Welcome to the North American Subaru Impreza Owners Club Thursday January 18, 2018
Old 05-06-2014, 05:40 PM   #76
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Great videos. I actually used these when I rebuilt a forester long block
Old 01-03-2015, 08:18 PM   #77
PRETTYBLUEPERFORMANC
Member#: 410046
Prettyblue Performance is a family run garage/modification shop located in the heart of Jamaica. We build/modify any make vehicle but we specialize in Subarus. We can safely say that we have some of the most powerful Subarus in Jamaica and the Caribbean. Here is a video showing us driving down to our local drag meet. Enjoy👍
PRETTYBLUEPERFORMANC is offline   Reply With Quote
Old 01-26-2015, 01:47 AM   #78
jordanhernandez
Member#: 411878
1996 Subaru Legacy
Gray
Default Swapping 1996 Subaru legacy RHD
Hey huge question. I just got my 1996 Subaru Legacy L Wagon. Im new to the forms and really would like a accurate way to swap the engine with a wrx motor and 5 spd I will be getting my friends old wrx engine and tranny for cheap just need what else I would need to start the swap. keep in mind my car is RIGHT HAND DRIVE idk if that changes much this is my first Subaru so im making it one of a kind lol plz any help would be appreciated....EJ205 is the motor and the stock WRX 5 spd.
jordanhernandez is offline   Reply With Quote
Old 02-23-2015, 11:50 AM   #79
kevdog99
Member#: 414254
Question... I have just installed a used engine on a 2009 outback 2.5i I now have a engine misfire at 2800 rpms. The light will come on and flash till I get out of the rpm range. I have tried everything to see why this it happening. Switched coils. plugs, wires, cam sensor, crank sensor, redid grounds, mass air flow sensor. Any help would be great
kevdog99 is offline   Reply With Quote
Old 05-31-2015, 12:44 AM   #80
joe_r
Member#: 421445
Thanks for this list of links. Lot's of good info!
joe_r is offline   Reply With Quote
Old 12-13-2015, 07:13 PM   #81
Lark01
Member#: 436073
2005 WRX STI
Default Good Fourm
Very very informative I have bookmarked multiple of these.
Lark01 is offline   Reply With Quote
Old 01-03-2017, 07:19 PM   #82
BadSubby
Member#: 460686
Originally Posted by modaddict View Post
Hey everyone. Here is a good compilation of reading material for when you get bored and want to read up on Subaru engines.
These are just some threads that I thought were great reading and have some very, very good information inside.
If you have a link bookmarked or know of one that you think should be added to the list...just post it up or PM me and I'll add it to the list!
Thanks and enjoy reading!
INTAKE/EXHAUST MANIFOLD
Exhaust pulses and big turbo spool - Theories
http://forums.nasioc.com/forums/show....php?t=1390611
aftermarket intake manifold
http://forums.nasioc.com/forums/show....php?t=1227220
OILING
*Looking for a Crankshaft? List of Crank Manufacturers*
http://forums.nasioc.com/forums/show....php?t=1890852
Available oil pumps and part numbers
http://forums.nasioc.com/forums/show....php?t=1176430
12mm oil pump: feedback, concerns, open discussion and the like wise
http://forums.nasioc.com/forums/show....php?t=1433697
Oiling system: More volume to the crank/rods
http://forums.nasioc.com/forums/show....php?t=1420864
@ what point is STI oil pump not good enough?
http://forums.nasioc.com/forums/show...ghlight=oiling
Improving the 257's crankshaft
http://forums.nasioc.com/forums/show...ing+crankshaft
Downfalls of the oem oiling system for high rpm engines?
Cross-drilling our crankshafts?
Engine failure due to ECM?
http://forums.nasioc.com/forums/show....php?t=1406883
Crankshaft Question
http://forums.nasioc.com/forums/show....php?t=1720557
PISTONS
Real Reason for Forged Piston Clearance? Thermal Expansion Not Enough.
http://forums.nasioc.com/forums/show....php?t=1061799
Piston FAQ: Read if you are thinking about buying them!
http://forums.nasioc.com/forums/showthread.php?t=907570
Mahle vs stock sti piston & pin weight information
http://forums.nasioc.com/forums/showthread.php?t=999055
*Discussion* Why has a higher compression ratio been a bad idea on a turbo car?
http://forums.nasioc.com/forums/show....php?t=1228477
piston dish comparison...
http://forums.nasioc.com/forums/showthread.php?t=964607
EJ22T Piston squirters...are they serviceable?
http://forums.nasioc.com/forums/show....php?t=1174798
RODS
crower or pauter rods ????
http://forums.nasioc.com/forums/show...ghlight=pauter
Pauter Rods EDM pressure-fed oiling to pin is it worth it?
********The *Official* Connecting rod weight compilation thread ********
http://forums.nasioc.com/forums/show....php?t=1902135
The *OFFICIAL* Long Rod discussion: pro's, con's who uses them and WHY
http://forums.nasioc.com/forums/show....php?t=1181857
Cobb Rods
http://forums.nasioc.com/forums/show...highlight=rods
Subaru RODs: Forged??
