Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 08-09-2007, 12:12 PM   #1
FAST-1
Member Sales Rating: (3)
Member#: 105537
Default Zeal Function V6 Coilovers Spring Rate 10K/8K for STI / WRX
SOLD
Great condition. Unbelievable handling. The best coilover for Track Days or Auto-cross.
This steel-type, inverted-monotube type shock absorber is produced for specific vehicles with strut-type suspension. The shock absorber for this type of set up takes great abuse, thus side load attributes must be strengthened. An inverted monotube with a Friction-Loss Cylinder was developed for this matter. While using the Function Series' technology, we've produced the new Zeal model for high performance driving. The nitrogen gas camber is positioned higher up and farther away from the braking area creating less heat transfer and thus, less chance for overheating. Also, under-spring weight is now lighter enabling handling to become sharper, quicker, and more responsive. Our easy-to-read and use, 6-Way Piston Valve Shock (PVS) Dial mechanism adjusts the rebound/compression force with its Piston Valve Shock Technology, Level 1 being the softest and Level 6 being the stiffest. Dial can be turned either direction infinitely. Pillow Ball camber adjustable upper mounts for direct feel of suspension motion help to decrease piston rod tension. ID60 Basic Spring (Street or Hard rates) maintains stroke and ensures a "seated" fit with upper and lower portions processed to a flat cut. The Adjustable Shock-Stroke System is a separate, adjustable lower cup/bracket used for height adjust ability which eliminates problem of sacrificing stroke and altering spring tension. Spin the mechanism over the threaded shock casing up to lower (and down to raise) vehicle height. All Zeal Function Series systems include this height-adjustable system.
FAST-1 is offline   Reply With Quote
Old 08-09-2007, 12:22 PM   #2
cellobro
RIP 3/18/1965 to 1/10/2008
Member Sales Rating: (18)
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
bump for excellent product, got a set for my NEXT car , got Cusco w/Econ on teh wagon...
ttt
cellobro is offline   Reply With Quote
Old 08-09-2007, 12:29 PM   #3
FAST-1
Member#: 105537
Thanks for the bump !
Old 08-09-2007, 07:01 PM   #4
FAST-1
Member#: 105537
Old 08-09-2007, 07:54 PM   #5
yoyoman05
Member Sales Rating: (4)
Member#: 101174
08 tribeca
00 outback
how much$ ? will they fit an 06sti?
yoyoman05 is offline   Reply With Quote
Old 08-09-2007, 10:41 PM   #6
iheartmysuby
Member Sales Rating: (173)
Member#: 83638
if the dial can be turned either way infinitely.... how do you know what settings it is on?
iheartmysuby is offline   Reply With Quote
Old 08-10-2007, 12:12 AM   #7
robbieshonda
Member Sales Rating: (38)
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
price and location
robbieshonda is offline   Reply With Quote
Old 08-10-2007, 11:40 AM   #8
FAST-1
Member#: 105537
Yes - they were on my 06 STI.
Old 08-10-2007, 11:41 AM   #9
FAST-1
Member#: 105537
There are numbers on the Dial.
Old 08-10-2007, 04:40 PM   #10
FAST-1
Member#: 105537
PM's sent
Old 08-10-2007, 09:09 PM   #11
FAST-1
Member#: 105537
Info updated - Check PM's
Old 08-13-2007, 11:58 AM   #12
FAST-1
Member#: 105537
PM's sent
Old 08-14-2007, 03:37 PM   #13
FAST-1
Member#: 105537
Info updated
Old 08-15-2007, 11:23 AM   #14
FAST-1
Member#: 105537
Old 08-16-2007, 11:39 AM   #15
FAST-1
Member#: 105537
Old 08-16-2007, 07:17 PM   #16
cellobro
Member#: 91500
hmmm sr-30+640cc=?
BUMP for a good product STILL.
these will far outperform spring & shock combos, the car goes where ya point it...
Old 08-17-2007, 11:43 AM   #17
FAST-1
Member#: 105537
Thanks for the bump cellobro...
Yes, the car goes where you point it, the only problem is the driver needs to know where to point it, at least if he wants a good autocross time...
You can buy great coilovers, unfortunately...you can't buy talent...
Old 08-17-2007, 12:49 PM   #18
mesa50w
Member Sales Rating: (24)
Member#: 83044
04.5 blue STi
97 miata, 93 miata turbo
great coilovers I have a set on my STI. Ride great on the street and great on the tack as well, best of both worlds.
the lowers can be switch out to fit ANY year impreza
mesa50w is offline   Reply With Quote
FS IL: Zeal Function V6 coilovers wrx awalk9905 Suspension/Brakes/Handling 20 09-03-2008 03:36 PM
Fs: 04 STi Zeal Function V6 coilovers, Stock V8 struts & tops, Stock Fr Swaybar SlvrRS Tri-State Area Private Classifieds 7 07-26-2008 12:01 AM
FS Feeler: Zeal Function v6 coilovers 8k/10k waktasz Suspension/Brakes/Handling 25 06-21-2007 11:20 PM
FEELER: Zeal function v6 coilovers for GC! rommellikewhoa SCIC Private Classifieds 4 04-28-2006 10:18 AM
FS: Zeal Function V6 Coilovers for 05 STi z3coupe Private 'For Sale' Classifieds 15 01-23-2006 06:16 AM
