View Poll Results: What color should I plasti dip the car? | |||
Arctic Black |
0 | 0% |
Nardo Gray |
0 | 0% |
Slate Blue |
0 | 0% |
Voters: 0. You may not vote on this poll |
#1 |
Member#: 497893
Vehicle:2011 Sti Hatch New color coming soon. |
![]() Well I'll start from the beginning..
I bought the car from Ford Ciocca bargan lot in PA on 12/22/2015 for $30,923(after interest and power train warranty). The car had 84,861 miles. ![]() So I make it home and right off the bat I change the oil soon realizing the previous owner clearly did not do routine oil changes. Looked like Hershey syrup trickling out the pan. So I changed the oil a few times in the next few weeks to try and get all that junk out and it seemed to work. ![]() Other then the accessport I ran a downpipe, a catback and Cobb intake for a long while, probably 3 1/2 years or so on the OTS stage 2+ map. The only issues I had were a bad thermostat, power steering rack, and I had a few fender benders. ![]() First one I hit a deer, had to replace the passenger side headlight, door, fender, and rear quarter. Next I hit a piece of metal on the highway, had the passenger side rocker replaced. Last I rear-ended someone who break checked me, luckily swerved and didn't total the car but destroyed the whole driver's side front bumper to rear bumper, sideswipe basicly. ![]() At this point in the cars life the motor was getting tired (175k) and it was a sad day when it blew up on the highway, pulled off and called for help. ![]() Brought the car to Precision Tuning in spotswood NJ, around march 2019. This was my only car at the time and I needed it back quick so I brought it to a local Subaru shop. Unfortunately they had issues finding a used motor that didn't have problems. I think they went through 3 motors that all had knock before deciding to just put a new factory shortblock in it. At this point it had already been 4 or 5 months at the shop. ![]() Finally the car was ready. Rich did an awesome job and gave me a great deal because it took so much longer then anticipated. The build: Factory ej257 and vf48 Agency unequal headers, 1320 up pipe, Invidia catless downpipe, Invidia N1 Cobb intake, Perrin turbo inlet Cobb ebcs IAG AOS IAG Tgv deletes AEM 340 fuel pump, Aeromotive fuel regulator, IAG rails, ID 1050x injectors Car made 325 hp 345wtq on the dyno jet at Precision tuning. ![]() I drove the car till the summer of 2020, put 8k on the new motor then bought a 2000 buick century as a beater for the time being. My plan is to rebuild the car again, this time in my driveway. I got the itch for more juice. Last edited by pickleSlapOG; 12-23-2020 at 03:13 PM. |
#2 |
Member#: 497893
![]() Work In progress: Will update as I move along with the build.
Motor Build: Outfront semiclosed block, Weisco pistons, Manley rods, King bearings, Killer b oil pan, baffle, killer b pickup, Killer b water pump housing, 11mm oil pump, Ported rebuilt heads, Oem Cams, Gsc Valves, Gsc Springs, ARP 625 Studs, Cometic Gaskets, Gates timing belt kit, Grimm LW pully, Exhaust: MAP 4-1 EL header, PLM up pipe + dump tube, Invidia deviated downpipe, Invidia N1 race, Turbo: Blouch Dom 1.5xtr, 44mm tial EWG, Perrin turbo inlet, Cobb EBCS, Turbosmart duel port BOV, Omni 4 bar, Engine Support: Cobb sf intake, ETS 3.5 in. FMIC, AEM speed density, Killer b upper reservoir, IAG Tgv deletes, IAG AOS, Cyl. 4 cooling mod, Perrin oil cooler retro top mount, Fueling: AEM 340 fuel pump, Aeromotive fuel regulator, IAG Fuel rails, ID 1050x injectors Drivetrain: ACT 6 puck, ACT streetlight flywheel, Maintenance: sunoco 260GT 100oct, Purolator Boss oil filter, Motul 8100 x-cess 5w-40, NGK 1 step colder plugs Suspension: Tien lowering springs, Cusco tower braces front and rear, Cusco front member, Whiteline rear control arms, Whiteline Rear Sway Bar Mount Support, Perrin F+R endlinks, Perrin front sway bar, Cusco rear sway bar Brakes/wheels: Miscellaneous: Cusco engine mounts, Cusco trans mount, Flat motors air pump delete plates, Kartboy pitch stop, Kartboy shifter bushings, Kartboy short shifter, Cusco power steering brace, Perrin master cylinder brace, Oem power steering pump and alternator, AC delete, IAG maf block off Dress up: Perrin rad shroud, Perrin rad mounts, Perrin EBCS cover, Cobb alt. cover, rally-tech bolt kit Interior: DAMD steering wheel, Perrin reverse lockout, Perrin si drive knob, AEM oil pressure gauge, AEM oil temp gauge, AEM AF gauge, AEM boost gauge, SMY duel gauge pod, Podi vent gauge pod, Single pod A pillar, Shift solutions e break handle, Notions and devotions shift boot, e break boot, and arm rest, Broadway mirror, Cobb weather tech mats Exterior: Perrin shorty antenna, Perrin hella horn bracket, Hella sharp tone, Rally armor mud flaps, Jdm side badge, Jdm rain guards, inno wind fairing, Ebay all around lip kit, Grimm plate relocate, kartboy plate delete, I'm sure I missed a few things here and there. Thanks to Rich from Precision tuning! Thank you GSD performance coatings! Thanks to Dave from Headgames motorworks! Thanks to Dane from Import image racing! Thanks to everyone from Nasioc who sold me parts! My dedication is real and I'm going to keep on untill I feel the car is right! ![]() Last edited by pickleSlapOG; 12-25-2020 at 06:24 PM. |
#3 |
Member#: 497893
![]() Just picked up some parts from GSD coatings in Keyport, New Jersey. Parts were ceramic coated.
#4 |
Member#: 497893
![]() Found some 2014 sti struts that I refreshed with a good scrub, some rust protection, and Tien springs.
#5 |
Member#: 497893
![]() Dash has been pulled apart for months, still getting around to it bit by bit.
#6 |
Member#: 209205
![]() As an owner of a 2009 STI in WRB I really enjoy this thread. Mine had a bad accident with only 5000km on the car; $25k CAD damage. Worst part was I wasn't the one driving.
I have had it since new. One quarter panel replaced twice (second time due to rust) and patched infront of both rear wheels. Driving through the winter mud builds up there and rusts between the splash shield and body. You may be aware of this and keep it cleaned out in there, I wish I noticed much sooner than later. Awesome cars, can't wait to see what you do with yours! A lot of future mods that are also on my list. |
#7 | |
Member#: 497893
![]() Quote:
#8 |
Member#: 497893
![]() Just clearing up why I'm staying with the stock location turbo.
I know I should go rotated but I'm waiting a few more years untill I start a closed deck build. I already had all these parts waiting to go into the car and it'll be a big loss if I sell everything. Also FYI I had all these parts before a built shortblock fell into my hands. It was a surprise and I was planning on staying with the factory shortblock but the Subaru gods blessed me with a killer deal so I took it. Im having second thoughts on the Blouch Dom 1.5 xtr. I'd like to see low 400's and I don't think I will get there with the Dom 1.5. So for now I'm going to stick with the stock location turbo, I just think the Dom 1.5 will be disappointing. Will update on what I decide to go with but leaning towards the 3.0 at this point. Edit: I'm going to keep the 1.5 xtr, get the car built, broken in and tuned, drive the car for awhile and go from there. Last edited by pickleSlapOG; 12-29-2020 at 07:16 PM. |
