Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 09-27-2018, 12:16 PM   #26
BlobeyeSTi
Member Sales Rating: (41)
Member#: 187877
04 FXTi
bump...
BlobeyeSTi is offline   Reply With Quote
Old 09-27-2018, 09:55 PM   #27
crisco555
Member Sales Rating: (19)
Member#: 56339
2005 saabaru x 2
"wash me"
Originally Posted by BlobeyeSTi View Post
For what car? Only ones I have are from a 06 WRX TR
that would work. looking for any wrx 2002-2007.
crisco555 is offline   Reply With Quote
Old 09-28-2018, 02:46 PM   #28
BlobeyeSTi
Member#: 187877
04 FXTi
PM sent
Old 10-01-2018, 10:49 AM   #29
BlobeyeSTi
Member#: 187877
04 FXTi
Updated OP
Old 10-03-2018, 03:49 PM   #30
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 10-05-2018, 01:08 PM   #31
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 10-08-2018, 11:15 AM   #32
BlobeyeSTi
Member#: 187877
04 FXTi
bump..
Old 10-09-2018, 12:21 PM   #33
SleepingWrex
Member#: 448222
Silver Metallic
Parts list & pictures updated: 10/1/18
Mostly GD WRX & STi parts but some 04 FXT & 05 LGT parts
GC parts post #2
GR parts post #3
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
*Links to albums of individual pictures of each part are located beside each group*
04 FXT Pics: https://imgur.com/a/CM4Qgsf
TMIC splitter $20
6 Disc $25
Power steering pump $45
Red OEM mud flaps $40 set
Rear Differential $200
ACT 6 puck & pressure plate $150
ACT lightweight flywheel $100
Driveshaft $50
Rear Axles $50 each
Control Arms $50
Sway Bars $25
Blown 5 speed - I think it was 3rd gear again make offer
05 LGT Pics: https://imgur.com/a/gQPn9Vq
Intake manifold $50
Engine harness $50
Throttle body $40
Side feed TGVs $80
Side feed fuel lines $50
Turbo inlet $15
Gauges auto $75
ECU auto #22611AJ18B $100
MAF #22680AA31A $35
BPV hose $5
Airbox lid $5
Intake pressure sensor #22012AA160 $5
Purge valve $10
Purge valve solenoid $15
Boost solenoid controller $25
04-09 Legacy all weather subaru mats $40
GD WRX & STi Parts
Engine & Drivetrain Pics: https://imgur.com/a/xYSVkuV
5x114 Knuckles $500
STi driveshaft *$200
EJ20 valve covers $40 set
STi front axle without outer CV $30
STi clutch master $40
STi clutch master line $20
STi side feed fuel rails with line $50 set
STi passenger side feed fuel rail with line $25
Side feed TGVs $80 set
Coolant crossover pipe $20 (3 available)
Purge valve $10
STi proportioning valve $20
BPV with crush mod no elbow $25
WRX STi blow off valve adapter for FMIC $30 (new)
Boost solenoid controller $25 (2 available)
Boost solenoid controller bracket $5
STi fuel pump controller $50 #22750AA000 (2 available)
Radiator mounts $10 set (3 available)
Power steering reservoir $20 (2 available)
Power steering reservoir bracket #34633FE001 $5
Power steering lines $30
04 WRX steering column with ignition & key $75
04 STi steering column with ignition, key & remote $100
06 STi steering column with ignition, key & remote $100
Pull type clutch fork pin (5 or 6 speed) $20
Transmission mount $20
AC condenser $40 (2 available)
STi passenger radiator fan $25
Coolant overflow tank $10
Starter $50
Radiator coolant hard line $10 (2 available)
Manifold coolant hard line $10 (2 available)
Oil dipstick $10 (2 available)
TMIC hard lines $10
Oil cap $5
Oil cap with fill neck $10
02-05 WRX cruise control actuator module $20
Hood prop $5 (2 available)
Battery tray $5
Turbo uppipe bracket $5 (2 available)
Pitch Stop Mount $10
Grimmspeed uppipe to turbo gasket $10 new
OEM intake manifold to TGV gasket $5 new
Timing Covers: center(2) and right available $10 each
Front O2 sensor plastic cover $5
AC Lines $25+
Suspension & Brakes Pics: https://imgur.com/a/1Ms6AE1
Front sway bar mounts $10
Rear sway bar mounts $10
STi LCA bushings $40 set
WRX STi ABS module #27534FE271 $40
WRX STi ABS module #27534FE270 $40
ABS Sensors: #27540AE000, #27540AE001, #27540FE050 $10
5x114 rotors were turned and never used $50
WRX rear calipers $60
Exterior Pics: https://imgur.com/a/o4gYp1I
BBS center caps $25 each (2 available)
04/05 right headlight bracket $10
Passenger front exterior door handle PSM *$20
Passenger rear exterior door handle PSM *$20
Wiper arms $30 (2 sets available)
Passenger mirror CGM $25
Driver mirror no cover black $25
Passenger mirror no cover black $25
Gas lid PSM $10
Exterior B pillar molding $15 each
Doors $150 each except for rear passenger is $100 because no glass (driver front sold)
