03-20-2019, 12:00 AM | #1 |
Member Sales Rating: (2)
Member#: 314374
Vehicle:2003 WRX WRB |
V7 JDM STi ej207 w/68k miles
Hello All so I recently ran into some bad luck (quite literally) someone ran a stop sign and tboned my beloved bugeye. Instead of rebuilding it I’m deciding to part it out and buy something newer.
Anyways as the tittle states I have a •V7 JDM STi ej207 w/68k miles. Semi closed deck design it came with forged pistons from factory and everything you will need to drop it into your 02-05 wrx. •V7 jdm ecu with @i_wire ’s avcs plug and play harness. •silicone turbo inlet w/Perrin short ram intake. •VF30 turbo •Grimmspeed ewg up-pipe with red tial 38mm ewg •Brand new oem 07 STi oil pan. Planned to go EL but we all know how that turned out. •Grimmspeed 3port boost controller. •walbro 255lph fuel pump. I do have a front mount intercooler we can negotiate in the deal but the price at the bottom is without it. This motor was meticulously looked after all the preventive maintenance was done on it when I got it i.e. timing belt, rear main, and just flat out cleaning it. Since I’ve had the motor I’ve driven it a whopping 7k miles and have changed the oil 3 times. The first oil change was with the BG oil treatment to hopefully flush any unwanted gunk or debris away then was emptied and replaced with AMS OIL. I put the engine in the car diagnosed 1 cel that was easily fixed and it was immediately put on a trailer to get tuned english racing in Camas, WA Where Aaron pulled a whopping 345whp from it. Again people I know you can buy a stock one off eBay for $12 and I know you know a guy that has one for cheaper.. you are buying a proven engine that has been properly maintained and is ready to go. I put a lot of care into this motor because it was supposed to be in my car for a long time. Thanks for checking it out! I’m looking for $4,600 SHIPPED. CLUTCH NOT INCLUDED! Getting trailered to English RacingWeek before the accident
