Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 08-02-2018, 11:52 AM   #1
BlobeyeSTi
Member Sales Rating: (41)
Member#: 187877
04 FXTi
OMGHi2U WV: GC, GD & Foz Parts - RS, WRX, STi, FXT & LGT
Post #1: Mostly GD WRX & STi parts but some 04 FXT, 05 LGT & 04 RS parts as well
Post #2: GC parts
Post #3: 2002 Forester parts
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
*Links to albums of individual pictures of each part are located beside each group*
04 FXT Pics: https://imgur.com/a/CM4Qgsf
• 6 Disc $25 (one speaker channel doesn't work)
• Manual Driveshaft $50
• Control Arms $25 each
• Sway Bars $25 each
• Front sway bar mounts $10
• Rear sway bar mounts $10
• Center differential $200
• Front differential $150
• 5 speed transmission case $100
• Output Gear Set 5 Speed 4.44 $200
• Gear Shaft $100
05 LGT Pics: https://imgur.com/a/gQPn9Vq
• Intake manifold $50
• Engine harness $50
• Side feed TGVs $80
• Side feed fuel lines $50
• Gauges auto $75
• ECU auto #22611AJ18B $100
• MAF #22680AA31A $35
• BPV hose $5
• Airbox lid $5
• Intake pressure sensor #22012AA160 $5
• Boost solenoid controller $25
04 Impreza RS
• Shortblock $250
• SOHC Complete Heads $200
• Plastic Intake Manifold $125
• Throttle Body $75
• Fuel Lines $40
• Engine Harness $75
• Crankshaft Pulley $30
• Injectors $40
• Air Assist Injector $35
• Fuel Pressure Regulator $35
• Plug wires $40 set
• Fuel Rail Covers $10 each
• Timing Covers $10 each
GD WRX & STi Parts
Engine & Drivetrain Pics: https://imgur.com/a/xYSVkuV
• 06 STi 5x114 Knuckles $100 each (34k miles)
• 06 STi rear axles $100 each (34k miles)
• 06 WRX front axles $75 each
• New Stainless Steel Clutch Line #SUBCL-115 $20
• Cam Gears: #13320AA000, #13320AA001, #13321AA001, #13322AA000, #13322AA001 & #13323AA001 $100 each
• EJ20 valve covers $40 set
• STi front axle without outer CV $30
• STi clutch master $40
• STi side feed fuel rails with line $50 set
• STi passenger side feed fuel rail with line $25
• Side feed TGVs $80 set
• Purge valve $10
• Purge valve solenoid $25
• STi proportioning valve $20
• Boost solenoid controller bracket $5
• Radiator mounts $10 set
• Power steering reservoir $20
• Power steering reservoir bracket #34633FE001 $5
• 04 WRX steering column with ignition & key $75
• 04 STi steering column with ignition, key $100
• 06 STi steering column with ignition, key $100
• Transmission mount $20
• AC compressor $80 #73110AE021
• AC condenser $40
• STi passenger radiator fan $25
• Radiator coolant hard line $10
• Manifold coolant hard line $10
• Water temperature sensor $10
• Oil dipstick $10
• TMIC hard lines $10
• Oil cap $5
• Oil cap with fill neck $10
• 02-05 WRX cruise control actuator module $20
• Hood prop $5 (2 available)
• Battery tray $5
• Turbo uppipe bracket $5
• Pitch Stop $10
• Left, Right & Center Outer Timing Covers $15 each
• Front O2 sensor plastic cover $5
• AC Lines $25+
Suspension & Brakes Pics: https://imgur.com/a/1Ms6AE1
