04-06-2003, 06:22 PM | #1 |
Member#: 30246
Vehicle:0394 WRX/Supra WRB/White |
Threw a cel today!!!???
So today i was driving and i parked my car at the wawa with me and my gf. I get back in the car, go to start it and see something weird.. Flashing Check Engine. I thinkin oh ****.. My mods are MBC @14.5psi, and a GFB BOV 100%, +silencer removed. Now i never overboosted or nothing. There was no cel when i turned my car off either. I just got in the car and went to start it and it was flashing. So offto work i went under the hood in the wawa parking lot. I removed the mbc, took her out for a ride cel still flashing. pulled over and turned the car off, then back on, and the cel was gone.
What could have caused the flashing cel... BOV at 100% or MBC(but the boost was at a safe level, and i hardly boosted before i turned the car off initially).???
04-06-2003, 06:46 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Flashing CEL indicates a real-time misfire. Could be a bad plug or coil, bad gas, vacuum leak etc. Unless the light also comes on steady there won't be a code stored.
04-06-2003, 07:19 PM | #3 |
Member#: 11599
Vehicle:02 wrx blue |
04-06-2003, 10:02 PM | #4 |
Member#: 30246
okay, the cel is now back and flashing, and its been sitting for hours... i dont know what happen
now when i put the key in the ignition, the cars fans run and everything turn on and you can hear them working, then they turn off, the boot back up again. Cel light flashing.. Tomorrow im going to remove the bov, could that be a cause? I dont know what else could have caused this.. the car runs fine when the cel flashes, so i dont understand.. someone help me pleasseee |
04-06-2003, 10:07 PM | #5 |
Trust no one
By any chance, did you have the underdash panel off and notice some loose connectors under there, and plug them together? If so this puts the ECU into a diagnostic mode where the CEL will flash and the fans and solenoids may cycle.
In the event this is what happened just unplug those connectors and your car will be fine. |
04-07-2003, 08:06 AM | #6 |
Member#: 30246
i didn't touch anything under the dash.. i donno what to do here.
04-07-2003, 09:55 AM | #7 |
Member#: 30246
CEL is gone.. I reinstalled my stock bypass valve, ran it for a while drove around played and all.. turn the car off, then back on several different times, at different durations of time and the cell has not re-occured. But get this everyone.. i went to autozone to see if they can pull a cel code, they said on the 03 wrx's they can't do because they cant get to the unit or somethin like that....
so i guess autozones can check our 03s? |
04-07-2003, 12:03 PM | #8 | |
Member#: 15533
Vehicle:2010 Dodge Ram Hemi boat, dirt bikes, bobcat |
Tell them the OBD-II plug is located right under your dash. They can scan it, they prolly just didnt want to do something for free cause they were lazy or something..... |
04-07-2003, 12:22 PM | #9 |
Member#: 30246
either that or it was because it started to snow and they were pus$ys and didn't want to go outside.
04-07-2003, 12:29 PM | #10 |
Member#: 16598
TXIC
Vehicle:'09 Civic Si Redline Orange |
I had the P0303 CEL a few weeks ago, myself. I was just under 20K miles when it occurred. The computer said "misfire on number 3 cylinder at cold start". The Subaru Tech at the dealership said it's a common CEL because of the proiximty of the turbo unit to the number 3 cylinder. It's kind of a "vapor lock" condition. Everything checked fine, so the dealer cleared the code and sent me on my way.
BTW: My light stayed on 3 days... |
04-07-2003, 02:59 PM | #11 |
Member#: 30246
the cel came back on again.. and now i can only get 7psi.. i think i gotta take it to the dealer.. F-(k!
04-07-2003, 04:00 PM | #12 |
Member#: 30246
Okay, so i reset my ecu and that didn't work. Im still getting the fluctuation idle and the fast blinkin cel. Here is in detail what happens. COLD Start, cel comes on and flashes, after 10-15 min of driving if i turn the car off, then back on, the cel is gone and idle is normal. Warm start, cel comes on, then if i drive around for 10-15 min again and turn off, the cel is gone.
From what i have noticed there is no difference in performance, car sounds the same and evverything, just a rough idle and flashing cel. 1. time it wouldn't boost past 7psi, but that didn't happen again. So what can this be, im totally confused, and what could have caused this to happen? |
Threw a CEL today, need help | Imppy | Normally Aspirated Powertrain | 1 | 09-22-2003 05:13 PM |
Threw my CEL today | nick robinson | Normally Aspirated Powertrain | 5 | 06-17-2003 09:52 AM |
Threw a CEL today, how worried should I be? | sir_aspen_white | Normally Aspirated Powertrain | 9 | 04-23-2003 12:20 PM |
threw first CEL today any thoughs? | STiStyle | Newbies & FAQs | 2 | 01-23-2003 11:00 PM |
Help: Threw a CEL today | MrWRXNYC | Tri-State Area Forum | 14 | 05-15-2002 05:54 PM |
