Welcome to the North American Subaru Impreza Owners Club Saturday August 17, 2019
Mid Atlantic Impreza Club
Old 04-14-2018, 10:40 AM   #4151
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
Dropped in my engine and test fitted turbo and intercooler
It's getting close! Had to order some more couplers and bends, but the IC piping is almost ready.
carnz-pj-410 is offline   Reply With Quote
Old 04-14-2018, 03:11 PM   #4152
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
Also installed my rear brakes today, Hawk 5.0 Pads and KNS/DBA 4k rotors
Old 04-21-2018, 10:45 PM   #4153
rathanav
Member#: 318109
2018 WRX
Crystal Black Silica
Just got a WRX last week and first thing I did was pull out that stock head unit!!
rathanav is offline   Reply With Quote
Old 04-26-2018, 02:02 AM   #4154
Lagunagreen
Member#: 410537
2002 Wrx Sedan
Wrb
Installed the turn in concepts 5 speed update linkage and my cusco type II power brace.
Lagunagreen is offline   Reply With Quote
Old 04-29-2018, 07:04 PM   #4155
sork83
Member#: 325152
2016 WRX
CWP
Default What did you really do to your car today? V3.1
Installed Morimoto c-lights in some black housing Depo headlights, then on my car
sork83 is offline   Reply With Quote
Old 04-30-2018, 01:13 PM   #4156
RossLH
Member#: 147839
'03 SRP WRX
'17 NGM SS
Decided to move it to storage, where it will be getting an EJ207 transplant. It wouldn't crank.
Worked on my bike instead.
RossLH is offline   Reply With Quote
Old 05-02-2018, 03:06 PM   #4157
NightKids
Member#: 342610
2013 Impreza WRX
Satin White Pearl
Replaced the leaking steering rack on my 13 WRX with the 15 STi rack. Also added Super Pro SR bushing and Cusco SR Power Brace. Highly recommend this mod.
NightKids is offline   Reply With Quote
Old 05-03-2018, 09:32 AM   #4158
RossLH
Member#: 147839
'03 SRP WRX
'17 NGM SS
Pulled the starter. If I short the terminals, the starter spins but the bendix doesn't engage. I'll borrow a starter for long enough to drive the damn thing to the storage room.
Old 05-12-2018, 11:07 AM   #4159
sork83
Member#: 325152
2016 WRX
CWP
Sold the RPF1s and put the stock wheels back on with some 20mm spacers all around.
Old 05-14-2018, 07:16 PM   #4160
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Painted the window crank handles. Both were heavily sun bleached; unfortunately I don't have a "before" pic. I used Duplicolor Vinyl & Fabric "charcoal gray", which turned out to be a little too light, but close enough. I would say in person it looks closer than it looks in the picture.
- Took the Rotas off the Legacy (put it up on jack stands) so I could make sure the tires aren't flat-spotted. The Legacy has been sitting in the garage for quite a while, not moving, but it might actually move under its own power in the coming month or two.
Tires seem to be fine. May have lost a wheel weight on one of the fronts, as there is a little vibration at highway speed, but I don't think it's due to flat-spotting.
Old 05-14-2018, 07:51 PM   #4161
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
finished my project of deleting the side mouldings on my coupe, i am very happy with the result
Old 05-14-2018, 08:33 PM   #4162
mPAINT3
Member#: 424371
Is that some sort of dash cam on your dash?
mPAINT3 is offline   Reply With Quote
Old 05-17-2018, 10:23 AM   #4163
infinite012
Member#: 74392
15 Foz
infinite012 is offline   Reply With Quote
Old 05-17-2018, 05:48 PM   #4164
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Had some fun on muddy dirt roads on my buddy's property. The summer tires weren't the best in the sloppy conditions, but I didn't get stuck, so it's all good.
Old 05-18-2018, 09:20 AM   #4165
RossLH
Member#: 147839
'03 SRP WRX
'17 NGM SS
Got it running just long enough to get to my storage room. It was pinging audibly on the way. Time to prep the engine for removal and order a replacement...
Old 05-25-2018, 11:22 PM   #4166
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Installed a brand new set of Subaru 20mm sway bars.
D-Rodman is offline   Reply With Quote
Old 05-26-2018, 06:18 AM   #4167
TwinkE
Member#: 11011
2018 WRX STi
Gray
Thursday was wash and decontamination, then yesterday was polishing. Finished everything but the handles and hood scoop.
