Welcome to the North American Subaru Impreza Owners Club Sunday November 3, 2024
Old 10-23-2003, 11:45 PM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default ej20's and what works with what
when I get a jdm swap I wanna know if the usdm ej20 parts work with the jdm ones by parts I mean a down pipe made for a usdm wrx and stuff like that
scobaru is offline   Reply With Quote
Old 10-24-2003, 03:45 AM   #2
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default answer.
parts for JDM? easy.
bottom end: crank/rods = EJ18 parts. most likely u will have for free bc thats what u are pulling outa it.
air filter? same as the EJ18
oil filter: ditto
turbo: im sure any bolt on WRX one will fit
header: i spoke to HKS personally in asia and they said that their header will fit
up-pipe: dont need on. its already no-cat and made outa incronel
downpipe: same deal. most likely usdm will fit. u probbly dont need it though, i dotn think 280PS will be slower than any exhaust modded GDA
some parts should be compatible with USDM legacy turbo. that is only a suspicion though
rallispec can get u gaskets (although USDM ej20 shoudl work fine)
clutch is identical to a USDM WRX GDA clutch. i have one in my attic. i have a exedy USDM GDA clutch on my 94 JDM STI trans
OR u can just buy stuff off UK shops or UK ebay. stuff is cheap there, bc ej20 impreza is so frekin common.
h
supermoose is offline   Reply With Quote
Old 10-24-2003, 03:10 PM   #3
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
I agree with the statement made. Impreza engines are basically like lego's in that they will all fit each other...to an extent
Old 10-24-2003, 04:07 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
yeah pretty intchangeable
i used a ej205 oil pan on my ej20g no leaks ..
Old 10-24-2003, 08:28 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Jaxx
^-- bastard
-Jon
stimpy is offline   Reply With Quote
Baja Turbos: What works with What? honda killer Baja Forum 302 12-30-2023 01:24 PM
will an ao with and 04 work with an 03 Ben-no AccessPort 0 05-29-2006 12:58 PM
clutch and flywheel what works with what?!?! scobaru Subaru Conversions 10 01-06-2005 11:21 PM
Advan RG works with what brakes??? Subaruist Brakes, Steering & Suspension 1 10-23-2002 12:23 AM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 08:55 AM
