02-17-2004, 08:40 PM | #1 |
Member#: 44945
SCIC
Vehicle:06 LGT wag silver |
my gf's 89 Camry has problems - please help me figure it out
ok so its a very old car, 1989 automatic with 130k miles, but her car has never had problems like this before. so she's coming home yesterday and it simply stalls at a light, starts it up again and drives ok until the next light or stop sign, stalls again. no smoke comin out, no sounds, no shaky tranny or anything. starts up again smooth and drives with no hesitation, and stalls at home. it seems like it should be an obvious problem, but im no mechanic. i was like 'eh its an old car' maybe its the timing belt, idle timing, fuel injection... i dunno! i never owned a car past 100k miles. please help me! i figured you guys would know... thanks.
02-18-2004, 12:38 PM | #2 |
Member#: 44945
SCIC
bump
02-18-2004, 12:40 PM | #3 |
Member#: 24463
Vehicle:2003 Chevy S10 91 Hunduh Civic BASE |
Idle air control valve/motor. Pull it out and clean it. Also, run a bottle of BG44k through the gas tank.
02-18-2004, 12:41 PM | #4 |
Member#: 7977
Vehicle:100% Abuse |
Erm.
It's not the timing belt... cuz it would not drive anymore. It may be the idle system... not letting enough air in, or the air/fuel mix is off. Basically it sounds like there's very little you can do to fix it yourself, since you don't know anything about engines. You could try some Fuel Injector cleaner, pour it in the gas tank, drive around, see what happens. But it probably has to go in to the shop. |
02-18-2004, 12:41 PM | #5 | |
Member#: 7977
02-18-2004, 12:42 PM | #6 | |
Member#: 24463
02-18-2004, 12:43 PM | #7 |
Member#: 7977
Hang on, I gotta finish the two I'm drinking now...
02-18-2004, 12:44 PM | #8 |
Member#: 7977
Also... given that he thought it might be the timing belt, I'm prepared to go out on a limb and guess he won't be able to properly locate/remove the Idle controller/throttle body/TPS/anything.
02-18-2004, 12:46 PM | #9 |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed (sold) |
fuel filter.
ss |
02-18-2004, 12:56 PM | #10 |
Member#: 5893
E. Canada
Vehicle:1997 Black GC4 1995 White BK6 |
Does she have the car regularly maintained? If not, do the spark plugs, air filter, and fuel filter first so you have a good baseline. Then start diagnosing.
02-18-2004, 01:47 PM | #11 |
Member#: 27986
Give the car a big, powerful kick, as that is the best way to fix things.
My HID's are doing REALLY WEIRD stuff. Someone help me figure it out. | Pwildeboer7 | Electrical & Lighting | 3 | 07-21-2009 03:01 PM |
I know I'm dumb - but someone please help me figure this out! | MissDanz | Off-Topic | 21 | 03-11-2005 04:56 PM |
Please help me figure this problem out | Enigma76 | New England Impreza Club Forum -- NESIC | 20 | 09-22-2004 04:15 PM |
I have a weird noise help me figure it out please? | waitandbleed92 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 12-13-2003 12:17 AM |
My fuel problem is back...please help me figure this out | Mancini | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 10-11-2003 10:02 PM |
