11-20-2005, 06:50 PM | #1 |
Member#: 58352
Vehicle:04 20G STI(SOLD) 08 z51C6 (growing mullet) |
idiot oil change people overfilled...didn't drain it all out plus added 5 quarts
cold sitting overnight my oil level is a good 2 inches above the notch....any easy way to drain some out from the top? anywhere to buy a tube and a pump like thing....links would be great....I know your suppose to check the level slightly warm but this is way overfilled right?
Matt
11-20-2005, 07:19 PM | #2 |
Member#: 71430
Good reason to change yor own oil. I dont trust anyone to do it right.
11-20-2005, 07:22 PM | #3 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
take it back ..
make them do it again for free its not going to hurt the engine |
11-20-2005, 07:50 PM | #4 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
Driving around with too much oil is not good for the engine. Either:
1. Take it back 1st thing and make them fix it, for FREE. This equates to a new oil change w/filter. 2. Go to an AutoZone/Advanced Auto/etc., get a transfer pump (~$10), and pump out the extra oil. Thing is, if they put in too much oil, they probably never changed the oil filter. See #1. |
11-20-2005, 07:51 PM | #5 | |
Member#: 89528
Vehicle:2005 sti crystal grey |
11-20-2005, 11:24 PM | #6 |
Member#: 87950
Vehicle:2005 STI Gone....Somewhere in MS |
First of all double, triple check your oil level on "level" ground. i checked mine the other day on a small incline and it read over one qt low. Pulled up on a flat surface as I was pretty sure it wasn't low and sure enough it was just right. Still way too much in yours, I'd call first and tell them what you found if you want them to take care of it. Invite them to come take a look if they don't believe you.
With 5 quarts too much they didn't do something right and owe you a total rework, possibly two. Before driving you could pull the plug and drain out either appx half or all and then refill to the appropriate level before driving back. if you don't have far to go and don't want to change anything prior to them seeing it, drive really easy with low RPMs. Hwy61 |
11-20-2005, 11:27 PM | #7 |
Member#: 37617
Vehicle:2007 |
This is another time when a fumoto valve would come in handy. Easy to drain some out...
Things like this are why nobody touches my car but me. |
11-20-2005, 11:52 PM | #8 |
Member#: 87950
Oil Change instructions for Women:
> 1) Pull up to Jiffy Lube when the mileage reaches 3000 miles since > the last oil change. > 2) Drink a cup of coffee. > 3) 15 minutes later, write a check and leave with a properly > maintained vehicle. Money spent: Oil Change $20.00 Coffee $1.00 Total > $21.00 > > ================================================== ========== > Oil Change instructions for Men: > 1) Wait until Saturday, drive to auto parts store and buy a case of > oil, filter, kitty litter, hand cleaner and a scented tree, write a > check for $50.00. > 2) Stop by 7 - 11 and buy a case of beer, write a check for $20, > drive home. > 3) Open a beer and drink it. > 4) Jack car up. Spend 30 minutes looking for jack stands. > 5) Find jack stands under kid's pedal car. > 6) In frustration, open another beer and drink it. > 7) Place drain pan under engine. > 8) Look for 9/16 box end wrench. > 9) Give up and use crescent wrench. > 10) Unscrew drain plug. > 11) Drop drain plug in pan of hot oil: splash hot oil on you in > process. Cuss. > 12) Crawl out from under car to wipe hot oil off of face and arms. > Throw kitty litter on spilled oil. > 13) Have another beer while watching oil drain. > 14) Spend 30 minutes looking for oil filter wrench. > 15) Give up; crawl under car and hammer a screwdriver through oil > filter and twist off. > 16) Crawl out from under car with dripping oil filter splashing oil > everywhere from holes. Cleverly hide old oil filter among trash in > trash can to avoid environmental penalties. Drink a beer. > 17) Buddy shows up; finish case of beer with him. Decide to finish > oil change tomorrow so you can go see his new garage door opener. > 18) Sunday: Skip church because "I gotta finish the oil change." > Drag pan full of old oil out from underneath car. Cleverly