• WRX STi ABS module #27534FE270 $40
• ABS Sensors: #27540AE000, #27540AE001, #27540AE010 & #27540FE040 $20 each
• 5x114 rotors were turned and never used $50
Exterior Pics: https://imgur.com/a/o4gYp1I
• Driver rear exterior door handle PSM *$20
• Wiper arms $30
• Passenger mirror CGM $25
• Driver mirror no cover black (TR WRX) $25
• Gas lid PSM $10
• Exterior B pillar molding $15 each
• GD Doors $150 each
Interior Pics: https://imgur.com/a/G7vOkeh
• Center rear view mirror sun visor $10
• Visor clips $5 set
• Interior mirror cover right #94251FE000 $5
• Interior upper B pillar trim $10 each
• Interior lower B pillar trim $10 each
• Interior C pillar trim $10 each
• Rear seat trim $10 each
• Trunk latch trim $10
• Door kick molding trim $10 each
• Driver center console side cover $10
• Rear heat vents $10
• Seat belts $40 each
• Seat belt buckles $10 each
• Trunk release cable $10
• Gas lid release cable $10
• WRX trunk hinges $20
• WRX torsion bars $20
• Weatherstripping: Doors, hood and trunk available $5 each
• Fuel pump cover $5
• Jack $5
• Trunk left and right liners $25
• Rear dash $40
• Bugeye door cards $50
Electronics Pics: https://imgur.com/a/QuPpVtK
• 05-07 mirror switch $10
• 02-04 mirror switch $10
• Hazard switch $10
• Engine bay fuse box $25
• Rear view mirror wire cover $5
• Map light $20
• Dome light $20
• 04 WRX ignition & key $40
• 04 STi ignition & key $40
• 06 STi ignition & key $40
• Headlight/blinker switch $25
• Wiper switch $25
• OEM horns $5 (2 available)
• ECU cover $10
• Wiper motor $40
• Positive battery terminal cable $5
• 04/05 WRX fuel tank wiring $20
• DRL module #84067FE060 $10
• DRL module #84067fe000 $10
• 04/05 control unit air bag #98221FE110 $40 (2 available)
• 06/07 control unit air bag #98221FE220 $40
• WRX STI left front air bag sensor #98231FE070 $10 (2 available)
• WRX STI right front air bag sensor #98231FE060 $10 (2 available)
• WRX STI left side airbag sensor #98235FE150 $10 (2 available)
• WRX STI right side airbag sensor #98235FE140 $10 (2 available)
• WRX STI left side airbag sensor #98231FE010 $10
• WRX STI right side airbag sensor #98231FE000 $10
• Airbag harness $25
• WRX STI G Sensor ABS #27540FA022 $10
• WRX STI G Sensor ABS #27540FE090 $10
• Fuel injector resistor module #684227 $10 (2 available)
• Door ajar sensors $20 set of 4 (2 sets available)
• 04/05 WRX STi keyless entry module #88035FE140 $20
• 04/05 WRX STi keyless entry module #88035FE141 $20
• 06/07 WRX STi keyless entry module #88035FE190 $20
• 04/05 WRX STi integrated control module #88281FE160 $20
• 06/07 WRX STi integrated control module #88281FE340 $20
• WRX STI clarion antenna amplifier assembly #86327FE090 $20
BlobeyeSTi is offline   Reply With Quote
Old 08-02-2018, 11:52 AM   #2
BlobeyeSTi
Member#: 187877
04 FXTi
Default FS: (For Sale) WV: GC, GD & GR Parts -RS, WRX, STi, FXT, LGT
Parts are from 1999 and 2000 RS coupes both 5 speeds.
