Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Old 12-29-2012, 04:33 PM   #1
95impreza72
Member#: 298661
Default need help asap
How do u change rear strut on a 95 coupe impreza
95impreza72 is offline   Reply With Quote
Old 12-29-2012, 09:17 PM   #2
gt601
Member#: 308387
2012 Impreza Sport
white
Not being mean. But... It isn't for some one to tackle unless you have access to the proper tools and a bit of knowledge. A spring that is compressed in the strut housing can injure or kill if it releases without the proper tools. If you have any doubt about your abilities and if you don't have the proper tools I would suggest taking it to a mechanic. You can also get a Haynes manual that will take you through it step by step.
Paul
gt601 is offline   Reply With Quote
Old 12-29-2012, 11:26 PM   #3
95impreza72
Member#: 298661
I no how to work on cars I just never dod a rear strut on one
Old 12-29-2012, 11:28 PM   #4
95impreza72
Member#: 298661
Did**
Old 12-30-2012, 10:30 AM   #5
gt601
Member#: 308387
2012 Impreza Sport
white
It's pretty self explanatory. You remove the whole strut assembly from the car. You then remove the spring and replace the shock absorber. You want to replace struts/shocks in pairs. If one side is bad the other wont be far behind. You will also have even control from side to side. I would bet that if you do a search on this site or even an internet search you will find a step by step procedure.
Paul
Old 12-30-2012, 07:14 PM   #6
95impreza72
Member#: 298661
I no how to do a strut and spring replacement I have a coupe so I need to take the back seat off and dont now how
Old 12-30-2012, 09:17 PM   #7
gt601
Member#: 308387
2012 Impreza Sport
white
Why didn't you ask how to take the back seat out instead of asking how to replace a strut?
Old 01-01-2013, 11:15 AM   #8
Cujo31
Member#: 19843
2000 2.5 RS Sedan
2016 Base 5MT VRP
You have to remove the bottom cushion of the rear seat first. It's two bolts down in the footwell area.
Then, you'll see three bolts at the bottom of the seatback left, right and center. take those out.
lift straight up on the seatback to remove it from the clips at the top. voila, you can see the tops of the struts.
Cujo31 is offline   Reply With Quote
Old 01-01-2013, 11:21 AM   #9
95impreza72
Member#: 298661
Thanks that all I needed
