05-17-2004, 09:30 AM | #1 |
Member#: 46399
Vehicle:0000 Knows nothing, about nothing. |
Checked for boost leaks, purge valve leaks, any ideas?
Part 42084G in the diagram squeels/vibrates when I manually apply pressure from an air compressor, begins around 4psi and gets worse/better as it goes up... is this normal behavior or does this valve need replaced?
05-17-2004, 11:35 AM | #2 |
Member#: 46399
well i ordered a new valve, but nobody pressure tests their intake systems here for boost leaks?
if you do, any notes about how well it holds for you or any odd noises even though it's not leaking to atmosphere? |
05-17-2004, 11:43 AM | #3 |
Member#: 35081
NESIC
Vehicle:2012 WRX WRB |
IIRC isnt that a check valve for the FPR, and fuel system?
05-17-2004, 01:04 PM | #4 | |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
05-17-2004, 01:09 PM | #5 |
Member#: 46399
so this is NOT supposed to happen right?
what other affects is this having on the running condition of my car? |
05-17-2004, 04:10 PM | #6 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
probably needs to be replaced. when you think about the function of that part, you have three ports... fuel in, fuel out, and manifold pressure. the manifold pressure should have no flow other than that required to deflect the internal diaphragm. vibrating/squeeling indicates to me an internal leak.
jm2c ken |
05-17-2004, 04:20 PM | #7 |
Member#: 35081
NESIC
Also...
Whats your fuel pressure at idle? Under boost? And WHY are you testing for boost leaks? Is boost bleeding off on you...? |
05-17-2004, 04:58 PM | #8 | |
Member#: 46399
05-17-2004, 05:00 PM | #9 | |
Member#: 35081
NESIC
The purge vavle may be ok, but I dont think anyones ever had it go bad so we dont know how to diagnose it... What turbo are you running now?! -Dave |
05-17-2004, 05:37 PM | #10 |
Member#: 46399
stock turbo
i understand it vents vapors, but it can affect fuel pressure too? i thought the line running to the fpr was independant |
05-17-2004, 05:40 PM | #11 | |
Member#: 35081
NESIC
05-17-2004, 05:42 PM | #12 | |
Member#: 46399
yeah everything's attached and operating perfectly except this valve, no check engine light and good vacuum @ idle, runs/drives fine... i was just trying to gauge how important this little valve was and what it affects negatively except emissions if it fails |
05-17-2004, 06:34 PM | #13 |
Member#: 32792
NESIC
ahh, here i was thinking that's your fpr... damn. disregard my previous comments please!
those exploded parts diagrams can be confusing when you don't have the real thing in front of you! ken |
09-08-2004, 09:51 PM | #14 |
Member#: 28408
TXIC
Vehicle:2002 vf48ed WRX OBP |
do you have a loud squeal? if so i have the same problem... did you ever find a solution?
07-05-2005, 01:29 PM | #15 |
Member#: 36983
Vehicle:2002 wrx black |
I know this is old but I am replacing the purge valve. Which way does the to e/g connect to?
07-05-2005, 01:59 PM | #16 |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
That sound is normal, whenever I pressurize a system on my car or a friends it will make that noise once the system is completly full of air. This valve just releases some of the air because it has no where else to escape. If i recall the valve has an arror showing which way it connects.
07-05-2005, 03:55 PM | #17 |
Member#: 36983
The arrow has the letters e/g, I need to know if it goes toward the intake or the other direction. I am thinking it points away from the intake.
Purge Valve Leak ? | AndrewMC | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 09-11-2008 11:52 PM |
AP boost gauge to check for boost creep? | sperry7 | AccessPort | 3 | 07-24-2006 05:20 PM |
Best way to check for boost leaks | Natoe | Newbies & FAQs | 3 | 06-30-2006 12:59 PM |
I'm this close to selling the bastard. Boost control issues > me. Any ideas? | Noizemaker | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 50 | 03-13-2006 04:34 PM |
Looking for NJ shop 4 Spring Install! Any ideas?? | SoLiDbReAkZ | Tri-State Area Forum | 19 | 02-07-2002 01:16 PM |
