![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#26 |
Member#: 205427
Vehicle:2000 RSTI w/ hta68 Army Green |
![]() I just read your article and i am trying to decide whether or not i need a full blown track pad for HPDE's. I will be running on Kumho XS which are fairly grippy for a street tire which i am sure you are aware of just wanted to give some detail. Am i better off switching pads for events using a HT-10 or running something similar to the hawk blue 9012. I am a novice driver. Also i have heard of people only running a serious brake pad compound for the front and a less aggressive pad for the rear, what is the logic behind this? the only one i see is cost effectiveness? Any detrimental effects with driving?
Can anybody help me narrow down choices, with their own experience? Information on car: 2000 2.5rs weighting in at 2750 roughly 2006 wrx motor with boltons going to be around the 300 whp range subaru 4pot/2pot brake setup If more information is needed please let me know
#27 |
Member#: 240135
Vehicle:2009 Sub Legacy GT Black |
![]() They squeel like ****
I tried to live with it but my wife wouldn't. Sold tem after 100 miles and went back to stock pads on DBA 4000 slotted rotors, which do a great job |
#28 |
Member#: 217458
VIC
Vehicle:1989 Mazda Miata Classic Red |
![]() Anyone else have experience with HP+ pads? How are they if you are just putting them on for HPDE or 'lapping' days? Are there better Hawk pads for track performance?
#29 |
Member#: 124113
Vehicle:Pura vida! Yellow V standing by |
![]() They should be good for HPDE/open track days. Of course there's better Hawk pads than something good enough. If you're going to go through the trouble of running 2 sets of pads for track and street, get something better for the track. HT-10 should do it for that level. Hawk is far from the only company out there, though.
#30 |
Member#: 217458
VIC
![]() True Hawk isn't the only manufacturer but they seem to be good performance for price. I see people talking about Stoptech too.
Any links to good deals on pads? |
#31 |
Member#: 205857
![]() Tons of great info! Thanks very much! I fall into the Time attack- Auto cross catagory.. I drive a 07 STi. I would love some suggestions about brands and proven set ups of fellow racers.. Currently using Hawk hps HB180f.560 in the rear and hb453f.585 in the front. This set up works very well for daily driving and hard driving track days but seem to fade a bit after 2-3 laps.
#32 | |
Member#: 125739
South East
Vehicle:2007 1500HD Need Brakes? 919.420.0021 |
![]() Quote:
By now we sell very few race pads that fit any of the small non-STi Subaru brakes. There simply is not enough mass to combat the heat effectively. I have some dusty DTC60 front/HT-10 rears in here if you want to prove it to yourself. It is what it is peeps - the cars are too fast and the brakes are too small. Physics win every time. |
#33 | |
Member#: 125739
South East
![]() Quote:
Carbotech is your friend on this one - but do yourself a favor and consider your upgrades carefully - the front needs help pretty quick on track. |
#34 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
#35 |
Member#: 125739
South East
#36 | |
Merci Buckets
Moderator Member#: 88606
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
![]() Quote:
For track use you should really use a track pad. If you can force yourself to NOT run full-bore at the race track you can get more of a dual-duty auto-x/track pad like the Hawk HP+, Carbotech AX6, or Ferodo DS2500. If you are really hardcore about track days then your best option is to have two separate sets of pads for track and street use. Keep your HPS for the street and buy the Hawk HT-10 or Carbotech XP10 for track use. |
#37 |
Member#: 188986
Vehicle:2007 WRX Wagon Silver |
![]() I have a '07 WRX wagon with EBC yellowstuffs all around. I've been using them for about 10,000 miles and about a season and a half of auto-x. Has anyone had experience with them vs. the Hawk HPS pads and if so was there a difference? They seem fairly similar performance-wise. I don't care about dust or noise unless it's insane. Along those lines I have some track days waiting in the wings. Would it be better to get some Hawk HP Plus pads for that to help slow the hefty wagon? And if that's the case, can you safely use the HP Plus pads on the street day in and day out? I know it's probably best to have 2 sets of pads but I'm trying to save some money if possible.
#38 |
Member#: 246878
RMIC
Vehicle:2008 WRX sparkling silver |
![]() Amazing write up, thanks for putting the time in to write that! I really appreciate hearing the options from someone who isn't trying to sell one to me.