GC Parts
Engine & Drivetrain Pics: https://imgur.com/a/F23PkWq
• Rear subframe $40
• Engine crossmember $80
• Rear differential carrier 'T' subframe $50
• Rear differential $50
• Transmission subframe $25
• 5 speed transmission *$400
• Gas cap $10
• Fuel pump $20
• Fuel pump assembly $20 (1 piece broken)
• Fuel lines $50
• Fuel pressure regulator $25
• Injectors $40 set
• Clutch master $30
• Slave cylinder $30
• Steering rack $75
• Throttle cable $10
• Power steering pump $70
• Power steering reservoir $15
• Power steering reservoir bracket $5
• Ignition coil $20
• Throttle body $40
• Oil fill neck and cap $15
• Cam gears $10
• Axle with one busted CV joint $25
• Intake silencer $10
• Coolant overflow tank $10
• Radiator fans $25 each
• Valve covers $40 set
Suspension & Brakes Pics: https://imgur.com/a/vaSJf0R
• Sway bars $40 each
• Lateral links $20 each
• Trailing arms $40 set
• Endlinks $20 set
• Control arms $25 each
• Brake booster and master $40
• Front ABS sensors $15
• Front brake caliper mount $5
Exterior Pics: https://imgur.com/a/l3wK1sO
• Taillights $75 each
• Scoop black $75
• Hood vents blue $40 each
• Driver door black $100
• Rear bumper $75 (blue & black available)
• Front bumper beam $60
• Black trunk with small wing (no dents needs repainted) $50
• Blue trunk with small wing (has few dents) $50
• Inner fenders $10
• Door windows $40 each
• Hood release cable $10
• Roof trim $40 each (Shipping is really expensive due to size)
• Windshield trim $25 each
• Wiper cowl $25
• Wiper motor & linkage $40
• Sunroof frame $50
• Driver Taillight trim blue $20
• Taillight trim black $20 each
• Quarter panel trim $10 each
• Hood prop $5
Interior Pics: https://imgur.com/a/zlSelwm
• Steering Wheel $20
• Driver airbag $40
• Dash bar $50 (2 available)
• Door handle $20
• Hood release handle $5 (2 available)
• ECU cover $10
• Wire covers for inside door kick panel $10 side
• Gas pedal $20
• Blower motor $50
• Dash cup holder $10
• Rear view mirror $20
• Map light $10
• Seatbelts $40 (no driver front or rear center but have the rest)
• Steering column $50
• Speaker brackets $5 set (2 available)
• Weatherstripping $5
• Tweeter cover $10 each
• Door handle trim and pocket $10 set
• Door panel bolt covers $5 set
• Gauge cluster surround $10
• Seat bolt covers $10 set of 4
• Passenger A pillar $15
• Rear heat vents $20 set (2 available)
Electronics Pics: https://imgur.com/a/3779vWz
• Knock sensor $10 (2 available)
• Sunroof harness $10 (2 available)
• Interior fuse box $20
• Engine bay fuse box $20
• Door ajar sensor $10
• Horn and cruise control steering wheel switch $20
• Antenna with screws $25
• Wiper switch $20
• Airbag sensors $10 each
• Airbag control unit $25
• Alternator to battery cable $10 (2 available)
Old 08-02-2018, 11:58 AM   #3
BlobeyeSTi
Member#: 187877
04 FXTi
2002 Subaru Forester 5 Speed 211k
*Coilovers & wheels are not for sale*
Engine, Drivetrain, Suspension & Brakes
• EJ22 Longblock $400
• EJ22 Intake Manifold (complete minus throttle body and wiring) $150
• EJ22 Throttle Body $75
• EJ22 Engine Harness $50
• 04 RS SOHC Complete Heads $200
• 5 Speed Transmission $400
• Lightweight Flywheel $75
• 6 puck with pressure plate $75
• Intake Manifold (complete minus throttle body and wiring) $150
• Throttle Body $75
• Engine Harness $50
• OEM Header $75
• Straight Pipe Cat Back Exhaust w/Resonator $150
• Rear Differential $75
• Rear Differential Carrier 'T' Subframe $50
• Engine Crossmember $50
• Rear Crossmember $50
• Driveshaft $50
• Axles $50 each
• Sway bars $30 each
• Lateral links $10 each
• Endlinks $20 set
• Steering Rack $75
• Power Steering Lines $25
• ABS Module $40
• ABS Sensors $15 each
• Brake Master $30
• Brake Booster $30
• Brake Calipers $25 each
