Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 03-01-2007, 01:46 PM   #1
scottvw13
Member#: 63131
05 STI
Crystal Grey
Default Best STU Tire for 2007? Need some help choosing!
Ok, I know this has been discussed to some degree, but I can't really make heads or tails of my search results.
I am looking for an STU tire for 2007. I'd like a 245/40/17. These will be daily driven, so I'd prefer not to have to shave. I run in and around CT, mostly on asphalt.
I would appreciate ANY opinions regarding the following, and any I might have missed.
My decision comes down to the following:
Falken 615 - Not really crazy about 245/35/17 size. Sounds like it has one of the better sidewalls. Good price.
Yoko Neova - Right size, performance, etc. Wrong price. I'd rather not spend $1k plus. Aside from price, it sounds like this is the tire to have
Hankook Z212 Good bang for the buck, but sloppy sidewall. Rather not have to shave.
RE070 right price, but how much performance am I giving up with the 225 width?
Advan 046 - The stock evo tire. Better performing than the Re070? About the same price, can be purchased used for cheap
RE01R - At the moment, this is where I am leaning. Right size (245/40/17) decent price. Seems like performance very close to Neova at $250 a set less cost.
Is there anything else I am missing? Anything that will be coming out during thenext month or so?
Thanks very much for your help!
scottvw13 is offline   Reply With Quote
Old 03-01-2007, 02:55 PM   #2
BlkWRXWag
Member#: 31821
2015 DS WRX
Well, the best tire is the Neova. However, if money is a concern, I would probably go for the RE01R. I don't think the Falken 615 comes in a 245/35/17. AFAIK, it is 245/45/17 only. Plenty of people use the Falken - personally I did not like them for STU, but they are cheap and good.
BlkWRXWag is offline   Reply With Quote
Old 03-01-2007, 03:03 PM   #3
Chiketkd
Member#: 71634
In hibernation...
Listen to Max (BlkWRXWag). He's the '06 National Pro Solo Champion in STU. FWIW, I've heard that Neovas are as fast if not slightly faster than Toyo RA-1's (r-comps) in a similar size.
Chiketkd is offline   Reply With Quote
Old 03-01-2007, 03:11 PM   #4
Funky
Member#: 11520
2005 STi (retired)
Obsidian Black
For doing regional stuff when tire money is a concern I'd do RE070. If you are doing national stuff, Neovas are it. (contingency money can help offset their increased cost assuming you win)
Looking forward to meeting you at Atwater Max!
Funky is offline   Reply With Quote
Old 03-01-2007, 03:19 PM   #5
BlkWRXWag
Member#: 31821
2015 DS WRX
Well, it depends on your region RE070's are a great tire though - you're not giving up much to a Neova.
See you in Atwater Funky. You should come down here for the El Toro Pro.
Old 03-01-2007, 03:23 PM   #6
scottvw13
Member#: 63131
05 STI
Crystal Grey
This is great info guys, I do appreciate it.
Surprising amount of respect for the factory stockers, despite the width disadvantage.
What do you guys think about the RE01R's compared to the RE070's?
Old 03-01-2007, 04:00 PM   #7
vanskater
Member#: 103630
sliver
i like my Hankook vents RS-2
vanskater is offline   Reply With Quote
Old 03-01-2007, 05:17 PM   #8
BlkWRXWag
Member#: 31821
2015 DS WRX
Again, a fine choice locally although I believe the sidewall is a bit soft for a STI.
Hancook is offering contingency this year, so you might get a few more people trying them in STU.
I would try the RE01R, but they don't pay Contingency. I won enough money last year for 3 sets of Yoks.
Old 03-01-2007, 05:34 PM   #9
AndrewSS
Member#: 51674
2005 Subaru WRX STi
WRB/GOLD
I am almost 100% set on getting hankook RS2's this season. They are a good tire from what I have read they have great grip, just a bit of a soft sidewall... but thats not a "huge" problem... I ran neova's this season and they were good but I dont wanna pay big $$$ again....
AndrewSS is offline   Reply With Quote
Old 03-01-2007, 05:46 PM   #10
Funky
Member#: 11520
2005 STi (retired)
Obsidian Black
I had thought about doing El Toro, but couldn't work the trip into my schedule with the long drive and all. I'm registered for Atwater already, #14STU, should be good fun.
Old 03-01-2007, 08:44 PM   #11
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
Ive driven on the RT615's, RS2's, and RE070's. I like the 615 and re070s the best out of those. The hankook has too soft a side wall for my preference. Since you will be DDing the car, I recomend the RE01R. I have heard great things about this tire, and it is up there in my choice for next tire
Crash477 is offline   Reply With Quote
Old 03-02-2007, 12:39 AM   #12
tuskenraider
Member#: 65699
15 WRX
WR Blue
So anyone tried to alleviate the soft sidewall of the RS2 by running them with 50lbs. or so of air before giving up on them?
tuskenraider is offline   Reply With Quote
Old 03-02-2007, 10:09 AM   #13
PhilC
Member#: 35190
2003 WRX STX #77
www.soloracer.com
You're much better off just tuning the car for the tire than trying to tune the tire to the car. Setup for the RS-2s is not the same as the setup for the old 215s is not the same as setup for the 615s is not the same as setup for the Neovas.... You get the idea. Each tire preforms best when it is worked a slightly different way and few people have spent the effort to tune a car to the RS-2s, everyone just repeats the "they have soft sidewalls" line. Simple example, the Neovas like a lot less static camber up front than the 215s did.