Need Builders Opinion On Rods!
http://forums.nasioc.com/forums/show....php?t=1397260
Eagle rods - Any good ?
http://forums.nasioc.com/forums/showthread.php?t=817085
Titanium rods and big power...
CAMS/SPRINGS
Compilation of valve spring options
http://forums.nasioc.com/forums/show....php?t=1555787
HOW TO: (w/ pics) STI cams in WRX heads
http://forums.nasioc.com/forums/show....php?t=1356918
DPR valvesprings can't handle lift, worse than STI
http://forums.nasioc.com/forums/show....php?t=1220672
Analysis of Cosworth AVCS cams vs USDM STI cams
Maximum AVCS Advance w/ Cosworth cams?
http://forums.nasioc.com/forums/show....php?t=1423635
2.0l to 2.5l swap, and what AVCS means to you
http://forums.nasioc.com/forums/show....php?t=1194269
Supertech Valvetrain and Mild Porting
http://forums.nasioc.com/forums/show...hlight=porting
HEADS
Head ports comparison
http://forums.nasioc.com/forums/showthread.php?t=903873
AVCS Heads on Non-AVCS blocks.
http://forums.nasioc.com/forums/show...ighlight=heads
Assembly: 2.0L Heads on 2.5L block
http://forums.nasioc.com/forums/show...assembly+heads
Cosworth Heads Vs. Everyone Else
THE Best Full Service Subaru Head Shop
http://forums.nasioc.com/forums/show...highlight=HEAD
DIY PNP Heads?
http://forums.nasioc.com/forums/show...&highlight=DIY
DIY ported WRX heads
Port and Polished heads
http://forums.nasioc.com/forums/show...highlight=port
Double-D Series head ports!!!
http://forums.nasioc.com/forums/show....php?t=1728481
MACHINING
Torque Plate Vs. Non Torque Plate Motor
http://forums.nasioc.com/forums/show....php?t=1899408
Torque Plates
http://forums.nasioc.com/forums/show....php?t=1659712
Builders who use torque plates
http://forums.nasioc.com/forums/show...ight=machinist
Thoughts on main bearing clearances...
Torque/hone plate is necessary when boring!
Whats needed for torque plate honing?
What to look for in a machinist / engine builder? Choose A, B, C, or D.
http://forums.nasioc.com/forums/show....php?t=1136374
Crankshaft balancing and counterweights
http://forums.nasioc.com/forums/show...ght=crankshaft
To Sleeve or not....
D.I.Y
Tearing down a block - A pictorial. Includes head removal.
http://forums.nasioc.com/forums/show....php?t=1435733
DIY: Pull your own motor. Lots-o-pics
http://forums.nasioc.com/forums/show....php?t=1301065
Talk me out of swapping pistons on my own.
DIY Closed-Deck
How To: DIY TGV Deletes
http://forums.nasioc.com/forums/show....php?t=1165948
MISC
Rallispec Street spec shortblock.
http://forums.nasioc.com/forums/show...6#post29236906
Is 1000 WHP possibly and how?
Has anyone hit 1000+ WHP on any EJ motor?
http://forums.nasioc.com/forums/show....php?t=1370387
catastrophic engine damage w/pics!! Expert opinions wanted..
Tony's 2.5 Hybrid Swap Thread
http://forums.nasioc.com/forums/show...ghlight=hybrid
My hybrid build on a budget...
http://forums.nasioc.com/forums/show...ghlight=budget
Built motor guys who have aquired significant milage
http://forums.nasioc.com/forums/show....php?t=1798862
FUEL
What Fuel pumps are people using on their 525+whp
http://forums.nasioc.com/forums/show....php?t=1228437
EJ255 vs. EJ257 FACTS:
EJ257 vs EJ255 facts with pictures
http://forums.nasioc.com/forums/show....php?t=1667168
Nice posting!
BadSubby is offline   Reply With Quote
Old 01-03-2017, 07:46 PM   #83
RP31
Member#: 123574
2005 stuck-in-garage
CGM STi
Originally Posted by BadSubby View Post
Nice posting!
Yeah? Did you read what was written? Do you even know which subforum this is?
You're obviously just posting willy-nilly to increase your day 1 count so you can post in some restricted forum.
RP31 is offline   Reply With Quote
Old 01-19-2017, 08:38 PM   #84
SeanL15
Member#: 461598
2005 WRX
Thanks great info!
SeanL15 is offline   Reply With Quote
Old 05-19-2017, 02:41 PM   #85
spencersti
Member#: 467959
Good info, a need to read if you want to a high hp car.
spencersti is offline   Reply With Quote
Old 07-06-2017, 12:59 AM   #86
jkaissar
Member#: 470473
great thread. thanks.
jkaissar is offline   Reply With Quote
The "Post a Link to Your Favorite Thread YOU Started" thread DrDRum Off-Topic 59 09-11-2008 12:01 PM
Anyone have a link to the thread where... Digitalfiend General Community 1 01-21-2008 12:21 AM
How to create a LINK to a thread? savka Newbies & FAQs 10 12-14-2001 01:17 AM
Links to good... er Great vendor pages..... subenutt General Forum Archive 7 01-05-2001 12:24 AM
Please help - Link to technical thread. Subu WEX General Forum Archive 1 09-03-2000 09:06 AM
