Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2018
Old 04-20-2006, 08:19 PM   #1
kleggo
Member#: 105294
Default permissable Effective Wheel / Tire Diameter changes?
Yes, i did search and i did read the FAQs which had lottsa good info, but not specifically what i'm looking for.
now that that's out of the way
I'm buying aftermarket wheels / tires for my 06 LL Beanie.
It's my understanding that with the AWD, i should maintain nearly the same Effective Wheel / Tire Diameters at all four corners to keep things happy.
My question is, how far from the nominal diameter of the existing wheel / tire combo can i deviate as far as the AWD system is concerned?
I'm looking to fill the wheelwells a bit more without lowering the car.
I realize that changing EWD may effect tire / body clearance and speedo reading.
i know that wheelwell opening size limits EWD.
How much larger can i go before the AWD drive or any associated sensors freak out?
Does a 1 or 2" increase screw with the AWD sensors?
thank you
be safe
kleggo
kleggo is offline   Reply With Quote
Old 04-20-2006, 08:23 PM   #2
WrexT
Member#: 80169
2004 PSM WRX
Cobb Stage 2 biotch!
A lot of guys here are running tires close to 1" taller than stock and I have yet to hear of a problem (in regards to ABS/AWD and such). It's not the proper way to tire our cars, but people are doing it! The usual recommendation is to stay within 2-3% of OE overall diameter.
WrexT is offline   Reply With Quote
Old 04-20-2006, 08:56 PM   #3
waktasz
Member#: 86356
2016 Aprilia
Tuono v4 1100 Factory
As long as they fit in your wheel wells you can run whatever size tires you want. The AWD doesn't like tires that are of varying size (like 225/45 front 245/45 rear) or something. Going to 4 larger tires won't change anything except your speedo/odo readings.
waktasz is offline   Reply With Quote
Old 04-20-2006, 11:43 PM   #4
kleggo
Member#: 105294
__________________________________________________ ______________
thank you for the cogent reply.
blue skies
Craig
Old 04-21-2006, 12:50 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...AND it will KILL----destroy is a better word....your acceleration and torque.....it will be a complete slug if you put such tall wheels on it and your braking and fuel mileage will suffer as well, due to the incerased weight.
Great idea.
Old 04-21-2006, 01:19 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Yeah, but it'll look better, and that's all that matters, bro!
Old 04-21-2006, 01:58 AM   #7
WrexT
Member#: 80169
2004 PSM WRX
You're crazy....Do it right, put the proper height tire on there and lower it!
Don't cut corners buddy!
Old 04-21-2006, 02:21 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 04-21-2006, 02:22 AM   #9
Back Road Runner
Member#: 60082
2004 Forester STI
Doesn't matter.
Just realize the limits in physical space, primarily the struts. You can only go so wide and so tall. The sad part is you're basically stuck at stock as pretty close to the maximum. On my '02 Forester, stock size being 215/60/R16, I'm basically limited to that size. Any wider, I rub the rear strut, any taller, I rub the spring perch(think that's what you call it). Sure you have a few milimeters to work with, but you're basically set to max at the start.
How to fix this?
Lift kit, coilovers, lower offset wheels, each with their own benifits and downsides. You figure out how you want to go about doing things.
As far as adverse effects with a different diameter tire, everyone else basically covered that. Your car and all it's electronics don't care...as long as all 4 are the same size.
Old 04-21-2006, 01:17 PM   #10
kleggo
Member#: 105294
Great idea.
__________________________________________________ _______________
i know it is, that's why i'm doing it.
If you read carefully you probably noticed that it's a LL Bean wagon.
How high up on the list do you think acceleration and torque is on my list of gotta haves for this car?
I drive my Cayman S when i want performance, not a station wagon
PS Torque is not a function of tire diameter.
Torque = the rotational equivalent of a force, and is calculated by multiplying the force causing rotation by the perpendicular distance from the line of action of the force to the centre of rotation. The unit is the newton metre.
What you percieve as Torque is affected by tire diameter, but Torque ( the force produced by the engine [not motor] is not).
have fun and thanks for the kind words.
be safe
kleggo
Old 04-21-2006, 02:43 PM   #11
UltimateLurker
Member#: 82488
06 Lotus Exige
Exactly.
Great idea.
You're confused, but I'm glad you think you know what you're talking about. If this is true, explain the performance #'s of the WR1. I know, I know, you're absolutely clueless as to what I'm talking about, hmmm, see a pattern here?
Torque at the wheels most certainly is, or rather, the practical application of engine torque is, don't make me explain it to you. However, for your application, I say g'head, you should be fine (but you knew that before you even started the thread).
UltimateLurker is offline   Reply With Quote
Old 04-21-2006, 04:23 PM   #12
kleggo
Member#: 105294
.[/quote]
UL
you are correct. hmmmmmm that seems to happen frequently.
i should have more clearly stated that ENGINE torque is not a function of tire diameter.