• Proportioning Valve $20
• Clutch Master $30
• Clutch Slave $30
• Airbox $40
• Plug Wires $40
• Power Steering Pump with reservoir $75
• Power Steering Pump Bracket $10
• AC Compressor $80
• AC Compressor Bracket $10
• AC Tensioner $25
• AC Lines $30 each
• Alternator $65
• Fuse Box $25
• Wiper Motor $30
• Fuel pump $20
• Washer Fluid Tank $15
• Pitch stop mount $10
• Gas cap $10
• Oil dipstick $10
• Oil cap $5
• Oil fill neck $5
• Radiator Mounts $10
• Alternator Cover $5
Exterior
• Headlights $50 each
• Corner Lights $20 each
• Taillights $50 each
• Fog Lights $20 each
• Headlight Trim $15 each
• Taillight Trim $15 each
• Doors $100 each
• Hood $100
• Fenders $75 each
• Front Bumper $100
• Front Bumper Beam $50
• Grill $40
• Lip $40
• Rear Bumper $100
• Rear Bumper Beam $50
• Hatch $200
• Wing $50
• Sideskirts $50 set
• Mirrors $25 each
• Wiper Arms $30
• Trim/Weatherstripping $10+
Interior
• ECU $50
• Bulkhead Main Harness $75
• Fuse Box $25
• Gas, Brake and Clutch Pedal Assembly $75
• Cluster $50
• Dash $70
• Glove Box $30
• Steering Wheel w/Airbag $75
• Passenger Airbag $40
• Seatbelts $40 each
• Steering Column $50
• Key set: Ignition, Locks and Key $50
• Center Dash Cubby $40
• Dual Pop Out Cup Holder $20
• Center Console $50
• Shifter Surround, Boot & Knob $30
• Door Cards $25 each
• Front Heated Seats $80
• Rear Seats $40
• 6 Disc CD Player $40
• HVAC Controls $40
• Heater Core $60
• Blower Motor $50
• Auto Dimming Rear View Mirror w/Compass & Temperature $40
• Dome Light w/Clock $40
• Map Light w/LEDs $15
• Headlight Switch $25
• Wiper Switch $25
• Master Switch $25
• Window Switch $10
• Door Lock Switch $10
• Mirror Switch $10
• Cruise Switch $10
• Fog Light Switch $10
• Rear Wiper Switch $10
• Heated Seat Switch $10
• Interior Plastic Pieces $10+
More pics: https://imgur.com/a/snXEEdk
Old 08-04-2018, 10:22 AM   #4
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 08-06-2018, 11:09 AM   #5
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 08-08-2018, 01:05 PM   #6
BlobeyeSTi
Member#: 187877
04 FXTi
OP Updated
Old 08-10-2018, 10:29 AM   #7
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 08-13-2018, 11:40 AM   #8
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 08-15-2018, 10:09 AM   #9
BlobeyeSTi
Member#: 187877
04 FXTi
OP Updated
Old 08-17-2018, 03:47 PM   #10
BlobeyeSTi
Member#: 187877
04 FXTi
Bump.
Old 08-19-2018, 11:12 AM   #11
BlobeyeSTi
Member#: 187877
04 FXTi
bump..
Old 08-21-2018, 03:44 PM   #12
BlobeyeSTi
Member#: 187877
04 FXTi
OP updated and added some GR parts to post #4
Old 08-23-2018, 08:30 PM   #13
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 08-25-2018, 06:54 PM   #14
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 08-27-2018, 12:53 PM   #15
BlobeyeSTi
Member#: 187877
04 FXTi
bump..
Old 08-29-2018, 02:20 PM   #16
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 09-02-2018, 01:54 PM   #17
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 09-05-2018, 01:29 PM   #18
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 09-07-2018, 10:12 AM   #19
BlobeyeSTi
Member#: 187877
04 FXTi
bump..
Old 09-11-2018, 02:43 PM   #20
BlobeyeSTi
Member#: 187877
04 FXTi
OP parts list and pictures updated
Old 09-14-2018, 01:33 PM   #21
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 09-17-2018, 01:05 PM   #22
BlobeyeSTi
Member#: 187877
04 FXTi
bump..
Old 09-20-2018, 11:59 AM   #23
crisco555
Member Sales Rating: (19)
Member#: 56339
2005 saabaru x 2
"wash me"
Looking for drivers side window switches
crisco555 is offline   Reply With Quote
Old 09-21-2018, 12:19 PM   #24
BlobeyeSTi
Member#: 187877
04 FXTi
For what car? Only ones I have are from a 06 WRX TR
Old 09-25-2018, 12:19 PM   #25
BlobeyeSTi
Member#: 187877
04 FXTi
bump..
