Welcome to the North American Subaru Impreza Owners Club Wednesday September 23, 2020
Old 08-04-2020, 03:11 PM   #1
subieslaysall
Member#: 494560
Default Ej205 timing belt question
Hi, I'm just curious what kind of timing belt kit I would need for my 2003 wrx. It's had a jdm ej205 swapped into it from the previous owner. I have no way of knowing what year it's from, the label on the timing belt cover is not readable. Is the only difference between the 02/03 kit and the 04/05 the hydraulic tensioner? If so I could just get the kit for the 02/03 and just not use the hydraulic tensioner if the motor is from a newer model?
Thank for reading, any help would be awesome!
subieslaysall is offline   Reply With Quote
Old 08-04-2020, 03:36 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Just get a 02/03 complete kit.
Since you don't say how many expected miles are on the motor, then you should do everything to be safe:
- timing belt
- tensioner
- pulleys
- water pump
Best to do it once and not keep taking things apart later doing it piece by piece thinking you will save yourself money
Samurai Jack is offline   Reply With Quote
Old 08-04-2020, 03:52 PM   #3
subieslaysall
Member#: 494560
- timing belt
- tensioner
- pulleys
- water pump
Awesome, thanks for the reply!
