#1376 |
Member#: 219492
Vehicle:17' 5mt XV & 02 WRX @comrad |
#1377 |
Member#: 159474
NESIC
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
#1378 | |
Member#: 74392
Vehicle:15 Foz SWP |
![]() Quote:
#1379 |
Member#: 159474
NESIC
![]() I thought about that, but 35 is such a thin/short sidewall... I dunno. Lemme marinate on that for a hot minute.
Just researched real quick. Looks like that size is the best way to retain my stock wheel ratio. It saves me 1 pound each tire too! Overall I'll be adding .1 pound each wheel over stock wheel weight (including tires). |
#1380 |
Member#: 74392
#1381 |
Member#: 368968
![]() where did you buy the rims from ?
Iam looking for a pair myself ![]() |
#1382 |
Member#: 185030
AKIC
Vehicle:2016 FXT Satin White Pearl |
![]() From me
#1383 |
Member#: 368968
#1384 |
Member#: 219492
![]() 245/35 Is a bit tiny.
IMO 245/40 or 255-265/35. Only tire sizes worth looking at for 8.5/9.5" wheels |
#1385 |
Member#: 159474
NESIC
![]() Realization #1: I forgot my snow tires are 255/45R18, not 245. More reason why they rub lock-to-lock.
![]() Realization #2: No warranty for cleaning corrosion buildup at battery terminals. $50, everything looks as good as new! Realization #3: Bayson R full STI lip kit comes in with my Seattle stock load today! ![]() I don't think 35 sidewall is THAT thin-looking. We'll see what happens. I'm liking the idea of saving weight and have wider tires. 255/35R18 sounds kinda hot. Also heavy, so probably not. Either 245/35 or 245/40. |
#1386 |
Member#: 159474
NESIC
![]() Realization #4: My STI cover on my new fender garnish doesn't sit flush against the garnish piece. I'm going to have to find some thick, double-sided tape to put behind it to keep it down. Kind of annoying. You can only tell when you're looking down the car from back to front and mostly up close.
#1387 |
Member#: 159474
NESIC
![]() @Woyiq: Still takin' dem kinda pics, bruh.
![]() Bayson R STI Replica Lip Kit |
#1388 |
Member#: 185030
AKIC
![]() Install all the parts!
I'm still waiting for that Nam.. *gets choked out by ninjas* |
#1389 |
Member#: 150248
SCIC
Vehicle:08 FXT Sports WRB |
![]() At some point, I'll break down and get that same kit...glad to see he sells it all together now.
I'd be tempted to grind the sideskirts a bit to look more like OEM, though. Like round off that sharp corner at least. |
#1390 |
Member#: 36125
NWIC
![]() I think some of the front lips look good but I scrape already. When I get new coilovers it's going to be worse. You have a problem with that at all?
#1391 |
Member#: 301431
AKIC
Vehicle:2005 Evolution VIII |
![]() *lurking cause no care, cause no installed pics*
#1392 |
Member#: 219492
#1393 |
Member#: 36125
NWIC
![]() Yeah I try my best but they love crowned roads here due to the rain. Most modern construction isn't bad, but the town I work in used to flood frequently in the 30's and 40's and most of the roads still reflect that. Turning off the street feels like driving into a ditch sometimes. So dumb.
#1394 | |
Member#: 380757
Vehicle:2014 Frs Black |
![]() Quote:
#1395 | |
Member#: 289693
Vehicle:2013 BRZ Sterling Silver Met. |
![]() Quote:
My 235/40/18 were perfect. If you would like I am going to start test fitting a lot of different styles soon, I can try and get you pictures. |
#1396 |
Member#: 159474
NESIC
![]() I was looking at pics of 35 vs 40 sidewall and it honestly doesn't look much different to me. I've driven on 40 sidewall plenty of times. The question is: Can I live with the rougher ride of 35 sidewall? Alaska's roads are very uneven, although I do my best to drive on the raised parts and I don't run over potholes. I might have to succumb to being a victim of circumstance and realize that I live in Alaska and having thinner sidewall tires is probably not the best idea. I do like the thought of having even more road communicated to me, though...
#1397 |
Member#: 36125
NWIC
![]() For what it's worth I'm doing staggered 255/35 and 225/40
I'm sure that will totally help with yer decision ![]() |
#1398 |
Member#: 356438
Vehicle:2013 BRZ Premium 6MT Dark Grey Metallic |
![]() I'm rolling 235/35/18r, been up and down the Staten Island Expressway a few times this year, no issues with them. Good luck finding a road more roughed up than that warzone. yeesh.
#1399 |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
#1400 |
Member#: 159474
NESIC
![]() Thanks for the input guys. I think it might also depend on the suspension I go with. There will be considerable gap if I get 245/35R18 tires at stock ride height. Even a 1.4" drop with Eibach Sportline springs might not be enough to satisfy my thirst for stance.
Examples of 245/35R18 at least in the rear wheels: ![]() ![]() ![]() My lip kit should be getting installed in about 90 minutes. It's snowing right now, but I'm going to try and wash my car before showing up so I can keep the areas clean beforehand and take pictures afterwards. I forgot the STI emblems, so those will be applied later. Anyone have any idea on mounting the front STI emblem for the grille? I haven't really looked at it yet. Just a buncha random plastic assortments, like a backing piece and some screws. |
