04-14-2009, 02:18 AM | #1 |
Member#: 152806
VIC
Vehicle:2006 2.5i SGM |
local pulley install
hey guys i was wondering where i should get a lightweight pulley installed.
I was thinking any performance shop such as RG, drivehard, advance, teamwork, ajr or a dealership. Or any home mechanics with torque specs and a wrench wanna help me out? I think RR is overkill for something so simple. let me know your thoughts on the places i listed and any other recommendations. thanks guys
04-14-2009, 02:29 AM | #2 |
Member#: 5851
VIC
Vehicle:17 Ford Escape SE Blk |
Or, just don't put it on, sell it and save yourself some moneys!
04-14-2009, 02:31 AM | #3 |
Member#: 152806
VIC
haven't bought it yet lol
04-14-2009, 02:32 AM | #4 |
Member#: 5851
VIC
don't, biggest waste of money.
04-14-2009, 02:32 AM | #5 |
Member#: 5851
VIC
But to answer your question, you answered it in your first post in terms of who could do it.
04-14-2009, 02:45 AM | #6 |
Member#: 43901
Vehicle:no car |
04-14-2009, 03:32 AM | #7 |
Member#: 116914
VIC
Vehicle:2006 WRX Wagon Obsidian Black |
Or just install it yourself. Takes less than 30 minutes if you have the right size socket and a long breaker bar.
I don't really feel any noticeable difference on my car though. |
04-14-2009, 03:35 AM | #8 |
Member#: 129503
VIC
Vehicle:2002 It's resting 6 > 4? |
lol have you felt the stock som bitch.....its heavy as hell...like 7 lbs lol....and its ugly as sin....
it wont really get you much real gains though...maybe a bit of throttle response...but it'll look pretty..... if you still want to do it let me know and i'll give you a hand, it'll only take about 20 minutes....i live in langley....let me know ps aspect and tora....have u tried LW crank pulley or are you going by common nasioc consensus? people spend just as much on other cosmetic engine mods oil caps and belt covers.....so why the hate for the pulley...lol |
04-14-2009, 03:43 AM | #9 |
Member#: 152806
VIC
i don't know my thinking is reduce drivetrain loss, it'll be the same as removing the spare tire. or running smaller diameter wheels/tires. I'm not expecting anything close to the gains from EL headers over UEL but that's another can of worms. esp because the car is NA little mods make a bigger difference then they do on turbo cars. johnson or jeff do you guys have a breaker bar/torque down specs?
04-14-2009, 03:51 AM | #10 |
Member#: 152806
VIC
I have access to a breaker bar and torque wrench but have no idea how to pull off the old one and how much tension to put on the belts and bolt. If anyone has specs please post that also = ). This is assuming i actually end up buying one.
I suppose it wouldn't hurt to put up the pulley's i've looked at agency power, cobb, perrin, medieval and groupA. Any experience with any of these? i'll likely end up getting the groupA or medieval since they're the cheapest at about 100 |
04-14-2009, 03:59 AM | #11 |
Member#: 143277
VIC
Vehicle:05 STI PPP OBP 1098, Z1000 |
i plan on getting a lightened pulley set but its at the bottom of my priorities as i hear gains are only measurable by the butt dyno.
if your car is stock, you might want to save the money towards a bigger mod? |
04-14-2009, 04:02 AM | #12 |
Member#: 116914
VIC
Torque spec is between 94 ft-lbs to 133 ft-lbs depending on which instruction you followed.
http://techinfo.subaru.com/html/down...IMING_BELT.pdf <-- Page 17 has the reinstallation info. I cheated with the installation by cranking the engine with the coil unplugged. I won't really recommend this method as your car should be new enough that the bolt isn't ceased yet. I also have the Group A crank pulley. Even though it is quite a bit lighter than stock I didn't felt any real gain (it is said the gain on a turbo is less than that of a NA car). |
04-14-2009, 04:07 AM | #13 |
Member#: 95195
W. Canada
Vehicle:1974 Rat Rod Bug back and white |
I noticed my car revved a bit quicker with it did it myself easy!
