04-19-2013, 12:22 PM | #1 |
Member Sales Rating: (194)
Member#: 176134
SCIC
Vehicle:1995 Coupe, Sedan & Wagon! |
93-95 Impreza Front Wheel Drive (FWD) Parts
These are from my personal builds over the last 10 years.
I listed each item from the year of the car it from. Some of these will fit 1993-2001. If unsure, please ask! I will do my best to answer. I will gladly combine prices on parts; please send me your offers as well! - Chris Located: Torrance, CA 90503 All shipped prices include PayPal fees! Parts: 1995 Base FWD Front Exhaust Heat Shield & Bolts - $10 + Shipping 1995 Base FWD Middle Exhaust Heat Shield & Bolts - $10 + Shipping 1995 Sedan FWD Middle Exhaust Heat Shield - $10 + Shipping 1995 L Coupe Rear Sub-frame with Bolts - $20 + Shipping 1995 L Sedan Rear Sub-frame with Bolts - $20 + Shipping 1995 L Coupe Drum Rotors / Rear Hubs - $20 + Shipping 1995 Base Drum Rotors / Rear Hubs - $20 + Shipping 1995 L Sedan Drum Rotors / Rear Hubs - $20 + Shipping 1995 L Coupe Rear Lateral Link Tow Bolts - $15 Shipped 1995 L Sedan Rear Lateral Link Tow Bolts - $15 Shipped 1995 Base Coupe Rear Lateral Link Tow Bolts - $15 Shipped 1995 L No ABS Rear Drum Rear Brake Proportioning Valve / Brake Pressure Valve - $15 Shipped 1995 Base FWD Gas Tank (Complete w/ Straps) - $20 Picked Up 1995 FWD Manual Transmission [Disassembled] (See Section for Breakdown) Pictures: 1995 Base FWD Front Exhaust Heat Shield & Bolts - $10 + Shipping 1995 Base FWD Middle Exhaust Heat Shield & Bolts - $10 + Shipping 1995 Sedan FWD Middle Exhaust Heat Shield - $10 + Shipping 1995 L Coupe Rear Sub-frame with Bolts - $20 + Shipping 1995 L Sedan Rear Sub-frame with Bolts - $20 + Shipping
04-22-2013, 02:24 PM | #2 |
Member#: 176134
SCIC
1995 L Drum Rotors / Rear Hubs - $20 + Shipping Worked fine when pulled for an AWD swap. 1995 Base Drum Rotors / Rear Hubs - $20 + Shipping Worked fine when pulled for an AWD swap. Last edited by bue car; 11-12-2018 at 01:45 AM. |
04-24-2013, 01:57 PM | #3 |
Member#: 176134
SCIC
Rear Drum Brake Lines [26531AA020]
1995 L Sedan Drum Rotors / Rear Hubs - $20 + Shipping Worked fine when pulled for an AWD swap. 1995 L Coupe Rear Lateral Link Tow Bolts - $15 Shipped 1995 L Sedan Rear Lateral Link Tow Bolts - $15 Shipped 1995 Base Coupe Rear Lateral Link Tow Bolts - $15 Shipped 1995 L No ABS Rear Drum Rear Brake Proportioning Valve / Brake Pressure Valve - $15 Shipped 1995 Base FWD Gas Tank (Complete w/ Straps) - $20 Picked Up Last edited by bue car; 06-16-2019 at 03:20 AM. |
04-30-2013, 01:17 PM | #4 |
Member#: 176134
SCIC
1995 FWD Manual Transmission [Disassembled] Pulled at 130K The transmission needed a rebuild; the main shaft bearing is toast, and the gears are showing wear from it. The front differential is still in great shape per AQ. I disassembled the transmission and will ship everything. Parts: - Stickers - Cases - $20 Each Side + Shipping - Rear End Section / Cap - SOLD - Front Differential - $60 Shipped - Shifter Arm & Joint - $30 Shipped - 1st-2nd Shift Rod & Fork - $20 Shipped - 3rd-4th Shift Rod & Fork - $20 Shipped - Reverse Shifter Lever, Idler Gear (One Tooth Partially Chipped) & Shaft - $15 Shipped - Main Shaft - $30 Shipped - Drive Pinion Shaft - $40 Shipped (Due to Weight) - Pitching Stopper Bracket & Release Fork Return Spring Bracket - $15 Shipped - Release Fork Cable Bracket - $10 Shipped - Release Fork - $25 Shipped - Neutral & Back-Up Light Switches - $15 Shipped Each Stickers Cases - $20 Each Side + Shipping Last edited by bue car; 06-16-2019 at 03:19 AM. |
05-03-2013, 11:59 AM | #5 |
Member#: 176134
SCIC
Front Differential - $60 Shipped Shifter Arm & Joint - $30 Shipped 1st-2nd Shift Rod & Fork - $20 Shipped 3rd-4th Shift Rod & Fork - $20 Shipped Reverse Shifter Lever, Idler Gear (One Tooth Partially Chipped) & Shaft - $15 Shipped Main Shaft - $30 Shipped Last edited by bue car; 11-12-2018 at 01:43 AM. |
05-06-2013, 01:03 PM | #6 |
Member#: 176134
SCIC
Pitching Stopper Bracket & Release Fork Return Spring Bracket - $15 Shipped Release Fork Cable Bracket - $10 Shipped Release Fork - $25 Shipped Neutral & Back-Up Light Switches - $15 Shipped Each Last edited by bue car; 11-12-2018 at 01:39 AM. |
