Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Old 06-11-2019, 09:17 PM   #1
adventures91
Member#: 349672
2003 WRX Wagon
Default IAG V3 Fuel Rails + Radium Fuel Damper?
I have a set of IAG v3 fuel rails installed on my car and was hoping to install some fuel pulse dampers into the provided ports. However I can't find any information on what the thread fitting is on the damper port that is on the rails.
On Iag's item description it just states in general that the fuel rail is designed to take 8AN ORB fittings but I assume that is referring to the main fuel line fittings and not necessarily the damper port. I assume the port is either an 8AN ORB or 3/8" NPT fitting?
If it is one of those sizes has anyone ran the IAG fuel rails with the radium fuel pulse dampers (FPD-R)? just want to confirm that they will actually fit and will have clearance?
adventures91 is offline   Reply With Quote
Old 06-12-2019, 08:52 AM   #2
goneagain2011
Member#: 293204
2016 STI
3/8" Npt
goneagain2011 is offline   Reply With Quote
Old 06-12-2019, 08:55 AM   #3
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
IAG also sells their own fuel pulse dampers
Turpid Porpoise is offline   Reply With Quote
Old 06-12-2019, 09:56 AM   #4
adesso
Member#: 59892
2004 TP Tuned
GT30R .82 JBP STi
They are NTP as goneagain2011 mentioned. I have IAG rails and Radium dampers on mine. I did have to clearance the rail spacers (shaved one side flat for all 4 spacers) to get the dampers to fit, but that's dependent on which dampers you choose. Just fyi.
adesso is online now   Reply With Quote
Old 06-12-2019, 12:23 PM   #5
adventures91
Member#: 349672
2003 WRX Wagon
Thanks goneagain2011.
Turpid Porpoise IAG discontinued there dampers.
Thanks adesso just called radium and they also said the dampers should work but glad to hear that they are working on your setup. Just ordered a set so we will see for sure.
Old 06-12-2019, 12:30 PM   #6
Turpid Porpoise
Member#: 476573
I had no idea, thats interesting.
Old 06-12-2019, 12:34 PM   #7
adventures91
Member#: 349672
2003 WRX Wagon
Turpid Porpoise yeah I called and asked why and they said they don't recommend running any dampers in any setup. Which is really weird to me. Especially since when I called radium they directly contradicted that and questioned where IAG was getting there info as there tests showed the exact opposite. Radium said they thought the dampers would really help especially in the setup I am running.
I am having some issues since switching to larger injectors that it seems the dampers might help with so we will see.
Old 06-12-2019, 01:13 PM   #8
JSR84
Member#: 469585
What kind of issues out of curiosity?
JSR84 is offline   Reply With Quote
Old 06-12-2019, 01:16 PM   #9
adventures91
Member#: 349672
2003 WRX Wagon
Idle surge and stumbling which are the main things in radiums description that the dampers state they help with. I might have an issue elsewhere but my tuner said these might help so giving it a shot.
Old 06-12-2019, 02:19 PM   #10
JSR84
Member#: 469585
Got it. What size injectors?
Old 06-12-2019, 02:23 PM   #11
adventures91
Member#: 349672
2003 WRX Wagon
1700cc
Old 06-16-2019, 09:04 PM   #12
adventures91
Member#: 349672
2003 WRX Wagon
Well I couldn't get the radium dampers to fit sadly. Going to just go ahead and try the radium rails I think
Old 06-17-2019, 04:44 AM   #13
Long Nguyen
Member#: 422350
Its 3/8NPT. And I run the 3/8 NPT dampers from Radium.
Fits perfectly.
Long Nguyen is offline   Reply With Quote
Old 06-17-2019, 06:34 AM   #14
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Fits perfectly.
Looks like a ton of space there. OP where’s the clearance issues?
bdubblu is online now   Reply With Quote
Old 06-17-2019, 07:47 PM   #15
adventures91
Member#: 349672
2003 WRX Wagon
Those are the generic oem style dampers that radium sells which they did not recommend for my application as they can only handle up to 40 and some psi of fuel pressure. So once you start getting into boost and your fuel pressure exceeds that they no longer have any benefit. I am looking at there after market fpd-r style which handle much more fuel pressure before bottoming out but are also larger then the oem style.
http://www.radiumauto.com/Fuel-Pulse...Kits-P759.aspx
The clearance issue on the fpd-r style is with the mounting bolts and phenolic spacers which I hoped I could shave down but was unable to make work.
Old 06-21-2019, 03:31 PM   #16
goneagain2011
Member#: 293204
2016 STI
Had to modify IAG TGV deletes but they fit
https://drive.google.com/file/d/1-0Q...ew?usp=sharing
Old 06-21-2019, 10:31 PM   #17
dev6565
Member#: 424131
2006 WRX Limited
Google 03 Hyundai Elantra fuel dampers. Those are what IAG used to sell and you can get them for $15 a piece on eBay. That's what I have on my wrx right now and they fit the IAG fuel rails with no issues. No performance issues either that I have found when I'm in or out of boost.
dev6565 is offline   Reply With Quote
Old 06-22-2019, 03:21 PM   #18
bp05obxt
Member#: 459799
I think it should be noted that there has been several cases of these dampers actually causing worse fuel pulsation issues. It is too my knowledge a proper FPR sourced from the plenum (I.E. Cobb’s dampers fix), parallel (soft/flexible) fuel lines, and a proper tune are the best ways to solve the stumbling.
bp05obxt is offline   Reply With Quote