Interior Pics: https://imgur.com/a/G7vOkeh
Visor clips $5 set
Center rear view mirror sun visor $10
Interior mirror cover right #94251FE000 $5
Interior upper B pillar trim $10 each
Interior lower B pillar trim $10 each
Interior C pillar trim $10 each
Rear seat trim $10 each
Trunk latch trim $10
Door kick molding trim $10 each
Driver center console side cover $10
Rear heat vents $10
Seat belts: passenger front and all rear available*$40 each
Seat belt buckles $10 each
Trunk release cable $10
Gas lid release cable $10
WRX trunk hinges and torsion bars $20
Weatherstripping: Doors, hood and trunk avaiable $5 each
Fuel pump cover $5
Jack $5 (2 available)
Tool kit #97010FE040 $10
Driver Trunk Side $20 (no jack cover)
Rear dash $40
Bugeye door cards $50
Bugeye front seats $50
Bugeye rear seats $50
Electronics Pics: https://imgur.com/a/QuPpVtK
Headlight leveling switch $10 (2 available)
05-07 mirror switch $10
02-04 mirror switch $10
Hazard switch $10
OBD II port $10
Engine bay fuse box $25
Rear view mirror wire cover $5
Map light $20
Dome light $20
05 STi ignition with 2 keys & 2 remotes $50
04 STi ignition, key & remote $40
06 STi ignition, key & remote $40
04 STi clockspring $50
Headlight/blinker switch $25 (3 available)
Wiper switch $25 (3 available)
OEM horns $5 (2 available)
ECU cover $10
Wiper motor $40
STi headlight leveling motors $20 each (2 available)
Positive battery terminal cable $5
04/05 WRX fuel tank wiring $20
DRL module #84067FE060 $10
DRL module #84067fe000 $10
04/05 control unit air bag #98221FE110 $40 (2 available)
06/07 control unit air bag #98221FE220 $40
WRX STI left front air bag sensor #98231FE070 $10 (3 available)
WRX STI right front air bag sensor #98231FE060 $10 (3 available)
WRX STI left side airbag sensor #98235FE150 $10 (2 available)
WRX STI right side airbag sensor #98235FE140 $10 (2 available)
WRX STI left side airbag sensor #98231FE010 $10
WRX STI right side airbag sensor #98231FE000 $10
Airbag harness $25
WRX STI G Sensor ABS #27540FA022 $10
WRX STI G Sensor ABS #27540FE090 $10
Fuel injector resistor module #684227 $10 (2 available)
Door ajar sensors $20 set of 4 (2 sets available)
04/05 WRX STi keyless entry module #88035FE140 $20
04/05 WRX STi keyless entry module #88035FE141 $20
06/07 WRX STi keyless entry module #88035FE190 $20
04/05 WRX STi integrated control module #88281FE160 $20
06/07 WRX STi integrated control module #88281FE340 $20
WRX STI clarion antenna amplifier assembly #86327FE090 $20
Still have the power steering pressure lines? Will they work on my 02 wrx?
SleepingWrex is offline   Reply With Quote
Old 10-09-2018, 12:25 PM   #34
SleepingWrex
Member#: 448222
Silver Metallic
Also need a condenser
Old 10-09-2018, 07:36 PM   #35
BlobeyeSTi
Member#: 187877
04 FXTi
I do still have the PS lines and pretty sure the ones I have fit 02-05 WRX but I don't have a bugeye condenser just ones for blobeye/hawkeye. Send me your cell or email and I can send you some pictures.
Old 10-12-2018, 12:31 PM   #36
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 10-15-2018, 12:32 PM   #37
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 10-17-2018, 02:20 PM   #38
BlobeyeSTi
Member#: 187877
04 FXTi
bump..
Old 10-19-2018, 12:57 PM   #39
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 10-24-2018, 01:56 PM   #40
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 10-26-2018, 01:19 PM   #41
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 10-29-2018, 12:58 PM   #42
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 11-02-2018, 02:18 PM   #43
BlobeyeSTi
Member#: 187877
04 FXTi
OP updated
Old 11-06-2018, 01:05 PM   #44
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 11-08-2018, 12:28 PM   #45
BlobeyeSTi
Member#: 187877
04 FXTi
bump..
Old 11-12-2018, 12:16 PM   #46
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 11-16-2018, 12:46 PM   #47
BlobeyeSTi
Member#: 187877
04 FXTi
bump..
Old 11-19-2018, 12:06 PM   #48
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 11-21-2018, 01:49 PM   #49
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 11-22-2018, 09:17 AM   #50
surfthacurl
Member#: 184757
Sti head light leveling motors... i want to order with ya next week... im sending a message as to remind myself. Can i get a pic?
surfthacurl is offline   Reply With Quote
