Welcome to the North American Subaru Impreza Owners Club Thursday September 20, 2018
Old 10-12-2017, 11:01 AM   #1
vaux
Member#: 457546
2017 Impreza Sport
Post 2017 Impreza Door Alignment Fix Service Bulletin
Has anyone taken advantage of the recent service bulletins in regards to the front door alignment with the body and interior dash? I got an alert in my OBD setup but noticed this isn't on mySubaru.
Basically, it indicates that there are a small number of customer reports indicating that the front door is misaligned and doesn't appear flush with the rear door and the interior dash shows a gap.
Does anyone have up to date service bulletins for the 17 Impreza?
vaux is offline   Reply With Quote
Old 10-12-2017, 11:12 AM   #2
buschap
Member#: 464292
I've got access to AllData, but there doesn't seem to be anything applicable under body and frame, just
12-213-17 01/12/2017 Center Console Lower Trim Panel - Design Change
01-168-09R 11/16/2016 Replacement Key and Immobilizer Information
buschap is offline   Reply With Quote
Old 10-12-2017, 11:28 AM   #3
vaux
Member#: 457546
2017 Impreza Sport
I have a bulletin noted as 12-228-17 indicating 'addresses a small number of customer reports of improper fit or misalignment between the front door trim panel and the instrument panel's ornament panel.'
Is this not showing up on your end?
Old 10-12-2017, 11:33 AM   #4
buschap
Member#: 464292
I don't see it, but it looks like AllData doesn't have any TSBs more recent than April now that I look at the whole list.
Hope someone else can turn something up.
Old 10-12-2017, 11:40 AM   #5
vaux
Member#: 457546
2017 Impreza Sport
Weird, I actually set up an appt for tomorrow to get it addressed hopefully. Still in my 1 year warranty so hoping to take advantage of these little quirks.
Here is a list that popped up for me if anyone wants to check for themselves:
12-228-17 Aug 29 2017
This bulletin provides a repair procedure to address a small number of customer reports of improper fit or misalignment between the front door trim panel and the instrument panel's ornament panel.
15-211-17R Aug 27 2017
The following information addresses reprogramming file availability and a software update installation procedure to provide optimation to the new Harman gen 3 audio and navigation head units utilized in the new 2017 Impreza
15-204-16R Aug 16 2017
This bulletin contains illustrations of exchange components and their manufacturer as well as a description of the proper exchange procedure.
12-224-17R Aug 2 2017
This bulletin provides a procedure for replacement of the black foam rubber insulating cushions for the roof rails. In rare cases, the cushions may come loose and begin to protrude from under the roof rails where they contact the body.
07-119-17 June 28 2017
This service information bulletin announces a production method change to the rear combination lamp assembly. The application procedure fo the anti-fog coating was changed to prevent a customer concern of visible drip marks or streaks.