Resultant torque applied the Outside Diameter of the wheel / tire is most certainly a function of O.D.
be safe
kleggo
Old 04-21-2006, 04:46 PM   #13
ricardo
Member#: 64735
2006 Forester STi
The difference in torque at the wheels due to bigger wheels is no different in principle from the difference caused by a different final drive ratio.
The idea of killing the torque would only apply if the car had just the one fixed gear - having a selection of gears means that the gear selection and the point at which gear-changes occur will change slightly. That's all...
The car will go faster in each gear before it runs out of revs. Not such a bad thing.
ricardo is offline   Reply With Quote
Old 04-22-2006, 01:24 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
....and people will continue to do stupid things to nice cars every day.
....and the ll beaner is a slug to start with----magnifying that isn't the best idea, IMO...especially if ya drive it on the highway and have to merge or pass somebody.
....and I(very unfortunatly) have to 'dumb down' all too often, here, so that the deeeeeeeeeeeeewwwwwwwwwwwwwwwwwds have some hope of gleaning any possible utility from any of my posts...so if ya wanna pick apart what I post.....piss off.
Old 04-22-2006, 06:49 AM   #15
ricardo
Member#: 64735
2006 Forester STi
Ah, so this isn't an open forum then, I didn't notice that at first.
So am I allowed to ask how fuel mileage is made worse by taller gearing ?
Old 04-22-2006, 11:18 AM   #16
WrexT
Member#: 80169
2004 PSM WRX
lock thread!
Old 04-22-2006, 03:16 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
...the taller gearing isn't the issue it is rotational mass.....MUCH heavier and moved away from the axle mass is harder to get moving and to STOP moving once in motion.
If all ya did was drive on the highway....it may not be bad....but in all in town driving would be problematic.
Look at all the kiddie/ghetto hoopties runnin around on their lame assed dub-dubs....they get BAD mpg and eat brakes...ever wonder why???
Old 04-22-2006, 03:22 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by WrexT
lock thread!
...why....did I offend you???
'cuz if I did....I made my point, right???
This boards decline and the continuing decline in age and apparent education of its members is glaringly apparent to me....hence my 'dumbing down' to the mentality of its mean members.
koo
Old 04-22-2006, 05:12 PM   #19
ricardo
Member#: 64735
2006 Forester STi
I agree on the rotational inertia. In this case it is more tire, not more wheel, but an increase in rotational inertia will have the effect you describe in stop-start traffic.
I spend more time driving at constant speed, so for me the taller gearing from the taller tires would give me a fuel mileage improvement if I wanted.
Which effect predominates depends of course on all the other factors...
Interestingly, the Impreza WR1 in the UK has a 225/45 tire instead of a 225/40-17, chosen by Subaru UK for that particular special edition. That's an inch taller in overall diameter, and I don't suppose they did it to make it slower.
Anyway, time to piss off I think.
Old 04-22-2006, 05:18 PM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
...my initial comment was not directed, particularly, toward you...moreso toward UL....'cuz he can be a pain in the ass
.....and there are VERY few 225/40 tyres available..
Old 04-22-2006, 05:47 PM   #21
ricardo
Member#: 64735
2006 Forester STi
It can be worse - our household is blessed with two Forester STi's(*) and one RX8. All take 225/45-18. That pretty much means Bridgestones, not my preferred choice for UK roads and UK weather. More choice in 225/40-18 than that, and much more in 235/40, which is where I may be headed. At least one tire size fits all the cars...
* One in a showroom for sale, the other one delivered from Japan but yet to be registered, neither of them available for me to drive at the time of writing
Old 04-23-2006, 12:00 AM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
....225/40-17 is what I was thinking.....and using a 225/40-18 in place of a 225/45-18 would make VERY little difference in any meaningful way, other than shortening the gear a bit
Old 04-23-2006, 12:26 AM   #23
waktasz
Member#: 86356
2016 Aprilia
^^^ He ninja editted that above post. At first he didn't say anything about 18s.
I got your back Scotty.
Old 04-23-2006, 02:37 AM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....meh....no matter......as long as everybody thinks I'm not tryin ta pick a fight or piss off the wrong person, here
Old 04-23-2006, 02:11 PM   #25
Assassin4457
Member#: 96773
04 WRX, RIP GC8
So the speed and odo readings change when you get a bigger wheel for example, how to change them to be back to accurate ?
Assassin4457 is offline   Reply With Quote
Changing tire diameter = different gearing BUT..... reddevil Proven Power Bragging 14 07-30-2006 04:57 AM
Changing overall wheel/tire diameter I_smoke_hondas Tire & Wheel 1 11-14-2003 03:02 PM
Effect of wider wheel? (same diameter and weight) pdlindor Tire & Wheel 3 08-01-2003 11:03 AM
Cost-effectiveness of tires & wheels? Noots Brakes, Steering & Suspension 5 09-25-2001 03:45 AM
