Welcome to the North American Subaru Impreza Owners Club Wednesday September 23, 2020
Old 12-17-2019, 02:34 PM   #1
Something Cool Here
Member#: 238734
2010 WRX Hatch
Spark Silver
Default S209 Block in 2008 STi
Alright so I blew up my ring lands on piston #4 in my STi and ordered a new block. I got my hands on a brand new block from Subaru for an S209. Probably wonít be here for another 60 days. Turns out newer EJís have piston crowns that are 2mm thicker. Iíve tried searching but found nothing (not sure if this is even the right category so bare with me Iím sorry).
My question is: what will need to be done in order for this block to work with my stock w25 heads from a 2008 STi ej257?
Thanks in advance!
Something Cool Here is offline   Reply With Quote
Old 12-17-2019, 07:25 PM   #2
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Nothing special needs to be done. Itís a straight bolt-in job.
Hoon Goon is offline   Reply With Quote
Old 12-17-2019, 07:43 PM   #3
JP Chestnut
Member#: 504432
Is there actually such a thing as an "S209" block? It's just a regular production engine with some new bolt on parts fitted.
JP Chestnut is offline   Reply With Quote
Old 12-17-2019, 08:43 PM   #4
stu
Member#: 25768
2003 GEN2 GTX35 40++
2.3 slobaru
type RA has forged pistons. It will bolt right up
stu is offline   Reply With Quote
Old 12-17-2019, 09:04 PM   #5
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
That's not correct. It has a higher quality cast piston.
Fierysun is offline   Reply With Quote
Old 12-17-2019, 09:14 PM   #6
Something Cool Here
Member#: 238734
2010 WRX Hatch
Spark Silver
From my understanding the type ra has a higher quality piston and the s209 has forged rods and forged pistons
And I was told by rallysportdirect the type ra block will not bolt right up to my heads since 15+ ejís have 2mm larger piston crowns. Guess Iíll have to wait until the block is here to see for sure. My guess is thick af head gaskets
Was curious if anyone has done a type ra or at least a 15+ block on w25 heads from an 08-14 sti
Old 12-17-2019, 09:26 PM   #7
JP Chestnut
Member#: 504432
The S209 has the same bottom end as the 2019+ base STI as far as I know - hence the huge complaint fest in the s209 thread.
Old 12-17-2019, 09:27 PM   #8
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Wrong. Type RA and S209 do NOT have forged internals.
Scorpius is offline   Reply With Quote
Old 12-17-2019, 09:35 PM   #9
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
^ What they said.
The 19+ STI, Type RA & S209 all share the same short block. This cast pistons are improved compared to previous years.
https://www.comeanddriveit.com/engin...-sti-internals
WRXnick16 is offline   Reply With Quote
Old 12-17-2019, 09:41 PM   #10
Something Cool Here
Member#: 238734
2010 WRX Hatch
Spark Silver
They have different part #ís and when ordering it the parts warehouse guy (I work at a dealership and placed the order) said it had forged internals not that he knows for sure. But he did say it was going to take awhile because it is built to order by STi in Japan and flown over as a single unit...so weíll see if I even end up getting it.
Iím trying to find out if it can handle more power than my old stock block did at least haha. Not going for 800whp just 400 ballpark
Old 12-17-2019, 09:46 PM   #11
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Just because they have different part numbers doesn't make the S209/Type RA have forged internals. You're wrong and you have no clue how to do a quick search on google.
Old 12-17-2019, 11:16 PM   #12
Something Cool Here
Member#: 238734
2010 WRX Hatch
Spark Silver
Okay this got a little off topic but that does make sense as to why it was actually cheaper than the correct part # for my car.
Back to the actual question. Has anyone ever used this block, that now I know is basically any 18+ ej257 block, with w25 heads?
Old 12-18-2019, 12:41 AM   #13
NighthawkSTI
Member#: 495630
all STI's have forged crankshafts and forged connecting rods....so forged internals. The RA pistons became standard for all STI's including the S209 so they all have forged internals except for the pistons. If they had forged pistons than one could say they are "Fully Forged" blocks.
NighthawkSTI is offline   Reply With Quote
Old 12-18-2019, 08:23 AM   #14
Something Cool Here
Member#: 238734
2010 WRX Hatch
Spark Silver
Thatís not the question I donít care not the point of this thread at all.
I wanna know how this block will bolt up to w25 heads since they have a 2mm larger piston crown
Do not reply if you havenít done something similar and donít have any real response
Thanks
Old 12-18-2019, 08:56 AM   #15
Fierysun
Member#: 82745
2005 Subaru STI
Most of your posts includes random unsolicited cut downs. Looking to get banned?
That’s not the question I don’t care not the point of this thread at all.
Do not reply if you haven’t done something similar and don’t have any real response
Thanks
Reach out to Yimisport in Santa Clarita. They know quite a bit about this block and have tuned it to 550whp (yeah it's an EJ to the FA fanboi's) with untouched internals.
Also, there may be something off with your tune/map to have damaged the ring land.
Old 12-18-2019, 12:39 PM   #16
NighthawkSTI
Member#: 495630
Thanks
The compression height is the same and the valve relief depths are the same for the standard pistons and the RA pistons.
Old 12-18-2019, 03:11 PM   #17
Something Cool Here
Member#: 238734
2010 WRX Hatch
Spark Silver
Okay cool thank you. I honestly think Iím gonna cancel the order and just hone my block and put forged internals in it and call it day
Not sure if it was my tune or wastegate but I was hitting about 30 psi of boost instead of 18 so Iím not surprised it happened
Old 12-18-2019, 03:17 PM   #18
Fierysun
Member#: 82745
2005 Subaru STI
That is going to be a can of worms. Good luck.
Old 07-30-2020, 07:31 PM   #19
SithSTI
Member#: 508661
I just put a type ra block in my 2012 STI. I am having issues with the timing belt tensioner clacking and not keeping good tension but I believe it's because I have a tensioner meant for a 2012 when in 2015 they updated only STIs to a new tensioner.
SithSTI is offline   Reply With Quote
Old 08-22-2020, 12:34 AM   #20
ventura92x
Member#: 165074
I have a type RA block in my Ď08 that Yimi built about a year ago. I wasnít looking to make a ton of power but itís solid and is a good base if I want to go that route.
ventura92x is offline   Reply With Quote
