Welcome to the North American Subaru Impreza Owners Club Friday July 10, 2020
Old 06-26-2020, 06:54 PM   #1
Payback45
Member#: 129370
2016 WRX
Default CVT Help
Can someone point me in the right direction of how to change the transmission fluid on a 2016 CVT WRX.
Is this something that can be done at home or is this a take it to a shop job?
I also donít know the fluid capacity of the transmission.
Thanks in advance
Payback45 is offline   Reply With Quote
Old 06-26-2020, 07:05 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Just Google it.
There are multiple videos & directions on how to do this
Samurai Jack is online now   Reply With Quote
Old 06-26-2020, 07:10 PM   #3
Payback45
Member#: 129370
2016 WRX
Default CVT Help
I have and havenít found what Iím looking for
Old 06-27-2020, 12:37 AM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
You drain it, then you fill it, then you bring it up to a specified temperature range, then you either add or remove fluid while it is running.
CosmoTheCat is offline   Reply With Quote
Old 06-27-2020, 07:53 AM   #5
Payback45
Member#: 129370
2016 WRX
Default CVT Help
I have been looking for CVT ATF High Torque, and all Iím finding is 5 gallon containers. Is this not available in quarts?
Old 06-27-2020, 09:48 PM   #6
Payback45
Member#: 129370
2016 WRX
Bump......
Old 06-28-2020, 10:25 AM   #7
Payback45
Member#: 129370
2016 WRX
Will the Amsoil CVT work?
Old 06-28-2020, 11:44 AM   #8
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Doesn't look like it - Amsoil spec only shows it compatible with the regular CVTF (green/blue).
Subaru High Torque is orange. Sometimes you have to pay to play. Maybe you should make friends at the dealer parts department so you can get them to sell you a couple quarts in a Mason or Mayo jar.
When dealer techs perform a drain-n-fill they use 4 to 6 quarts. when they replace a reman CVT they may need a quart or so. They usually just pump it out of the 5 gallon pail. There is a billing part number they use for invoicing quarts on repair orders so the issue is whether they want to go through the hassle of selling it to you.
Old 06-28-2020, 11:48 AM   #9
Payback45
Member#: 129370
2016 WRX
How much would a flush or CVT service cost on average?
Old 06-28-2020, 02:16 PM   #10
Elbert Bass
Member#: 283429
You'd have to call a dealer - every dealer has their own pricing. Sometimes they are bundled. Dealer I worked at used to have a service where we would drain and fill the front differential, rear differential, and ATF/CVT pan. for $275 - $350 depending on which trans you had.
Keep in mind you only get 1/3 to 1/2 the fluid if you drain the pan. The rest is in the torque converter. I know the dealer I worked at only had a flush machine for older "Dexron" type ATF, and would not invest in machines for CVT. Subaru uses 3 different types of CVT fluids that can't be mixed.
Old 06-28-2020, 03:15 PM   #11
Payback45
Member#: 129370
2016 WRX
Sounds like Iíll have a shop do it. Thanks
Old 06-29-2020, 02:34 PM   #12
Jack
Add Lightness
Member#: 13699
not my president
(From General)
How would one determine the correct CVT fluid to use? By VIN? By transmission number? I've got a 13 Crosstrek with a replaced CVT by the dealer under warranty. I've put on about 55k miles and would consider doing a "partial change" as in drain and fill the identical amount by measuring. But if there's any chance I don't have the right fluid....I'm doing nothing.
Old 06-30-2020, 08:54 AM   #13
Elbert Bass
Member#: 283429
It is more or less model specific. You have a GEN II CVT - blue or green color. The two are interchangeble. Use Subaru CVTF-II.
I wouldn't do a thing. If that replacement transmission was going to fail it would have by now. That CVT fluid is pretty robust unless there is a catastrophic failure. I have drained many Gen-I and Gen-II CVTs at 180,000+ miles and the fluid is still clear, plenty of color, fresh smelling, just a tad bit darker.
CVT transmissions do not have a bunch of clutch discs in it that wear and contaminated the fluid so it does not get "dirty" like old 4EAT/5EAT/5AT. That is why Subaru "officially" has no service interval for CVT.
Old 06-30-2020, 03:51 PM   #14
F1EA
Member#: 448622
2019 STI SportTech
CWP
I also don’t know the fluid capacity of the transmission.
Thanks in advance
1st of all... the 2015+ WRX CVTs have an extended 10yr warranty.
Unless you already have a basis for forfeiting that warranty, either do the service at an 100% "authorized dealer" or do no service at all.
Do you have a leak or any reason to suspect your fluid (or transmission) is in trouble?
Dealers should service leaks and and any CVT-related issue under the extended warranty. After 2 or 3 leaks they may choose to replace your entire transmission.
F1EA is offline   Reply With Quote
Old 07-01-2020, 01:45 AM   #15
CosmoTheCat
Member#: 3409
98 My FMIC
The gen 2 CVTs have a set of clutches that can wear.
They do recommend a fluid interval if you're towing.
And the fleet purchasing industry looks at maintenance intervals to calculate cost of ownership when deciding what vehicles to buy. The more things you can leave off the list, the better your vehicles look to a fleet buyer (think rental cars, taxis, etc). PCV valves, brake flushes, transmission services, coolant, spark plugs - all pushed out to or past 100k miles...
The high torque fluid comes in 5 gallon buckets - if you want some, for some reason, bring empty quart/gallon jugs and have them fill them up for you. The stuff is stupid expensive.
Old 07-01-2020, 11:17 PM   #16
Elbert Bass
Member#: 283429
Yes, but with the exception of the transfer clutch none of the other clutches are used to change gear ratios. Even the lock-up clutch is fully engaged above 5-7 MPH. God help you if your trying to tow with a '13 Crosstrek CVT...