#39 | |
Merci Buckets
![]() Quote:
Something like the Hawk HP+ or Carbotech AX6 is going to be a much better pad if you intend to do track days. Its not going to provide the same level of performance as a track pad (friction coefficient and heat resistance), but its going to be a lot better than a street oriented pad. Either one of them would be acceptable for street use, though you'll want to pay attention to the cold grip as temperatures start to drop in the winter. When cold they won't have the same initial bite and it will likely take a little longer to stop. How are your current brake pads? Decent life left or nearing the end? I know several people who daily drive with full-bore track pads during the summer. They squeal more than a city transit bus, but they provide sufficient braking for the daily commute. If you don't mind the noise and the dust you could do the same and save your current pads for winter use when the track pads aren't going to function. |
#40 |
Member#: 188986
![]() Hey thanks for the response and the good info. My current pads have a decent amount of life left so I think I'll try the HP+ pads as summer is approaching now anyways. Thanks again
#41 | |
Member#: 248752
Vehicle:2006 WRX STI White |
![]() Quote:
I have an 06 WRX STI and I have the original brake pads on the car but they are at the end of their life and need to be replaced but I do not want to spend the 500 dollars that it will cost to get the OEM pads, especially if they are not going to perform as well as some aftermarket brake pads. As of right now I don't take my ride to the track at all as I never have any time so I am really just looking for pads that are good for road driving and the occasional messing around. After reading the article I am not sure which material to go with. I would like good performance but I also don't want to have to clean up a lot of brake dust and I don't want them to be overly noisy. Any suggestions? I would like to stay in the range of no more than $150 for the front and around $100 for the back if possible. |
#42 |
Member#: 166576
Vehicle:2003 Impreza WRX WRB |
![]() Great article, tons of useful information.
#43 |
Member#: 214359
South East
Vehicle:2005 WRX WRB |
![]() thanks for the write up, i just printed and taped it up in the garage next to the toolbox and Manifesto!
#44 |
Member#: 144210
Vehicle:2007 STI Urban Gray Metallic |
![]() What category are the OEM brakes on a 2007 STI? Is it worth replacing with OEM or are aftermarkets still very good even at less than half price? (I'm quoted by my dealer $1450 for OEM, $700 for aftermarket, though they didn't say which aftermarket models...)
#45 |
Member#: 122980
South East
![]() $1450 for PADS???
![]() Protip: Dont go to the dealer, the pads are super easy to install yourself. ![]() |
#46 |
Member#: 144210
![]() Sorry, they want to do rotors and everything, not just pads. Some friends think I'd be OK with just pads and turn the rotors this time though. I'm just trying to find out if OEM is worth the money or not compared to aftermarket pads&rotors
#47 |
Member#: 122980
South East
![]() Oh, well even so, if you wanted to do rotors at the same time, Ken has rotors with the Stoptech pads for just over $400 and with the HPS pads for a few bucks more. If you arent tracking the car, one of those would be a safe bet.
Theres no way in hell I would pay $700 for either of those. I assume part of that is labor, but still, its a piece o' cake to swap out yourself. ![]() |
#48 |
Member#: 125739
South East
![]() Damn...I need to start hiring you guys! Yeah man, that is way too high of a price. I bet they are charging to turn your rotors as well. Please do not pay that much...You can call me and i will walk you through your brake job step by step for a good I trader rating.
#49 |
Member#: 122980
South East
![]() Speaking of, I need to swing by and get the pads for the Legacy. Im fairly sure I cant bend the squealers back too much more.
#50 |
Member#: 179384
Vehicle:2012 DGM WRX Ltd. 02 WRB WRXTi in process |
![]() that was not only a super informative article, but a fantastic read! thanks so much for taking the time to educate, it certainly has given me some great insight.
DIY - How to replace Stock STI Brembo brake pads | CLR4ILS | Brakes, Steering & Suspension | 17 | 11-14-2015 02:55 PM |
Article: How To Clean your Exhaust Tips | blue-sun | Mid West Subaru Owners Club Forum -- MWSOC | 20 | 05-15-2012 03:04 PM |
Endless Brake parts for Street and Track | dentsport | NESIC Vendor Classifieds | 4 | 04-11-2009 01:52 PM |
Brake pads for lazy butts who street and track | chimchimm5 | Brakes, Steering & Suspension | 50 | 12-21-2008 04:51 AM |
FS: Carbotech Panther Plus - street/track brake pads - BRAND NEW | eclip5e | NESIC Private Classifieds | 10 | 04-18-2006 10:54 PM |
