalcVictim is offline   Reply With Quote
Old 07-31-2013, 03:59 PM   #20
cwb124
Member#: 15571
2006 06 Forester XT
Went through that. Was looking for PCM or something to mess with. No audio stuff in that diag menu at all.
Old 07-31-2013, 04:02 PM   #21
cwb124
Member#: 15571
2006 06 Forester XT
Correct. HDMI 1 was the old Comcast cable box. HDMI 2 is the blu ray. We tried HDMI 1 and 2 with the new cable box, trying both cables too. No audio.
This cable box has "stereo" and "surround" as the only audio settings. Very basic.
Old 07-31-2013, 04:02 PM   #22
Qcanfixit
Member#: 135762
2059 Venturi Skimobi
transparent aluminium
based on the OP, it seems to me that the optical port on your new box is either disabled or not working for some reason.
based on the post above this one, it seems like the box is not handshaking with the rest of your gear.
have them send a reset signal to your box.
Qcanfixit is offline   Reply With Quote
Old 07-31-2013, 04:04 PM   #23
cwb124
Member#: 15571
2006 06 Forester XT
We did change channels a few times to check that. Like I said, there isn't much in the way of audio settings on the cable box. Stereo and surround is it.
Old 07-31-2013, 04:07 PM   #24
cwb124
Member#: 15571
2006 06 Forester XT
based on the posts above this one, it seems like the box is not handshaking with the rest of your gear.
The optical cable goes from TV to sound bar. That hasn't changed. This is a brand new box, actually the second one we tried today. Both were brand new out of the box. Signal was sent to the box a couple times throughout the day during initial setup.
Old 07-31-2013, 04:07 PM   #25
lacuna0
Member#: 251529
Have you tried using optical digital or RCA ports from the cable box to the TV?