dump oil in > hole in back yard instead of taking it back to Kragen to recycle. > 19) Throw kitty litter on oil spilled during step > 18. > 20) Beer? No, drank it all yesterday. > 21) Walk to 7-11; buy beer. > 22) Install new oil filter making sure to apply a thin coat of oil > to gasket surface. > 23) Dump first quart of fresh oil into engine. > 24) Remember drain plug from step 11. > 25) Hurry to find drain plug in drain pan. > 26) Remember that the used oil is buried in a hole in the back yard, > along with drain plug. > 27) Drink beer. > 28) Shovel out hole and sift oily mud for drain plug. Re-shovel oily > dirt into hole. Steal sand from kids sandbox to cleverly cover oily > patch of ground and avoid environmental penalties. Wash drain plug in > 29) Discover that first quart of fresh oil is now on the floor. > Throw kitty litter on oil spill. > 30) Drink beer. > 31) Crawl under car getting kitty litter into eyes. Wipe eyes with > oily rag used to clean drain plug. Slip with stupid crescent wrench > tightening drain plug and bang knuckles on frame. > 32) Bang head on floorboards in reaction to step > 31. > 33) Begin cussing fit. > 34) Throw stupid crescent wrench. > 35) Cuss for additional 10 minutes because wrench hit bowling > 36) Beer. > 37) Clean up hands and forehead and bandage as required to stop > blood flow. > 38) Beer. > 39) Beer. > 40) Dump in five fresh quarts of oil. > 41) Beer. > 42) Lower car from jack stands. > 43) Accidentally crush remaining case of new motor oil. > 44) Move car back to apply more kitty litter to fresh oil spilled > during steps 23 - 43. > 45) Beer. > 46) Test drive car. > 47) Get pulled over: arrested for driving under the influence. > 48) Car gets impounded. > 49) Call loving wife, make bail. > 50) 12 hours later, get car from impound yard. Money spent: Parts > $50.00 DUI $2500.00 Impound fee $75.00 Bail $1500.00 Beer $40.00 Total > - - $4,165.00 But you know the job was done right |
11-21-2005, 12:33 AM | #9 |
Member#: 98638
^lmao
11-21-2005, 12:58 AM | #10 |
Member#: 86798
Vehicle:2005 Legacy GT Black |
Same thing happened to me on my last oil change (Jiffy Lube). I work in a lab so I was able to use a pipet-aid with some tubing and suck it out of the dip tube. Took out about half a quart to get it down to the right level.
I will be doing all of my own changes from now on. |
11-21-2005, 01:01 AM | #11 | |
Member#: 87370
Vehicle:2005 WRX,Soon to be EVO9-94 toyota4x4 project |
11-21-2005, 01:04 AM | #12 | |
Member#: 87370
11-21-2005, 02:43 AM | #13 |
Member#: 51034
Vehicle:03 WRX, 02Forester PSM |
get a 50cc syringe and a matching plastic tubing and just withdraw from the dip stick opening. A can of beer would certainly help , just put the cold beer gently on top of the intercooler ....
syringe $2 , tubing $1, beer $1 total $4......the cooling of the intercooler--priceless. Last edited by ronf; 11-21-2005 at 08:09 AM. |
11-21-2005, 08:05 AM | #14 | |
Member#: 23676
NESIC
Vehicle:. |
11-21-2005, 08:15 AM | #15 | |
Member#: 37617
Vehicle:2007 |
11-21-2005, 08:17 AM | #16 | |
Member#: 3604
NESIC
Vehicle:2008 Infiniti G35S 2005 S2000 |
rotflmao |
11-21-2005, 10:25 AM | #17 | |
Member#: 88698
NWIC
Vehicle:'05 Best e.t. 11.8 Best Trap: 123 MPH |
This is going in my funniest of NASIOC file |
11-24-2005, 01:57 AM | #18 | |
Member#: 87950
Hwy61 There was a long list of this stuff like the oil list a few years back, same kind of thing, I only remember a few. |
11-24-2005, 11:43 AM | #19 |
Member#: 57113
Vehicle:2009 Dodge Ram Blue |
Check your tranny fluid level. He may have drained it instead.
snowboard gear - a ton of it. blowing it all out | mattesonb | Non-Subaru Stuff | 6 | 05-22-2010 05:09 PM |
first oil change.. when'd you guys do it? | alpnwhite96 | Service & Maintenance | 52 | 06-18-2006 06:54 PM |
Quick oil change places - do they do it right? | alotas123 | Texas Impreza Club Forum -- TXIC | 18 | 06-16-2006 04:02 AM |
oil change and overfill | no_rex_yet | Service & Maintenance | 2 | 12-28-2004 11:48 AM |
Just had my oil changed, but they didn't put it all in! | edubb11 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 12-01-2003 08:49 PM |
