Welcome to the North American Subaru Impreza Owners Club Friday August 7, 2020
Old 11-16-2018, 03:25 PM   #1
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Default 2006 Subaru WRX TR build thread
So figured I start a build thread
Picked this thing up and immediately ditched the broken home depot lip bumper
Then after throwing it on the lift noticed the eBay coilovers were junk and the shock bodies had so much play in them (felt like a bad wheel bearing) I ditched them and found something a little better (Truharts) temporary of course been focusing on the engine build which I will outline in a second. These truharts are okay definitely better then the eBay ones but are a little bouncy in the rear but again will be going with something better once I'm ready (FEAL? FORTUNE AUTO?)
So on to the engine
So I'm working with Kinetic Motorworks for this build as you can see we went with a close decked EJ 255 heads are going to just be reworked/refreshed(stock)
As far the breakdown goes
BLOCK
Weisco Pistons
Manley Rods
Nitride Crankshaft
Killer B oil pickup
Killer B oil pan baffle
FUEL
ID 1050
AEM Fuel pump
SoCal VF48 20G ported (having the compressor housing ceramic coated)
Grimmspeed EWG up pipe
Tial 44mm EWG (Dumped to atmosphere)
Invidia catless downpipe
Stock STI header (Till BNM Performance starts taking orders again want the Madusa 4-1 UEL)
Cobb Accessport V3
Cobb EBC
Cobb AOS (Air oil seperator)
GDT cylinder 4 cooling system
New Poly motor mounts
Pitch stop mount
Perrin Turbo inlet
Big TMIC
TGV Deletes
STI oil cooler
ACT clutch
Resurfaced flywheel
New oil pump
Water pump
Timing belt
All new bearings
Arp head studs
Headgaskets
Probably missing something but that just about everything Ive ordered so far
BDGWRXTR is offline   Reply With Quote
Old 11-16-2018, 03:57 PM   #2
Calamarii
Member#: 492826
2002 EJ207 WRX Wagon
What's the time frame from buying the car to going for a built motor?
Trying to hit any power goals or just seeing what the build will net you?
Car looks real clean though from the pictures. That mismatched color scoop though..
Calamarii is offline   Reply With Quote
Old 11-16-2018, 04:04 PM   #3
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
I decided to go built motor almost immediately I bought the car maybe a month ago and just waiting on engine machining but should start the swap in a week or two hopefully. I'm shop neighbors with Kinetic Motorworks so I spend alot of time with the guys over there Kyle and Joe are good people. I honestly bought the car with the intent of doing this so yeah haha. Bought I don't have a specific power goal but I'm definitely giving myself room to grow so to speak the transmission is the limiting factor here so I won't be able to push crazy numbers till I get a 6 speed in the car but maybe 350-400 we'll see I have a GTX3071R that would make fore a good rotated setup in the future. Well see where I'm at down the road.
Old 11-16-2018, 05:52 PM   #4
Calamarii
Member#: 492826
I respect the commitment. You do much driving in that pre-build month to get a before and after feel?
Old 11-16-2018, 06:26 PM   #5
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Unfortunately the clutch is toast so I'll never really have a good before and after comparison
Old 11-17-2018, 10:08 AM   #6
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Just got an update from Mike over at United Research and Development LLC compressor housing is all ceramic coated and ready to go
Old 11-17-2018, 11:09 AM   #7
Itsmigz101
Member#: 471378
Niceeee! Subbbb'd
Itsmigz101 is offline   Reply With Quote
Old 11-17-2018, 12:06 PM   #8
Itsmigz101
Member#: 471378
I should have them tune my 18 wrx
Old 11-17-2018, 12:09 PM   #9
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
You absolutely should Ryan does all the tuning at kinetic and he's an awesome dude
Old 11-17-2018, 12:19 PM   #10
Itsmigz101
Member#: 471378
I've heard from a co worker of mine the same thing 🤝.. I'm on a stg.1 ots map from cobb.i can't wait till I go stg.2
Old 11-17-2018, 12:26 PM   #11
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
I've heard from a co worker of mine the same thing .. I'm on a stg.1 ots map from cobb.i can't wait till I go stg.2
Ryan just dyno tuned a 18 wrx stage 2+ made 268whp/327ft lbs of tq they're dyno reads a little low though
Old 11-17-2018, 12:27 PM   #12
Itsmigz101
Member#: 471378
Woah not bad tho
Old 11-17-2018, 09:51 PM   #13
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Kyle at Kinetic just sent me photos of the short block it's all ready to go
Old 11-18-2018, 02:58 AM   #14
nospoolforyou
Member#: 490539
Is it an IAG block?
nospoolforyou is offline   Reply With Quote
Old 11-18-2018, 06:43 AM   #15
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Originally Posted by nospoolforyou View Post
Is it an IAG block?
No its a CSS block it's a local company here in town that does close decking. The service by itself (close deck insert made and pressed in)without machining bare block is $550
Old 11-18-2018, 01:26 PM   #16
Itsmigz101
Member#: 471378
Goood **** so far dude! CSS a few of my turbo honda heads I personally know have been making long lasting records using the CSS blocks with out any issues thus far.. keep it up homie
Old 11-18-2018, 01:28 PM   #17
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Yeah the CSS dudes are big on Honda stuff and all off Kinetics close decking is done through them
Old 11-18-2018, 01:31 PM   #18
Itsmigz101
Member#: 471378
I'm doing an all motor honda setup myself.. was going to do the CSS but don't need it to run so cold being NA.. but this build of yours loving it so far dude
Old 11-27-2018, 03:43 PM   #19
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Progress
Old 11-28-2018, 12:33 AM   #20
PDXREALTOR
Member#: 468393
2017 STI
Looking good... Subscribed
PDXREALTOR is offline   Reply With Quote
Old 11-28-2018, 10:02 PM   #21
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Starting to come together that VF48 20G tho
Old 12-01-2018, 03:03 AM   #22
rwbpanda
Member#: 483035
Nice build, can't wait to see the finished car
rwbpanda is offline   Reply With Quote
Old 12-01-2018, 09:30 AM   #23
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Engines in the car kinetic is just finishing up a few things then I'll get some photos then off to the Dyno
Old 12-01-2018, 02:58 PM   #24
SinisterSkube
Member#: 96012
2005 WRX sedan
Following
SinisterSkube is offline   Reply With Quote
Old 12-03-2018, 03:48 PM   #25
BDGWRXTR
Member#: 494117
2006 WRX TR
Steel Gray Metallic
Engines in and running and on the dyno getting broken in