You can win national events on any of the tires listed IMO, you just can't cookie cutter someone else's setup from a different tire. When everyone used the 215 you could pretty well copy another persons setup but with the different tires that is just not the case anymore.
I find it curious that the OP feels the Hankooks would need shaved but you think the REs and Neovas wouldn't. I've seen all three start to chunk even when shaved.
PhilC is offline   Reply With Quote
Old 03-02-2007, 10:58 AM   #14
Silencer
Member#: 35998
2003 Evolution
Tarmac Black, #76 STU
lol, Max got beat by the RE-01R's at the 06' Solo2 Nat's and the AD07's are not close to the RA-01's.
Sorry Max, just giving your fan club a hard time.
Dave
Silencer is offline   Reply With Quote
Old 03-02-2007, 11:03 AM   #15
Silencer
Member#: 35998
2003 Evolution
What about the Continental ContiSportContact or the newest "3" version. Baring the results at Nat's, how did Steve Rankins like them overall?
There's also the Dunlop Direzza DZ101's. Anyone run these?
Dave
Old 03-02-2007, 11:19 AM   #16
Chiketkd
Member#: 71634
In hibernation...
Hey there! I resemble that remark!
Dave
Steve couldn't legally use the ContiSport Contact 3's as they weren't available stateside at the time Nationals took place IIRC... He had to run Contact 2's and finished ~17th. Steve has mentioned that the Contact 3's are much grippier than the Contact 2's though.
Old 03-02-2007, 12:42 PM   #17
BlkWRXWag
Member#: 31821
2015 DS WRX
Dave
Bugger off Dave
He does have a point though - there is not much difference between the Neova and the RE-01R... it comes down to the driver in the end.
I creamed Dave in the Pro, and he just slightly beat me in Champ
Old 03-02-2007, 09:32 PM   #18
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
For the Hankook RS2, you need alot of negative camber, like -3 degrees
Old 03-02-2007, 11:38 PM   #19
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
Which tire do you think would be best for a car running stock-ish camber (-1.0 degrees)? I'm thinking something ultra-stiff, like the RE070?
Mind is online now   Reply With Quote
Old 03-02-2007, 11:58 PM   #20
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
The Falken RT615 would be great, plus its cheap! They have a very stiff sidewall and doesnt need alot of camber..
Old 03-03-2007, 01:09 AM   #21
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
The RE070 (and other Bridgestone tires for that matter) has something that the Falken, Hankook, and basically nobody else has in a sidewall: A concave design. Upon heavy cornering with little camber, it is much more difficult to fold under versus a regular sidewall design since the sidewall basically compresses rather than rolls. For camber challenged vehicles, this is my unequivocal recommendation, seconded only by the RE01R.
-Biggly
DrBiggly is offline   Reply With Quote
Old 03-03-2007, 09:43 PM   #22
Mind
Member#: 109216
08 STI DGM
^Great info. I was not aware that the sidewalls were concave; I knew they were stiff, but not concave.
DrBiggly, does your recommendation also stand for stock-cambered vehicles when considering the availability of other tires in wider sizes (ie RE070 rollover resistance vs. wider tires)?
Old 03-03-2007, 10:10 PM   #23
scottvw13
Member#: 63131
05 STI
Crystal Grey
Thank you all for all of the GREAT info.
I found a set of RE070's with more than half tread for $200 locally, so I wen t that direction based on all the great responses.
If I end up competing beyond the local level, I'll look to spend the extra money on RE01R's or Neovas...
Old 03-03-2007, 10:15 PM   #24
Chiketkd
Member#: 71634
In hibernation...
Good choice. FWIW, the tread width of the 225 RE070 is actually 1/10" wider than the Evo's 235 Advan 046 tire.
Old 03-03-2007, 11:19 PM   #25
REX8
Member#: 24038
OMG you read his profile too!
Ever been on RA-1's? There's still a hefty gap.... Who in the world said that???
Need some help choosing coilovers dtseng01 Brakes, Steering & Suspension 24 07-18-2007 06:47 PM
Need Some help choosing Cams... AXA Built Motor Discussion 8 05-01-2007 02:19 AM
Need some help choosing rims to buy stiguy21 Tire & Wheel 0 01-06-2007 06:39 PM
I need some help choosing a new sys. waitandbleed92 Car Audio, Video & Security 37 04-03-2004 03:58 PM
Need some help choosing some upgrades FlaaB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-04-2002 01:00 PM