TwinkE is offline   Reply With Quote
Old 05-28-2018, 09:13 PM   #4168
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Finally swapped back to the original parking brake cables on my 05 Saabaru. Last year I did a full ver 7 STi drive train swap into it and mistakenly used the parking brake cables that came on the knuckles. Turns out that was a big mistake as the cables were too long and resulted it in poor parking brake lock down.
Also got rid of the ugly Enkei PF01 center caps. Got lucky with a set of old Saab center caps I had laying around from a failed attempt at using them Enkei RPF1 a few years ago. They fit perfectly on the new PF01.
Old 05-28-2018, 11:36 PM   #4169
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Made a plywood splitter, yeehaw!
Need to fab the air dam, add a few reinforcements, and a touch up a few cuts then she gets paint. 4 cotter pins to release, I can walk on the lip.
corona672 is offline   Reply With Quote
Old 06-04-2018, 07:59 AM   #4170
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Swapped out both front axles and changed out both front ABS sensors. Turned out both sensor wires had been rubbing the outer axle boot, and the passenger side sensor finally wore through and failed. At least I know what the issue was.
Thanks Pat for the help!
Old 06-04-2018, 09:00 AM   #4171
D-rock240
Member#: 284221
2011 WRX GV SSM
01 Legacy/03 Outback wgns
Took my Outback to Boxerfest yesterday. Glad I took an extra pair of shoes and socks, found out a pair of Columbia shoes I bought are not waterproof
D-rock240 is offline   Reply With Quote
Old 06-06-2018, 12:14 AM   #4172
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Originally Posted by Patrick Olsen View Post
Did a custom redesign of my driver's fender, courtesy of the driver's door. Went to move the car real quick so I could take my Mustang out for a spin. Pulled open the driver's door and it went a few inches and then kind of sprung back towards closing, at that same time I heard that ugly bending metal sound.
http://www.submariner.org/thepno95/P...20contact1.jpg
http://www.submariner.org/thepno95/P...20contact2.jpg
How the hell did the door and fender suddenly decide they wanted to occupy the same space?!?! I've never noticed anything unusual about how the door opens/shuts, like it's got a loose hinge or isn't aligned properly, so this was completely out of the blue.
For now I just bent the fender back out with a bigass screwdriver. The Jessup Crazy Ray's still has 2 green Imprezas as of today, so I'll keep an eye on that and head up there later this week to see about getting a "new" fender.
This door/fender interference continues to randomly occur. I've "straightened" the fender a couple of times over the past couple months. Today it did it again when I stopped to get gas, and it got the fender pretty good - bent it in to the point I knew closing and opening the door would just make it worse. Fortunately, I happened to have a set of hedge clippers in the back seat, so I pulled those out and used them to pry the fender back out so it wouldn't catch the door again.
Old 06-06-2018, 12:32 AM   #4173
CreepyCrawl
Member#: 469605
09 STI Hatch
Originally Posted by infinite012 View Post
Neat, kinda. I’m already a basket case when I park for extended amounts of time so this would be great....but on the other hand I hate my phone so I fear it would be open all the time either way still cool!!
CreepyCrawl is offline   Reply With Quote
Old 06-06-2018, 09:42 AM   #4174
SGT Didymus
Member#: 486863
2018 WRX
Pure Red
Have had my WRX for a little over a week and already installed Perrin shift stop and intake filter, Nameless axleback, RallyArmor Mud Guards.
I have an Accessport but being I'm still in the break-in period (around 500 miles on odo) I'm letting the car settle before installing it.
I'm not new to modifying cars, I had a 2012 Mazdaspeed3 with over $5k worth of mods I did to it before the ex made me get rid of it, so I'm excited to see what the WRX can do.
SGT Didymus is offline   Reply With Quote
Old 06-07-2018, 12:16 PM   #4175
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Flushed and bled the brakes on the Legacy, in conjunction with installing a used Stoptech 328x28mm setup on the front and in anticipation that the car might actually move under its own power at some point in the next couple months. The fluid in the system was ATE Super Blue, which hasn't been sold in 4 or 5 years, which shows how disappointingly long it has been since the car was last operational.
- Rolled the EZ30 in the Legacy over by hand about a revolution or so, just to check if it had "frozen up" while it's been sitting for so long.