04-14-2009, 04:12 AM | #14 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Instagram | arthurlam89 |
DIY. Takes like less than 10 minutes.
04-14-2009, 04:17 AM | #15 |
Member#: 152806
VIC
yeah besides boring the hell out of the block and intake there isn't much more for NA lol cams aren't an option as there isn't any tried and tested reliable setup available. car is rock solid with konis and rce yellows. sways/endlinks will come as soon as i find a good set used. Wheels and tires have been done and have been aligned w/ a bit more negative camber. There are holes in my trunk, but it adds to the funkyness of driving a sube/ plus appearance isn't anywhere near the top of my priorities. I've managed to weaken the car by putting uel headers on but it makes for a more enjoyable driving experience. Might toy with phenolic intake manifold spacers after i do some more reading on them. brakes are great for dd'ing but ss lines and/or 4pots are being considered.
and i've derailed my own thread lol thanks for the specs johnson Last edited by JccL; 04-14-2009 at 04:28 AM. Reason: thanks for the specs |
04-14-2009, 10:13 AM | #16 |
Member#: 125055
VIC
Vehicle:12 STI hatch |
It's actually a good mod for n/a guys. Made rev-matching easier for me, pretty minor (on a 2.0-litre) and I've heard the 2.5 Turbo guys don't notice it at all.
It just depends how much torque you have. |
04-14-2009, 10:56 AM | #17 | |
Member#: 5851
VIC
Read this thread - http://forums.nasioc.com/forums/show...ghlight=pulley Anyways, if someone just wants to do it for looks I can't argue with that. |
04-14-2009, 11:52 AM | #18 | |
Member#: 129503
VIC
http://www.deltacam.com/ give em a call...they're like 90$/cam then opensource the ecu (u can do that with the 2.5i apparently)..... those are the only two things that will get you power on the RS |
04-14-2009, 12:00 PM | #19 | |
Member#: 152806
VIC
04-14-2009, 12:11 PM | #20 |
Member#: 48685
Vehicle:2010 Prius Silver |
http://www.hspn.tv/?videoid=65&catid=14
That's what I used to install the crank pulley. Butt dyno felt the car revved quicker but I dunno. I bought it when it was cheaper during a group buy. |
04-14-2009, 01:03 PM | #21 |
Member#: 4718
VIC
Vehicle:I gotz a Subaru again |
I've done the mod before, and would prefer to spend my money elsewhere now.
That said, if you NA guys are seeing gains, you can't argue with that. Plus, you're so limited on the mods you can do, it's almost a no brainer. Fwiw, I'd throw a shot of Zex on it and call it a day. |
04-14-2009, 01:18 PM | #22 |
Member#: 129503
VIC
04-14-2009, 01:36 PM | #23 |
Member#: 106510
VIC
Vehicle:98 Widebody 3.4L Smooth Safety Blue |
I removed the lightened pulley that was on the car when I bought it in favour of the stock one, FWIW.
Inertia is important in small displacement vehicles. |
04-14-2009, 03:34 PM | #24 |
Member#: 134949
VIC
04-14-2009, 04:00 PM | #25 |
Member#: 68402
VIC
Vehicle:2016 WRX DGM |
Similar Threads | ||||
HELP! pulley install-broke plastic bit that connects a/c tensioner pulley to bolt | garie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 12-22-2004 12:46 PM |
Pulley install question. | RallyImprezive | Normally Aspirated Powertrain | 4 | 04-27-2001 12:35 AM |
unorthodox racing pulley install | IMPREZA GUY | Normally Aspirated Powertrain | 2 | 04-24-2001 10:14 PM |
('93-'01) NEED HELP ASAP W/ PULLEY INSTALL! | TimCat | Impreza Forum | 2 | 04-14-2001 11:45 AM |
Underdrive pulley install... | SFsube | Bay Area Impreza Club Forum -- BAIC | 2 | 05-18-2000 05:03 PM |
